Rubicon Express RE1600 Adjustable Track Bar Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Track Bars Next Product
Rating:
Product Information
MSRP: $256.00
Average Price: $149.46
Manufacturer: Rubicon Express
Recommended?
Yes: 26 / No: 4
Adjustable front track bar for TJ/XJ/ZJ/MJ.
Correct alignment and handling problems on lifted vehicles with our adjustable chromoly track bar. Easy installation works on vehicles with 2.5" - 5.5" of lift. Allows for more wheel travel than the stock unit and features a replaceable rod end for easier future maintenance.
None
Page 2 of 2 1 2
WillyB
110K miles and counting!
WillyB's Reviews
04-18-2008, 05:44 PM
Price: $180.00
Recommended? Yes
Comments: Easy install, but barely fits w/ 4.5" lift. Good solid feel to the suspension. Only bought this to replace the stock one that didn't align with the axle bracket after I welded it back on.
discomonkey
discomonkey's Reviews
04-16-2008, 01:37 PM
Price: $100.00
Recommended? Yes
Comments: Good for me just came with the lift kit
chappy84
chappy84's Reviews
03-31-2008, 08:07 PM
Price: $100.00
Recommended? Yes
Comments: sturdy and dependable
SillyPutty
SillyPutty's Reviews
03-27-2008, 05:22 PM
Price: $160.00
Recommended? Yes
Comments: adjustable and tracks! two sides of a delightful coin.
bmyohn
Youngin'
bmyohn's Reviews
12-01-2007, 08:10 PM
Pros: adjustable, keeps stock mount (less $$$)
Cons: heim joint, single shear
Recommended? No
Comments: It worked really well for a while, then i began to notice a clunk, it wasnt because it wasnt tight, it was that the heim joint wallowed out the frame mount hole. If on a budget go for it, other wise go for a double shear trac bar
barry1me
barry1me's Reviews
03-28-2007, 02:34 PM
Pros: very robust design
Cons: still looking
Recommended? Yes
Comments: This is a great trac bar, very strong, and looks good. Once again RE made another great product.
Dubakountry
Dubakountry's Reviews
08-22-2006, 03:59 PM
Price: $120.00
Pros: Easy installation, strong
Cons: n/a
Recommended? Yes
Comments: I just installed this over the weekend, and was the easiest part of the installation. I needed to drill out the previous whole in order to get the bolt at the fish eye to fit through, but that was the only change to the original set up. With this track bar you DO NOT need to offset the track bar on the bottom bracket. VERY easy installation.
ChristopherJ
Resident Physician
ChristopherJ's Reviews
08-03-2006, 04:23 PM
Price: $120.00
Pros: Very stout and adjustable.
Cons: none
Recommended? Yes
Comments: Install of this trackbar was a breeze. The mount DID need to be drilled out, but that was stated in the directions and went easily with the correct drill bit. The trackbar is easily adjustable and does its job. Add $25 to the cost for the drill bit needed at a local Ace Hardware, you will be glad you did.
Maco98XJ
Maco98XJ's Reviews
08-02-2006, 12:55 PM
Pros: Lightweight, strong, promotes good flexability
Cons: If you dont have a drill press or a drill with a 1/2" chuck, youre in for a long day when you try to install this.
Recommended? Yes
Comments: Drilling that darn hole took way longer than it should have. If I did it over I would pull the upper mount bracket out of the XJ and drill that way. Dont make more work for yourself like I did. Make sure you have a 1/2" chuck drill. Other than that, I wish it was black. Yeah, paint is cheap but its just another step.
digitalcox
digitalcox's Reviews
08-01-2006, 10:38 AM
Price: $130.00
Pros: Stronger than stock, adjustable, affordable, easy installation
Cons: n/a
Recommended? Yes
Comments: I just recentely installed this track bar on my TJ. The installation was really simple and didn't take too long to install. The only extra thing you will have to do is drill out the hole mounted to the frame to accomodate for the new hardware for the track bar.
Adjusting the track bar is easy and my axle is now centered under my Jeep.
Have a good one,
Justin
Page 2 of 2 1 2
ThreadForumRepliesLast Post
Rubicon Express 4" standard kit YJ Complete Lift Kits 23 08-17-2015 04:26 PM
Rough Country Adjustable Front Track Bar Track Bars 18 06-19-2015 04:00 AM
Rubicon Express 2 1/2 " Spring - Over Complete Lift Kits 4 07-22-2014 08:46 PM
SuperLift Front Adjustable Track Bar Track Bars 8 01-11-2013 10:33 AM
Rubicon Express RE5505 Complete Lift Kits 5 08-16-2012 11:03 PM
