Notices
Off Road Only AiROCKô Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Springs Next Product
Rating: None
Product Information
Manufacturer: Off Road Only
AiROCKô is a computer controlled coil replacement system. The coil springs are replaced by our custom air springs, and the bump stops are moved to the custom shock absorbers that come with the kit. The system includes four air springs, four shocks, the user interface, the AiROCKô Control Unit (ACU), four height sensors, stainless steel brackets, and the wiring harness and tubing to connect all of the components.
AiROCKô ties into the Vehicle Speed Sensor, (VSS) which in conjunction with the ACU, allows the system to know the vehicle speed and height of all four corners at all times. This information allows AiROCKô to operate in three different driving modes, which include "Off road", "Highway" and "Freeway". The end result is the best of both worlds-- total control of your vehicle's behavior off road, and a safe, level vehicle at higher speeds.
AiROCKô allows the user to control the height, pitch and roll of the vehicle with a touch of a button. Push the "right arrow" and your vehicle leans to the right, push the "up arrow" and the vehicle rises to its maximum height. Press the "check" button at any time and you return to your predetermined, level ride height. A simple, intuitive dash-mounted interface provides a powerful way of telling your vehicle's suspension how to behave in real time.
Button menus are also customizable so you can easily execute commands that you use most often, both on and off road. The user interface is encased in black anodized aluminum to ensure longevity and a clean OEM appearance. The interface even turns its backlit screen on automatically as night falls!
There are many advantages over conventional spring suspensions. On road, the ride is smoother and the ACU automatically compensates for body roll by making real time pressure changes in each corner. The system also allows you to drive a vehicle with very large tires everyday, while maintaining a lower center of gravity, thus providing better handling. The system also has an optional "egress" mode which tells the vehicle to lower itself every time you turn it off, making getting in and out of it much safer and easier.
Off road the system gives you complete manual control of your vehicle. In off camber situations you can tell the vehicle to "lean" into the hill, or lower the vehicle to keep the center of gravity down. Tired of hitting your bumper on tall rocks you're trying to climb? Press the "pitch front up" button and raise your bumper a few inches to clear those rocks! Next time you get high centered, simply raise the vehicle and continue down the trail. The air springs also articulate more naturally than coils. Coming down off of rocks is less jarring and off camber situations more stable. There are countless other situations that AiROCKô systems make safer and more enjoyable.
In all modes, the height and ground clearance of your vehicle are maintained no matter how much weight you add or subtract from it. Now adding more lift to accommodate larger tires takes place in minutes instead of swapping out coils, simply adjust your "ride height" from inside the cab.
AiROCKô is a coil replacement system; it is not a complete suspension lift kit. Currently we offer 4" and 6" AiROCKô bolt-on kits for Jeepģ Wrangler TJs. As with any coil lift, geometry and driveline issues that go along with a substantial lift have to be addressed before or while installing AiROCKô.
We highly recommend using the Rubicon Express Extreme Duty Long Arm lift with the AiROCKô 6" system. A Slip Yoke Eliminator is also needed to handle the extreme axle travel that the AiROCKô systems provide. The shock absorbers that come with our kits require bar pin eliminators in the lower front and upper rear. They also require front upper shock adaptors, which are made by JKS Manufacturing and others.
Most importantly, the AiROCKô systems require an on board air, (OBA) system. There are many ways to design an OBA system, which is why we do not include one as part of the AiROCKô system. We do sell a separate OBA system and many fittings and accessories you may need when piecing together your own OBA setup.
Below is a list of additional parts needed for the AiROCK kits-
Additional Parts required 4" AiROCK 6" AiROCK
CV Drive Shaft (rear) yes yes
Bar Pin Eliminators (front) yes yes
Bar Pin Eliminators (rear) yes yes
Front Shock Adaptors yes yes
Long Arm kit no yes
Adjustable Track Bars* yes yes
Adjustable upper arms (rear)* yes yes
On Board Air system yes yes
* included in Rubicon Express Long Arm kit
The installation process is very straight forward. You essentially replace your old coils and shock absorbers, mount the height sensors, interface and ACU, and run the wiring and air lines. Detailed instruction manual and user guide, along with great customer support ensure a smooth install.
We also have a growing list of dealers all around the country. They can help you piece together any additional parts you may need and install the kit for you.
http://www.offroadonly.com/docs/airock/install/
http://www.offroadonly.com/contact/dealers1.shtml
You can order AiROCKô directly from Off Road Only, or from one of our dealers. Both the 4" and 6" AiROCKô systems are $3195. Please call 651-644-2323 to provide us with details about your make and model. You can also order from our online store at www.offroadonly.com/store.
We only offer TJ bolt-on systems at this time; please contact us for other applications. Additional parts and labor are often required.
If you need additional parts for your AiROCK installation be sure to check out our online store for a growing list of air and suspension parts!
https://secure48.mysecureorder.net/offroadonly/catalog/
Check out more pics and how to
http://smg.photobucket.com/albums/v654/wildman4x4nut/New%20Pictures/?action=view&current=AiRock.flv http://www.offroadonly.com/products/suspension/airock/airock2-2.shtml
http://www.offroadonly.com/projects/
http://www.ryansrubicon.com/Build.html
None
ThreadForumRepliesLast Post
Rocky Road outfitters MK 2 1/8" Lift Kit Complete Lift Kits 3 05-09-2011 09:44 AM
Rustys Off Road 4.5" lift Complete Lift Kits 7 11-29-2010 07:38 PM
Rusty's Off Road 2" Lift with Stabilizer Complete Lift Kits 6 12-17-2009 10:22 PM
Cage Off-Road 4" SA Suspension Lift Complete Lift Kits 1 12-18-2008 10:29 PM
Rocky Road Outfitters SOA with OTT and CJ to YJ Conversion Complete Lift Kits 2 10-01-2008 11:20 AM
