Comments: I ordered a set of 4 of these from Poly Performance. The ones I have are for a TJ and a few ZJ models if I remember correctly.
They will work on the front or the back. There is no size difference in front or rear spacers, so don't be alarmed if you get a set and all of them are the same. I have these on the back and 1'' Pro Comp spacers in the front.
Front install is not a problem, but I had a time with the back. It was a tight fit on my Jeep.
Very good springs. Was able to put 31s under them after the spacers. Very cheap but also very durable
Cons
NONE
Recommended
yes
Comments: Got the 2 3/4 coil spacers, 60 for parts and only like 60 for labor as well. Was able to get 31s under it, rubs a little bit on the inside but def a great purchase
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
