Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Teraflex 2.5" BB JK
Teraflex 2.5" BB JK Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Teraflex 2.5" BB JK
Rating:
Product Information
MSRP: $635.00
Average Price: $347.04
Manufacturer: Teraflex
Recommended?
Yes: 23 / No: 1
2.5" JK BB
Page 1 of 2 1 2 > Last »
phantomwood
Newbie
phantomwood's Reviews
12-22-2011, 09:19 PM
Price: $370.00
Pros: good product, very good reputation
Cons: none
Recommended? Yes
Comments: Made a lot of reseach, and its the best bang for buck
greenbudz
greenbudz's Reviews
12-02-2011, 02:43 PM
Price: $800.00
Pros: teraflex 2.5 shock a coil kit
Cons: nothing
Recommended? Yes
Comments: great pruduct got the bilstein shocks. rides like stock
Vladimer
Vladimer's Reviews
07-22-2011, 04:54 PM
Price: $400.00
Pros: Affordable lift and ride quality still feels the same.
Cons: Reuses stock rear swaybar links. Will also rub without spacers.
Recommended? Yes
Comments: Reuses the stock swaybar links from the rear in the front. (advantage is it keeps the cost of the kit down) One of the swaybar links broke upon removal and had to buy a new one so I could use it in the front. Instructions included in kit did not mention anything about reusing the swaybar links in the rear and the stock fronts are too short and will invert.
Vladimer
Vladimer's Reviews
07-22-2011, 04:52 PM
Price: $400.00
Pros: Affordable and ride quality still feels the same.
Cons: It reuses the rear sway bar links in the front, mine broke upon removal so had to purchase new ones. Instructions included in kit did not mention anything about reusing the swaybar links in the rear and the stock fronts are too short and will invert.
Recommended? Yes
Comments: Instructions included in kit did not mention anything about reusing the swaybar links in the rear and the stock fronts are too short and will invert.
R-U-B-I-C-O-N
R-U-B-I-C-O-N's Reviews
05-23-2011, 07:55 AM
Price: $330.00
Pros: Very easy install. Looks great, big enough to throw some bigger tires on.
Cons: The sway bar connect rubs the tire so Wheel spacers are a MUST
Recommended? Yes
Comments: Great Product. Not too much of a PITA to install. Looks great for anyone who plans on just putting bigger tires on. Only problem i ran into is that the sway bar connector rubs on the rear tires. Without wheel spacers, its a sitting brick. As mine is now while I wait for spacers.
narleycarley
Junior Member
narleycarley's Reviews
05-01-2011, 11:01 AM
Price: $337.00
Pros: Good lift, levels jeep out, not hard to install
Cons: Havn't seen any yet
Recommended? Yes
Comments: Got the BB with shock extensions. Able to use factory springs and factory shocks to keep same ride, wasn't hard to install. Installed by myself with jack and jack stands. Instructions did miss a couple small items, but no biggie, if you are competent enough to do a tune-up you can do this in about half a day.
OregonVette
OregonVette's Reviews
02-04-2011, 09:50 AM
Price: $249.00
Pros: Great
Cons: Instructions
Recommended? Yes
Comments: Great lift, I'd recommend it as a complete simple & effective lift for all JKs
CHIPMAKER
CHIPMAKER's Reviews
12-06-2010, 10:45 PM
Price: $450.00
Pros: Everything you need is in the kit
Cons: crappy instructions
Recommended? Yes
Comments: TF 2.5 coil lift w/ shock extensions.
No death wobble or shimmy
No lights on dash
No drive shaft clearance issue
No steering adj.
No alignment needed
Rides as good as stock
WindMeUp
WindMeUp's Reviews
11-08-2010, 08:38 PM
Price: $329.00
Pros: Easy to Install, Cheap
Cons: Sags with added weight (using low # stock springs)
Recommended? Yes
Comments: I purchased this kit with shock extensions because I have Rubicon shocks. I opted for this because it is cheap, and I don't plan on adding extra weight with bumpers until next Summer, when I will be swapping to a better lift as well. This is a great starter lift to run 35" tires, I'm very glad I purchased this lift as a temporary solution for tires.
