Iron Rock Offroad Double shear track bar kit Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Track Bars Next Product
Rating:
Product Information
Average Price: $180.82
Manufacturer: Iron Rock Offroad
Recommended?
Yes: 20 / No: 2
Its a heavy duty double shear adjustable track bar kit
This kit is designed to replace your factory or aftermarket track bar. The new bracket you'll receive is CNC Laser cut and precision break bent from 1/4" plate steel for extreme strength and durability. It drops your track bar 3/4" to counteract bumpsteer as it occurs in XJ's and ZJ's especially with taller lift heights. The track bar is 1.25" cold rolled solid steel bar and is adjustable for a large range of different lift heights!
The new polyurethane bushing end at the uniframe side will allow as much suspension travel as your control arms or shocks will allow with no restriction like a ball joint style tie rod end.
None
Page 1 of 2 1 2 > Last
SmashDN
SmashDN's Reviews
10-24-2016, 03:49 PM
Price: $199.99
Pros: Beefy bar.
Cons: None thus far
Recommended? Yes
Comments: Bar has thus far been very good. Can't say that it has remedied any of the problems I am experiencing but feel that it was still a good buy to get the smaller factory bar out of there and no that I have a quality piece of gear down there.
bluejunior
bluejunior's Reviews
06-08-2015, 02:07 PM
Price: $190.00
Pros: Perfect fit, beefy as heck.
Cons: Heavy, if you're worried about that.
Recommended? Yes
Comments: What can I say, it's rock solid and fits well. It's popular for a reason. I recommend it to any that need an adjustable.
vang7322
vang7322's Reviews
03-14-2015, 02:06 AM
Price: $1.00
Pros: 1
Cons: 1
Recommended? Yes
Comments: 1
HS00XJ
HS00XJ's Reviews
03-06-2015, 02:12 PM
Price: $200.00
Pros: beefy
Cons: none
Recommended? Yes
Comments: The track bar is very beefy and centered my axle like a boss. I would recommend this bar over others any day.
Rhinoed_ZJ
Rhinoed_ZJ's Reviews
08-21-2014, 03:19 PM
Price: $180.00
Pros: Very beefy setup, strong bar, strong bracket
Cons: none so far
Recommended? Yes
Comments: I got this to try and help fix a bad death wobble in my 97 ZJ. This thing is worth the money, much beefier than the stock bar. This and a new set of tires and no death wobble so far, knock on wood. Pretty easy to install, straighforward instructions. Definitely recommending to others.
T-REXJ
T-REXJ's Reviews
12-20-2013, 05:09 PM
Price: $185.00
Pros: This thing is really beefy
Cons: none
Recommended? Yes
Comments: I am really satisfied with the product i got the adujustable version and is really easy to install
Toebee97
Toebee97's Reviews
08-07-2013, 12:42 AM
Price: $189.99
Pros: Awesome. 1.25" solid steel rod. Anything less would be uncivilized.
Cons: Zero.
Recommended? Yes
Comments: Badass trackbar for the money. Good luck finding anything better for the price.
Agility
Agility's Reviews
07-14-2013, 10:16 AM
Price: $190.00
Pros: good price, included the bracket, solid reputation
Cons: expensive to ship
Recommended? Yes
Comments: I only just installed this track bar. My HD track bar with the stock mounting style went on after the lift and I started getting death wobble less than 6 months later. I just threw this track bar and bracket on the XJ a few days ago. My death wobble is gone and my steering feels a little tighter going over bumps, especially on the highway.
DoubleUp686
DoubleUp686's Reviews
05-06-2013, 01:59 PM
Price: $200.00
Pros: Beefy as hell! The flange mount is way stronger.
Cons: None that I can think of.
Recommended? Yes
Comments: I got this to fix the offset resulting from my 3" lift. I also had a death wobble going on, and even though the track bar wasn't the cause I'm still glad I bought this because it is designed really well. Install wasn't too hard except I had to drill out a bolt for the new mount, and that took a while.
lostatindo
lostatindo's Reviews
04-18-2013, 04:48 PM
Price: $189.99
Pros: double shear, can't beat that. fully bolt-on.
