Go Back JeepForum.com > Reviews > Suspension > Track Bars > Currie Enterprises - Currie Johnny Joint Track Bar
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Currie Enterprises - Currie Johnny Joint Track Bar Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Track Bars Next Product
Rating:
Product Information
MSRP: $299.95
Average Price: $293.13
Manufacturer: Currie Enterprises
Recommended?
Yes: 7 / No: 0
Company Website: http://www.currieenterprises.com/
The all new and improved Johnny JointŪ trac bar for the TJ/XJ/LJ/MJ features an offset Johnny JointŪ rod end that puts the bar further forward providing more clearance between the diff and the trac bar. Other features include 1 1/4" x .250 wall 4130 chrome moly construction, a welded in gusset from the bar to the Johnny JointŪ, heavy duty adjustor end with urethane bushing and steel insert sleeve, and semi-gloss black powder coat finish. Some drilling is required for installation. The supplied frame bolt is a 5/8", and the supplied housing bolt is 7/16". Both of these holes must be drilled to size to accommodate the heavier duty hardware.
None
77midget
77midget's Reviews
04-26-2013, 09:17 AM
Price: $329.00
Pros: heavy duty and well constructed. JJ and heavy duty bolts.
Cons: $$. Also, shipping was a bit of a mess, but no fault of Savvy
Recommended? Yes
Comments: only had it in for a few weeks, but it killed my DW with a headshot. The install was fine, though had to remove other sterring components to drill out the frame mount. No worries, though, as I incorporated it into a steering gearbox replacement.
MVintherTJ
MVintherTJ's Reviews
03-18-2013, 09:53 PM
Price: $309.00
Pros: Very stout and beefy, lots of flex
Cons: None
Recommended? Yes
Comments: This track bar is the best of the best.
CWgauge
CWgauge's Reviews
03-14-2013, 11:32 PM
Price: $260.00
Pros: Beefy
Cons: None
Recommended? Yes
Comments: I would recommend this track bar.
boeingxtreme
boeingxtreme's Reviews
10-24-2012, 10:16 AM
Price: $280.00
Pros: Stout construction, Larger than Previous, Like how theres not a drop bracket
Cons: Had to remove drop pitman arm and rusted out bolts on axle from old track bar, nothing a grinder couldn't cut off.
Recommended? Yes
Comments: Awesome track bar, should have installed this a long time ago, had sloppy steering from a junky track bar and this fixed it. I drive 75 mph with one finger now! Straight as an arrow!
chopperkid2000
chopperkid2000's Reviews
03-04-2012, 04:39 PM
Price: $295.00
Pros: Well built
Cons: Have to drill both brakets
Recommended? Yes
Comments: Works good, clears diff fine
Zakman
A locked & armored Sport
Zakman's Reviews
11-21-2011, 07:04 AM
Price: $278.99
Pros: Dual JJs to eliminate binding in rear.
Cons: Bracket required. Will not work with other aftermarket brackets.
Recommended? Yes
Comments: CE-9120R dual rear JJ trackbar & CE9121 Bracket. Had to order the CE-9121 bracket as this product will not work with other brand brackets. Dual JJs eliminated binding due to axle rotation after SYE installation. The new style bends clear exhaust and gas tank at full bump and drop.
SaxManClay
SaxManClay's Reviews
07-26-2011, 12:01 PM
Price: $299.95
Pros: Large Johnny Joint side, huge and beefy
Cons: No Lasers
Recommended? Yes
Comments: Awesome track bar. Needed a new one after my lift, so I figured I'd go with this one. What can I say? Large 1/2" housing, and I only had to drill out two holes to make them bigger to accommodate for the track bar.
ThreadForumRepliesLast Post
Currie Rear adjustable uppers Control Arms 23 04-15-2013 08:33 AM
Currie Enterprises Anti-Rock Sway Bar, TJ Track Bars 15 11-28-2012 02:34 PM
currie 4" hd Springs 5 06-23-2012 02:12 AM
Currie Anti-Rock Sway Bar Springs 4 04-30-2012 09:37 PM
Currie Enterprises Johnny JointŪ AntiRockŪ suspension system kit Complete Lift Kits 10 02-19-2012 06:05 PM
