Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > TnT Customs 5.5" - 7.5" Y-link System
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
TnT Customs 5.5" - 7.5" Y-link System Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $2,000.00
Average Price: $2,221.88
Manufacturer: TnT Customs
Recommended?
Yes: 10 / No: 0
Y-Link Suspension System
5.5" Lift: $2079.95
7.5" Lift: $2279.95
T&T XD Bellypan
T&T Y-Linktm Radius Arms
T&T XD Drop Trac-Bar Mount
T&T XD Trac-Bar
T&T Universal Rear Shock Mounts
2" Front Bump-Stops
2" Pro-Comp Drop Pitman Arm
Rear 1.5" UBolt Eliminators
Rear 1.0" Boomerang Shackles
Pro-Comp Braided Brake Line Kit
5.5" R.E. Front Coil Springs
3.5" R.E. Rear Leaf Springs
Sway-bar Disco's
Y-Linktm Install Hardware
Y-Linktm Unibody Bracing System
Wrenches_00
Junior Member
Wrenches_00's Reviews
06-24-2011, 11:02 PM
Price: $5,600.00
Pros: Long arms are formed to go inside of frame.
Cons: None
Recommended? Yes
Comments: We picked up the completed Y-Link conversion June 13, so we haven't had time to really test it yet. TnT doesn't have an alignment rack and the TJ had a very pronounced pull to the right. Had to have it aligned locally. Rear axle was 1 degree to left causing the right pull. Jeep rolls much easier now. The installer used to short of bolt in the left front arm so the lock nut would not lock subsequently it fell off and the bolt backed out. Just poor workmanship nothing to do with the design of the system. Compared to a friends RE long arm this one is much more substantial. The bent front arms that go inside the frame give greater clearance then the straight arm types. Will take it to Chinaman's Gulch this weekend so I can compare it to when the TJ was stock.
escapeartist
escapeartist's Reviews
03-27-2010, 02:03 PM
Price: $2,500.00
Pros: well built, sturdy fabrication with good looking welds
Cons: See review
Recommended? Yes
Comments: drilled/ burned holes needed to be slightly enlarged to accept bolts supplied. TNT's directions don't allow for changes they have made in hardware sizes/product configuration and there is some figuring stuff out on your own, I did call them and was helped right away at one point. Still a great product and would buy it again. Mine came with a SYE and RE springs and components for the price also.
Rodimus
Rodimus's Reviews
05-06-2009, 09:59 PM
Price: $2,000.00
Pros: Love it! Flex like mad!
Cons: none
Recommended? Yes
Comments: This kit is awesome. It's very well built and it flexes like mad. Worth every penny!
DustinJ
DustinJ's Reviews
10-31-2008, 02:28 PM
Pros: very well built!!! great LCA's that are very out of the way of rocks.
Recommended? Yes
Comments: this kit is very sturdy and rides great i took it on the trail last weekend and did very very well never hit a control arm or anything!!
Wallace
Wallace's Reviews
05-27-2008, 04:29 AM
Recommended? Yes
Comments: Excellent, well thought out product. Very sturdy construction. Dual triangulated rear available, as well as diff trusses. Product ships unfinished.
Calvin9r
Come out and play.
Calvin9r's Reviews
05-10-2008, 02:53 AM
Price: $900.00
Recommended? Yes
Comments: Incredible system. All bolt in, nice for those of us who can't weld. The belly pan is worth it's weight in gold. I bought the y-link before there was lift included.
cousin eddie
cousin eddie's Reviews
04-24-2008, 01:24 PM
Price: $899.00
Recommended? Yes
Comments: I have the upgrade and pieced the rest together out of RE springs and Bilstien shaocks
prlasher
prlasher's Reviews
04-15-2008, 04:02 PM
Price: $1.00
Recommended? Yes
Comments: Coming Soon...
bmyohn
Youngin'
bmyohn's Reviews
12-01-2007, 07:20 PM
Price: $2,000.00
Pros: Stout Belly Pan, longarms, UBEs, good ride
Cons: difficult install, little pricey but worth every penny
Recommended? Yes
Comments: I have been installing this kit for the past week or so. And i have been very impressed with the amount of detail that goes into this kit. it is strong and will withstand anything u bring it. very good instructions and an extremely complete kit. completely adjustable LCAs, UCA, and trac bar. very good flex, in fact i will probably need limiting straps to keep it from FULL flex
highly recommended, just check the XJ Tech Boards
ThreadForumRepliesLast Post
4 Wheel Customs TJ/LJ 2.25 Inch Complete Budget Boost Kit w/(4)Skyjacker Hydro Shocks Complete Lift Kits 6 09-08-2011 03:28 AM
Front Sway Bar Link Steering Stabilizers 1 08-16-2009 07:02 PM
RE 5.5 LA Tri-Link Complete Lift Kits 1 07-24-2009 05:40 AM
Clayton Offroad 5.5" double tri-4-link long arm stretch kit Complete Lift Kits 1 05-21-2009 05:32 PM
4 Wheel Customs XJ 2.25 Inch Complete Budget Boost Kit Complete Lift Kits 1 10-29-2008 09:56 AM
Glock Forum
