Go Back JeepForum.com > Reviews > Suspension > Track Bars > Rough Country Adjustable Front Track Bar
Rough Country Adjustable Front Track Bar Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Track Bars Next Product
Rating:
Product Information
MSRP: $150.00
Average Price: $112.38
Manufacturer: Rough Country
Recommended?
Yes: 12 / No: 1
Gives full adjustability and allows you to easily center your axle under your Jeep®
Eliminates front-end wobble
Improves steering
HitowerInc
HitowerInc's Reviews
10-04-2011, 08:33 AM
Price: $129.00
Pros: Pretty Easy to install, seems pretty tough as well. Nice and beefy.
Cons: None yet.
Recommended? Yes
Comments: I got this track bar off of ebay and For $129. It installed easily and seems pretty rugged. I'm sure there are better out there but for the price this is a good buy.
nwaxtreme
nwaxtreme's Reviews
09-04-2011, 11:58 PM
Price: $130.00
Pros: Well made beats stock.
Cons: None.
Recommended? Yes
Comments: The only RC component on my jeep but thoroughly satisfied with their track bar. I compared it to RE and the decision was hands down RC.
Rocker33
Rocker33's Reviews
07-13-2011, 01:28 AM
Price: $150.00
Pros: cheap, good quality, good service
Cons: Theres better out there
Recommended? Yes
Comments: The RC adjustable track bar comes with a relocation bracket that works injunction with a drop pitman arm from the steering box. It is nice to set the track bar mounting on the original mounting hole. To truelly benifitt from this upgrade make sure you have a fairly new steering stabalizer.
grabber1000
Junior Member
grabber1000's Reviews
10-16-2010, 02:08 PM
Price: $95.00
Pros: Right up the road
Cons: Shipping cost
Recommended? Yes
Comments: Good Track bar
drewtj05
drewtj05's Reviews
09-20-2010, 05:39 PM
Price: $129.99
Pros: Cheap
Cons: Caused minor bumpsteer.
Recommended? Yes
Comments: Bought this TB to go with my RC lift. Installed it and all seemed well, but I'm pretty sure that with this trackbar you should install a longer pitman arm since it lowers the frame trackbar mount which i believe was the cause of my bumpsteer.
cheapjeep06
cheapjeep06's Reviews
09-12-2010, 06:04 PM
Price: $126.00
Pros: Easy install, clears diff so far
Cons: No grease or grease fitting for frame end
Recommended? Yes
Comments: Had stocker out and new one installed in just over an hour. Hardest part was drilling hole for mount. Disappointed that there was no lube sent with the bushing, and no grease fitting (maybe poly doesn't need greased?).
psychoteen101
psychoteen101's Reviews
04-18-2010, 02:22 PM
Price: $125.00
Pros: Great price, great quallity.
Cons: No cons
Recommended? Yes
Comments: I bought the kit that came with the bracket for 4-6" of lift. Lined up with the factory bolt holes and was an easy installation.
fireball27190
fireball27190's Reviews
03-10-2009, 09:45 PM
Price: $150.00
Recommended? Yes
Comments: Bought the bar with the bracket that bolts on to the frame so you don't have to run a tie rod style end. this new design is way more heavy duty then stock style and wont break and wear as easily either.
brand0nlp
brand0nlp's Reviews
03-05-2009, 09:15 PM
Price: $99.00
Recommended? Yes
Comments: track bar makes it easy to align the front axle, was a very simple install, on top of being a simple install it was at a great price.
travisf2002
travisf2002's Reviews
11-18-2008, 03:28 PM
Price: $99.00
Recommended? Yes
Comments: I like the track bar it did its job i need the axle to be centered and it helped get rid of the death wobble.
DerekRI
DerekRI's Reviews
11-14-2008, 03:32 PM
Price: $1.00
Recommended? Yes
Comments: Easy install, great for the price. The replacement bolt for the lower mount that the track bar came with was way too long. Got another one at the hardware store, and all set.
hocgreen
hocgreen's Reviews
05-13-2008, 01:04 AM
Price: $120.00
Recommended? No
Comments: bump steer, death wobble, and road vibrations are a few of the things aimed for when buying this... You would be better off getting your tires balanced and an alignment.
DOES have conflicts with after market skid plate mounting/removal. Gets in the way just enough to be a pain in the ***.
chadk77
chadk77's Reviews
04-29-2008, 12:06 PM
Price: $107.00
Recommended? Yes
Comments: Easy install. Very sturdy adjustable track bar.
ThreadForumRepliesLast Post
Rough Country 4" Rough Country Suspension Lift Complete Lift Kits 46 12-22-2011 04:52 PM
Rough Country - X-Flex Adjustable Control Arms Lower Control Arms 4 01-05-2010 02:30 AM
rough country Adjustable greasable front upper and lower control arms Control Arms 6 11-23-2009 06:37 PM
SuperLift Front Adjustable Track Bar Track Bars 5 10-16-2009 08:15 PM
Rough Country Adjustable Uppers Control Arms 2 02-02-2009 11:02 PM
Glock Forum
