Go Back JeepForum.com > Reviews > Suspension > Track Bars > Rubicon Express RE1600 Adjustable Track Bar
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Rubicon Express RE1600 Adjustable Track Bar Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Track Bars Next Product
Rating:
Product Information
MSRP: $256.00
Average Price: $153.42
Manufacturer: Rubicon Express
Recommended?
Yes: 21 / No: 2
Adjustable front track bar for TJ/XJ/ZJ/MJ.
Correct alignment and handling problems on lifted vehicles with our adjustable chromoly track bar. Easy installation works on vehicles with 2.5" - 5.5" of lift. Allows for more wheel travel than the stock unit and features a replaceable rod end for easier future maintenance.
Page 1 of 2 1 2 > Last »
Pontiacman
Pontiacman's Reviews
10-01-2011, 07:43 AM
Price: $124.00
Pros: Works good with 3.5" Superflex lift. Alignment on Jeep good. RE backs up the product.
Cons: After eight years, the heim joint wore out and threads galled, damaging the nut threads. However RE took care of me
Recommended? Yes
Comments: This setup installed by original owner in 2003. I bought it 7/2011. The heim joint was worn out. Ordered a new one for $25. I tried to remove the remove the old one and it was really stuck. After great effort using an oxygen and Mapp gas torch setup on the track bar nut and ice on the heim joint, it forcibly came out using a large pipe wrench. It turns out the threads had galled. Damaged the welded on nut. I called Rubicon Express explaining I am not happy this item is not serviceable. They offer to replace the actual bar only under warranty, or for about cost send me a completely new setup. For $60, it was worth it due to getting a new axle end bushing and replacement small hardware along with a new track bar.
Lesson learned: Use anti-seize paste on all threads with this setup.
cbenez1
cbenez1's Reviews
06-07-2010, 04:26 PM
Price: $175.00
Pros: Has not failed me yet
Cons: None
Recommended? Yes
Comments: Nice finish. Nice upgrade over stock bar.
1RustyXJ
1RustyXJ's Reviews
03-25-2010, 09:37 PM
Price: $165.00
Pros: Tough, allows more flex, easy to adjust, and will accommodate more lift.
Cons: Still uses OEM mount and not a stronger "HD" mount on driver side.
Recommended? Yes
Comments: This trackbar has been very good to me. I installed it, adjusted it, and haven't touched it in over 2 years. Seems to hold up just fine with my 3" lift.
Luke94XJ
Luke94XJ's Reviews
10-15-2009, 04:54 PM
Price: $150.00
Pros: Allows for a lot of flex, while still being able to use stock mounting points, and its adjustable.
Cons: Came loose after a while, had to buy a $20 drill bit
Recommended? Yes
Comments: Works great for me, I actually got this track bar in a $100 lift kit I bought locally.
It was definitely a ***** getting the old bar out the lower bolt was spinning the sleeve inside of the old bearing. I had to sneak my sawzall in there and cut it.
Had to make a run to ace to get a 5/8 drill bit (I believe, can't remember), which I found was still tight, so I reamed it out a bit.
The upper bolt came loose after about 50 miles and I had to re tighten it, could have been my mistake. I haven't thought about it lately, but it would have been nice to have a lock washer handy instead of the nylon lock nut.
you'll also need some sizable crescent wrenches to adjust the thing.
works great though other than those small problems. helps me flex out like a mofo.
bob6987
bob6987's Reviews
07-15-2009, 10:11 PM
Price: $280.05
Pros: Beefier then there stand track bar, installation was easy.
Cons: none so far
Recommended? Yes
Comments: Beefier then there stand track bar, installation was easy.
Blainer
Blainer's Reviews
06-22-2009, 12:34 AM
Price: $165.00
Pros: High quality part, looks great functions well, serviceable.
Cons: none
Recommended? Yes
Comments: I bought this part used from a fellow jeeper and even after his many wheeling events the track bar still is in excellent shape. I was able to service the bushings through RE as well.
