Notices
JKS Adjustable Trac-Bar Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Track Bars Next Product
Rating:
Product Information
MSRP: $315.00
Average Price: $174.80
Manufacturer: JKS
Recommended?
Yes: 63 / No: 2
The JKS Adjustable Trackbar is an essential upgrade to any lifted Jeep® still using the OE trackbar. The length is easily adjusted to perfectly center the axle housing beneath the vehicle. Unlike relocation brackets, our Adjustable Trackbar is compatible with virtually any suspension system and allows constant changes as vehicle modifications require.
The ends of each JKS Adjustable Trackbar feature bushings specifically chosen to provide maximum off-road performance while minimizing the transfer of road noise and
vibrations. A Johnny Joint® spherical polyurethane (2.0" or 2.5"), Dura-Thane™ performance polyurethane or OE rubber bushing is used, depending on each application's requirements.
Manufactured from 1.25" x 0.156" DOM tubing, JKS Adjustable Trackbars are bent to OE specifications for proper geometry and clearance. A zinc plating and durable powdercoat finish provide excellent protection from corrosion and trail debris.
None
Page 3 of 4 1 2 3 4 > Last »
river2c
river2c's Reviews
01-02-2010, 03:48 PM
Price: $139.00
Pros: quality
Cons: none
Recommended? Yes
Comments: I have the JKS adjustable front track bar on my JK. It is easy to adjust and much stronger than stock.
DoinSumthin
DoinSumthin's Reviews
10-07-2009, 10:18 PM
Price: $275.00
Pros: HEAVY and Durable! This has an extreme bushing on one side, and one beefy heim joint at the other! Easy install. Greasable as well. Very nice product!
Cons: none
Recommended? Yes
Comments: Go buy one.
SDT03GCOverland
SDT03GCOverland's Reviews
08-14-2009, 07:55 PM
Price: $137.00
Pros: Heavy Duty. Solved all my problems.
Cons: None at all.
Recommended? Yes
Comments: This was a remedy for a drop trac-bar bracket and I cannot rave enough about such an upgrade.
JeeperFound
JeeperFound's Reviews
08-02-2009, 07:10 PM
Price: $140.00
Pros: Seems like a very sturdy piece of hardware!
Cons: None so far
Recommended? Yes
Comments: I bought this one because the bushings were bad in the my stock rear track. Very easy and straight forward to install.
mtnmarc
mtnmarc's Reviews
07-30-2009, 04:02 AM
Price: $65.00
Pros: durable
Cons: i cant think of any
Recommended? Yes
Comments: works great with my jeep. id recommend it any day. i love the adjustability of it. can go bigger lift without buying a new track bar
Unlimited04
This post/info=my opinion
Unlimited04's Reviews
06-26-2009, 10:39 AM
Price: $250.00
Pros: adjustable, uses JJ
Cons: hits the diff cover and/or the tie-rod
Recommended? No
Comments: old style TJ/XJ single shear version hits the diff cover with anything less than 2" bumpstop extension over stock.
the new style TJ/XJ single shear version hits the tie-rod with anything less than 2" bumpstop extension over stock.
See mudb8's track bar thread for more info.
RockyClymer
RedRock4Wheeler
RockyClymer's Reviews
05-10-2009, 05:33 PM
Price: $260.00
Pros: Solid construction and well built Good joints
Cons: Need to remove to adjust
Recommended? Yes
Comments: Price was about 130 each - I have both front and rear. I found them easy to install, make sure the torque is correct and the jam nut is real tight. The adjustment was easy for me and they have been doing their job for about 10k miles as of write up. Would definitely recommend for any lift over a couple of inches.
TX02WJ
TX02WJ's Reviews
03-27-2009, 12:10 AM
Price: $130.00
Recommended? Yes
Comments: excellent! No more death wobble! A lot beefier as well. My jeep thanks e after running it out of alignment for a few weeks...oops
_Kyle_
_Kyle_'s Reviews
03-19-2009, 10:04 PM
Price: $135.00
Recommended? Yes
Comments: Great product. Order from Kolak for a great price for JF members! 75 characters...
xeneau
xeneau's Reviews
02-25-2009, 10:03 PM
Price: $315.00
Recommended? Yes
Comments: I have both front and rear installed. Once they are in, it is incredibly easy to make adjustments as needed. Overall, a very solid product for re-centering axles after any amount of lift.
canoeman71
canoeman71's Reviews
01-31-2009, 05:50 PM
Price: $100.00
Recommended? Yes
Comments: very nice product-made the lift so much easier than dealing with that bracket, plus it can be adjusted up to 6 inches for any changes I may do later on...
wjjeep4x4
wjjeep4x4's Reviews
01-12-2009, 12:14 PM
Price: $160.00
Recommended? Yes
The JKS Adjustable Trackbar for my OME lift does its job and does it well!
froggo27
froggo27's Reviews
01-02-2009, 12:37 AM
Price: $200.00
Recommended? Yes
Comments: Great product to have after putting on a lift on the Jeep. It sets your axle straight.
87XJ00TJ
87XJ00TJ's Reviews
12-24-2008, 11:16 PM
Price: $199.00
Recommended? Yes
Comments: I love it so far...the old one was popping on one end and wallowing on the other.
jeepin_98
jeepin_98's Reviews
11-27-2008, 09:27 AM
Price: $200.00
Recommended? Yes
Comments: I just installed it so i really dont have anything to say about it you can tell it will out perform the stock track bar its about 20 times the sie of th estock one.
erickpl
erickpl's Reviews
11-24-2008, 12:28 PM
Price: $200.00
Recommended? Yes
Comments: Why do I need 75 characters to provide a review? I Just want to list em. Adding characters to shut this thing up.
rlanderton
RedRock4Wheeler
rlanderton's Reviews
11-12-2008, 12:31 PM
Price: $260.00
Recommended? Yes
Comments: Installed both front and rear adj track bars as a part of the OME lift kit. They are well built and fairly easy to install if you take careful measurements to center the axle. No rocks yet, so I will report back in near future.
BlackE1
BlackE1's Reviews
08-19-2008, 01:59 PM
Price: $215.00
Recommended? Yes
Comments: I had to install this after i bent the stock track bar. My BDS lift did not come with a adjustable track bar so the mount on axle side was modified. I went back to the stock mounting location with this adjustable track bar.
distortedtj
distortedtj's Reviews
07-20-2008, 09:17 AM
Price: $129.00
Recommended? Yes
Comments: BEEFY...that is all need said.............................................. .........................
SquirrelPig
SquirrelPig's Reviews
07-02-2008, 02:08 PM
Price: $280.00
Recommended? Yes
Comments: OK, this isn't really a JKS piece. I have the Kevin's Track Bar Conversion. This really helped eliminate death wobble and flexes great.
ThreadForumRepliesLast Post
Rough Country Lower Adjustable CAs Control Arms 15 01-05-2016 08:11 AM
Currie Rear adjustable uppers Control Arms 24 10-12-2013 06:37 PM
BDS Adjustable Front Trackbar Track Bars 5 04-05-2013 12:06 PM
Rough Country Adjustable Uppers Control Arms 4 10-10-2012 05:09 AM
Pro Comp Adjustable Cam Bolts Control Arms 0 10-12-2008 04:07 PM
