Comments: After adding a winch and some lights on a bar, my front end was drooping. So I replaced my 127 springs with a pair of 129's from a 6cyl jeep. It levelled out nicely. Now I need to put a 3/4" bb in the back to get some rake back.
Donor Vehicles rusted to the point that required cutting tools for removal
Recommended
yes
Comments: utilized 75ish Ford F-100 Front Coils Netted about 4.5" of lift on the XJ. The removal from donor vehicle was gruling however worth it. Installation on the xj was SUPER EZ! The rear leafs on the S-10 were a different story for removal. 3 hours of fighting the bolts and shearing off the gearing in two of my Craftsman ratchets resulted in a grinder with cutting disks being utilized. Sparks are KEWL!
Comments: Alcan springs make a great heavy duty spring for your offroad toy. no more cookie cutter lift kits. Alcan makes custom springs and suspensions hand made. Great product.
Fixed my drivers side tilt. Better clearance and ride now.
Cons
Not much in the con area currently. Still bottom out on runs but not as much. Pretty sure this is due to run conditions and lift size (2.5) not the actual product
Recommended
yes
Comments: After Big Bear run I sheared my rear drivers side leaf spring shackle without knowing. Major drivers side tilt made me aware of issue. Took it in to 4 wheel parts and about $745 dollars later and new leaf springs and shocks the tilt was severely reduced. Very small tilt now because I need new front shocks and leaf springs. Rides better now very happy. Asked around and was told the price was reasonable. I will update once I find out what springs where used. The shocks are Ranchos.
The 2 1/2 inch lift springs did a phenomenal job of tightening the steering up. The PO had used these monster shackles to lift the jeep and it was downright unsafe. The lift springs have restored my confidence to drive the Jeep on the road and the ability to bid on i had used these monster shackles to lift the jeep and it was downright unsafe. The lift springs have restored my confidence to drive the Jeep on the road and the ability to trust it on the trails!
Cons
I wish I would've gone straight to why Jay front springs the first go-round.
Recommended
yes
Comments: The springs flex phenomenally and provide a soft-ish ride. I do not have any shocks so the rebound can get kind of bad at times 😁!
nice spring, seems good quALITY, well put together packs
Cons
none
Recommended
yes
Comments: i ordered the crown h/d leafs with the hope to be a simple change from my worn out leafs. i was told i would get about 1.5" lift from the h/d springs. and planned to add new shackles to get about 3" total. i ended up with 3" after every thing was installed.....these were great. took a little muscle to put the bushings in, but at least you know they wont slip. the bands that hold the leafs together and center pin were very nicely installed. whole pack is 100% straight, (no individual leafs off center) and the best part.....they are very nicely priced.
i would deffinitly tell any one looking for a budget way to get 1.5-2" lift to grab a set of these.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
