Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Teraflex 2" spacers
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Teraflex 2" spacers Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Teraflex 2" spacers
Rating:
Product Information
MSRP: $120.00
Average Price: $155.95
Manufacturer: Teraflex
Recommended?
Yes: 9 / No: 0
2" spacers
OffRoadRyder
Junior Member
OffRoadRyder's Reviews
12-01-2011, 09:28 AM
Price: $130.00
Pros: Easy, inexpensive, looks good. Makes 33" tires look like they belong. No rubbing if the tires are fairly narrow.
Cons: Installation instructions are horrible. www.jeepfan.com has much better, detailed instructions.
Recommended? Yes
Comments: I have never installed anything like this on any vehicle but I am quite mechanically inclined and I have plenty of tools.
I installed this leveling kit in just over two hours with basic hand tools, a floor jack and two jack stands. It changes the look and fell of the stock JKU dramatically.
joeyc
JK Guru
joeyc's Reviews
10-03-2011, 04:15 PM
Price: $70.00
Pros: Good product retains stock ride.
Cons: none so far
Recommended? Yes
Comments: Got this spacer lift from someone off another forum for a steal so i picked it up. Installed in a hour and 30 minutes nice and easy!
Wainzilla
Wainzilla's Reviews
07-06-2011, 07:01 PM
Price: $129.00
Pros: Easy to install
Cons: Basic
Recommended? Yes
Comments: Good lift for tire clearance. Basic lift for trail use. I had to get BPE's for the stock shocks.
Beta144
Beta144's Reviews
11-09-2010, 08:08 PM
Price: $160.00
Pros: Cheap price for a little extra height
Cons: Had to adjust tail pipe to keep from rattling against the new extended shackle
Recommended? Yes
Comments: No detrimental effects on ride quality or handling.
Rubigirl
Rubigirl's Reviews
10-21-2010, 06:59 AM
Price: $300.00
Pros: Easy to install, low price
Cons: instructions all but useless
Recommended? Yes
Comments: The Teraflex 2 inch spacers with TeraFlex gas shocks provide a nice ride with no vibrations on a 2006 TJ Rubicon.
Snow4Lif3
Snow4Lif3's Reviews
05-16-2010, 06:38 PM
Price: $300.00
Pros: Easy to install/remove
Cons: None yet
Recommended? Yes
Comments: Good quality product. The front spacers are well painted and I like the material of the rear one. The only thing I did not like is the installation instructions... They are not very well detailed/illustrated. I did not follow the instructions for the front spacer. You don't need to fight to remove the lower arm... you just need to remove the upper ball joint and extend the wheel until the shaft come out... remove the brake and you'll can insert the shock (with the spacer fixed) relatively easily ! Don't forget to realing the wheel after.
xantasm
Cav scout
xantasm's Reviews
06-11-2009, 02:40 PM
Price: $134.52
Pros: Coil spring spacers are good qaulity, bumpstop extenders are aluminum discs
Cons: Bumpstop extender bolts are not long enough for use on the rear of a TJ/LJ
Recommended? Yes
Comments: Overall the quality of this kit is pretty good. It comes with black coil spring spacers with Teraflex logo in white, 4 aluminum bump stop extenders, and 4 bolts for use with the bumpstop extenders. The idea of the extenders is to remove your OEM bumpstop cups and place the aluminum extenders in between them and the frame mounts using the provided longer bolts. The bolt length is the same for both front and rear however the bolts needed for the rear have to be longer as the ones provided will only barely thread. This is not necessarily a serious issue but it is however a detractor to the value of the kit in my opinion. I have usually been very pleased with Teraflex products, this time I am a bit disapointed so Im rating this kit average as I have used coil spacer kits from other companies which came with everything needed and it all fit correctly for the same price if not less.
bnasty
bnasty's Reviews
12-26-2008, 09:20 PM
Teraflex 2" spacers
Price: $120.00
Recommended? Yes
Comments: Fairly easy to install: took me and a buddy 3 hours to complete, neither of us having any knowledge of suspension systems- So far no problems!- Most bang for your buck
mudslingernick
mudslingernick's Reviews
11-18-2008, 12:15 PM
Teraflex 2" spacers
Price: $60.00
Recommended? Yes
Comments: easy to install i am running 33" with this lift and the clear just fine. no rubbing
ThreadForumRepliesLast Post
Teraflex 3ST Complete Lift Kits 10 01-21-2010 01:42 PM
Teraflex 2.5" BB JK Complete Lift Kits 12 11-05-2009 02:36 AM
Teraflex Teraflex 4" WJ Coils Springs 2 07-30-2009 03:00 AM
Teraflex 5" LCG Pro Complete Lift Kits 2 01-31-2009 08:25 PM
teraflex 2" BB WJ Complete Lift Kits 1 11-07-2008 01:37 PM
Glock Forum