Cons: none
Recommended? Yes
Comments: This is a great product. Comes with track bar, bracket, and all the hardware. Simple install as it is fully bolt-on. Very happy with product and IRO.
premo
premo's Reviews
04-01-2013, 09:04 PM
Price: $190.00
Pros: Stout track bar, great double sheer bracket, easy bolt on mod
Cons: frame side bushing should be a hiem joint
Recommended? No
Comments: The bar and bracket itself is stout, well built, etc. The only problem I've ran into is the frame side is a bushing and not a hiem joint. I run a 6" RE long arm with 35's so I get a bit of bump steer and blow the bushings out way to frequently. I understand they have a prototype though. If I were to do it again, I would probably get something else due to my setup. This would probably be a better setup for someone running smaller tires with different backspacing.
GTO71
GTO71's Reviews
11-25-2012, 07:20 PM
Price: $200.00
Pros: Quality
Cons: Can not run on stock height, I installed my lift in portions over 3 days, after the track bar but before the lift coils the track bar hits the diff cover....oh well....
Recommended? Yes
Comments: Great to adjust and fine tune with a alingment rack, new bracket is nice and clean also. Really makes stering so much better like Mercedez Benz SUV
xj_noob
xj_noob's Reviews
10-13-2012, 01:40 PM
Price: $190.00
Pros: Very beefy bar, bracket is solid
Cons: n/a
Recommended? Yes
Comments: This trackbar puts the rest to shame, although it uses polyurethane bushings on both ends, it tightens up your steering like nothing else. very simple to install, takes just under an hour to do by yourself.
Airborn
Airborn's Reviews
08-06-2012, 05:19 PM
Price: $160.00
Pros: Strong
Cons: none
Recommended? Yes
Comments: Great fit, strong, heavy duty. Great for any lift IMO
dougmorgan99
dougmorgan99's Reviews
01-14-2011, 05:02 AM
Price: $180.00
Pros: Beefy... great price...
Cons: With a 2 inch BB lift, the trackbar hits my diff cover on large bumps...
Recommended? Yes
Comments: This for sure rocks and helped cure my DW for having a worn factory bar. Plus it grows with your future lifts since I plan on going with a 4.5 IRO lift later.
btait1
btait1's Reviews
08-12-2010, 08:02 PM
Price: $190.00
Pros: Strong. quality. comes with all the mounting hardware/bolts/nuts/washers. quick and easy install.
Cons: Its really heavy, so when it comes time to install you may need a friend to help hold up the other end.
Recommended? Yes
Comments: It does what its supposed to do. And it will continue to do its job because its so strong and thick.
cahlheim
cahlheim's Reviews
05-07-2010, 12:05 PM
Price: $205.00
Pros: Very beefy
Cons: none
Recommended? Yes
Comments: Chose this over the RE HD Track Bar and mount. Very happy with the choice.
dougmorgan99
04-24-2010, 12:44 AM
Price: $189.00
Pros: Heavy duty and truly awesome! Built like a tank!
Cons: None, other than the kit could of been packed with a little grease to prep the poly bushings. I had to spend $10 for a whole tube of Green Grease when I only needed a little bit.
Recommended? Yes
Comments: This thing is no joke when it came to being fabricated! Iron Rock Off Road truly "rocks" for coming up with this great kit. It exorcised my Death Wobble Demon! It did stiffen up my steering response and got rid of my front end clunking sound to boot.
keaton
keaton's Reviews
02-20-2010, 05:09 PM
Price: $190.00
Pros: Stiffened the front end up, pulls back to center...BEEF
Cons: NONE.
Recommended? Yes
Comments: Told my dad to get me it as my christmas present haha. Noticed a huge difference after i put it on. Stiffened everything up. Feels awesome. The bar is beef and the bracket is nice and quality. Would definately buy again. Great product.
CalebsXJ
CalebsXJ's Reviews
09-14-2009, 11:00 PM
Price: $189.00
Pros: Pure Beef!
Cons: NONE
Recommended? Yes
Comments: Highly recommended, compares to RE, and TNT.
ThreadForumRepliesLast Post
Iron Rock Offroad WJ 3" Lift Kit Complete Lift Kits 11 08-11-2016 10:13 AM
Iron Rock Offroad Iron Rock 3" Lift Complete Lift Kits 12 05-04-2016 11:03 AM
Iron Rock Offroad IRO 3.5" Suspension Kit Complete Lift Kits 26 04-20-2016 03:03 PM
Iron Rock Offroad IR-W4CPK Complete Lift Kits 11 05-29-2014 09:54 PM
Iron Rock Offroad 3.5" ZJ Spring Springs 5 11-25-2012 05:16 PM