Steve2237
Steve2237's Reviews
01-21-2009, 10:46 AM
Price: $75.00
Recommended? Yes
Comments: >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>........... .................................................. .................................................. .....................
srmitchell
srmitchell's Reviews
11-27-2008, 09:31 PM
Price: $140.00
Recommended? Yes
Comments: Great construction, easy to adjust between my 2 inch and 3.5 inch lift.
Tightened up my steering, and allows more droop.
C2kraft
C2kraft's Reviews
08-01-2008, 12:01 PM
Price: $170.00
Recommended? Yes
Comments: I purchased both the front and rear track bars.
With the right tools the installation was quick. Nice to have the adjustability.
rlk_99
rlk_99's Reviews
07-06-2008, 09:09 AM
Price: $140.00
Recommended? Yes
Comments: Easy to install. Easy to set. Good price. Maybe the best one on the market.
ORmudslinger
ORmudslinger's Reviews
07-02-2008, 12:23 AM
Pros: stout
Cons: Modifying upper mount
Recommended? No
Comments: Upper mount comes loose and moves around..clunk, clunk. Waiting for the bolt to snap one of these days. Hope I'm not running down the interstate at that time.
flatlander757
Now in the 937
flatlander757's Reviews
05-10-2008, 10:28 PM
Price: $165.00
Recommended? Yes
Comments: Good trackbar, the heim joint is nice for flexibility. Seems very durable and works great in conjunction with the RE1602 angled CV trackbar bracket.
av8tr
av8tr's Reviews
04-29-2008, 02:36 PM
Price: $256.00
Recommended? Yes
Comments: Easy to install. This bar is really intended for 4.5 and higher but works well with the 3.5.
WillyB
Too much downtime
WillyB's Reviews
04-18-2008, 04:44 PM
Price: $180.00
Recommended? Yes
Comments: Easy install, but barely fits w/ 4.5" lift. Good solid feel to the suspension. Only bought this to replace the stock one that didn't align with the axle bracket after I welded it back on.
discomonkey
discomonkey's Reviews
04-16-2008, 12:37 PM
Price: $100.00
Recommended? Yes
Comments: Good for me just came with the lift kit
chappy84
chappy84's Reviews
03-31-2008, 07:07 PM
Price: $100.00
Recommended? Yes
Comments: sturdy and dependable
SillyPutty
SillyPutty's Reviews
03-27-2008, 04:22 PM
Price: $160.00
Recommended? Yes
Comments: adjustable and tracks! two sides of a delightful coin.
bmyohn
Youngin'
bmyohn's Reviews
12-01-2007, 07:10 PM
Pros: adjustable, keeps stock mount (less $$$)
Cons: heim joint, single shear
Recommended? No
Comments: It worked really well for a while, then i began to notice a clunk, it wasnt because it wasnt tight, it was that the heim joint wallowed out the frame mount hole. If on a budget go for it, other wise go for a double shear trac bar
barry1me
barry1me's Reviews
03-28-2007, 01:34 PM
Pros: very robust design
Cons: still looking
Recommended? Yes
Comments: This is a great trac bar, very strong, and looks good. Once again RE made another great product.
Dubakountry
Dubakountry's Reviews
08-22-2006, 02:59 PM
Price: $120.00
Pros: Easy installation, strong
Cons: n/a
Recommended? Yes
Comments: I just installed this over the weekend, and was the easiest part of the installation. I needed to drill out the previous whole in order to get the bolt at the fish eye to fit through, but that was the only change to the original set up. With this track bar you DO NOT need to offset the track bar on the bottom bracket. VERY easy installation.
ThreadForumRepliesLast Post
Rubicon Express 4" standard kit YJ Complete Lift Kits 17 10-19-2010 11:00 PM
Rubicon Express RE5505 Complete Lift Kits 4 01-04-2010 08:46 AM
SuperLift Front Adjustable Track Bar Track Bars 5 10-16-2009 08:15 PM
Rough Country Adjustable Front Track Bar Track Bars 6 03-10-2009 09:45 PM
Rubicon Express 2 1/2 " Spring - Over Complete Lift Kits 2 03-02-2009 12:01 PM
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