WindMeUp
WindMeUp's Reviews
11-08-2010, 08:35 PM
Price: $329.00
Cons: Sags with added weight when using stock springs
Recommended? Yes
Comments: I bought this with shock extensions due to the price. It was easy to install, came complete with everything I needed for an easy lift to run 35" tires. Using low #'d factory springs it will sag with added weight, but it is a great lift for the economical price.
markxj2k
markxj2k's Reviews
10-03-2010, 09:53 PM
Price: $320.00
Pros: An extra 2.5" of height is never a bad thing
Cons: Need wheel spacers or new wheels with 4.5" backspacing.
Recommended? Yes
Comments: I kept my OEM Rubi shocks and springs, just added the spacers and shock extension brackets. The kit went on fine, but the rear sway bar links rub a bit on the inside of the stock Moab wheels. I added 1.5" spacers and solved the problem with the stock wheels, and my off-road wheels have 4.5" backspacing so that's no problem.
Wolf359
WOLF359
Wolf359's Reviews
06-13-2010, 11:08 PM
Price: $300.00
Pros: Easy install. Came with relocation hardware for brake lines and bump stops.
Cons: Blew out spacer... not for moderate off road use.
Recommended? No
Comments: Ended up getting a suspension lift. Should have gotten the suspension lift in the first place.
ratcals
ratcals's Reviews
11-05-2009, 02:36 AM
Price: $200.00
Pros: Easy to install.
Cons: The directions were lacking. Recommend going to Project JK and downloading their very concise directions.
Recommended? Yes
Comments: Mine yielded over 3" all around. Very easy to do with minimal experience.
charlope
charlope's Reviews
10-28-2009, 03:02 PM
Price: $1.00
Pros: 1
Cons: 1
Recommended? Yes
Comments: .
shockwave562
shockwave562's Reviews
06-02-2009, 03:33 PM
Price: $300.00
Pros: allows for 35" tires, easy to install
Cons: not really functional off-road, inexpensive temporary solution
Recommended? Yes
Comments: This will suffice for now. I really wanted to get 35s under the JK as soon as possible. This is a cheap solution until I can get the lift kit I really want next year. No sense in buying a cheap suspension system and then buying a whole new one down the road.
warCryr
warCryr's Reviews
03-18-2009, 06:15 PM
Teraflex 2.5" BB JK
Price: $320.00
Recommended? Yes
Comments: Good if a lease and don't want to overdo it.
I'm not very mechanically experienced.. it took me and a friend 10 hours to install the lift. I recommend reading through ALL of the instructions before starting.
Solid construction and seems well thought out. I had to do a little bending on the trackbar relocation bracket.
My only real complaint is the notice on the Teraflex box saying "IF PLANNING TO USE STOCK WHEELS, WHEEL SPACERS MUST BE PURCHASED WITH THIS KIT."
But the wheel spacers are soo expensive, I decided to just buy after market rims with 4.5 in. backspacing. I've been driving around on stock wheels waiting for the new wheels to arrive and I haven't had any problems actually. I'm not going off-road until I get the new wheels however.
08rubinewb
08rubinewb's Reviews
03-12-2009, 02:54 PM
Teraflex 2.5" BB JK
Price: $259.95
Recommended? Yes
Comments: That's with shipping and the shock extensions! Went on easy and so far so good.
Laughingstok
Laughingstok's Reviews
02-06-2009, 09:44 PM
Teraflex 2.5" BB JK
Price: $417.00
Recommended? Yes
Comments: I have the coil lift, not the BB. The coil lift is excellent, flexes well and rides like stock on the rubicon shocks. Very easy to install.
idrivejeep
idrivejeep's Reviews
01-13-2009, 03:59 PM
Teraflex 2.5" BB JK
Price: $360.00
Recommended? Yes
Comments: Real simple to install by myself in one day. Exactly what I wanted for my daily driver.
harrisart29
harrisart29's Reviews
12-09-2008, 05:04 PM
Teraflex 2.5" BB JK
Price: $635.00
Recommended? Yes
Comments: I actually have the teraflex 2.5" coil spring lift. The Jeep is actually still in the shop getting them put on. So I can't really write a review yet, but the guy installing them says they should be pretty good and is pretty impressed with them. So just like the tires, we'll have to play the wait and see card on these, too.
ThreadForumRepliesLast Post
Teraflex 3ST Complete Lift Kits 10 01-21-2010 01:42 PM
Teraflex Teraflex 4" WJ Coils Springs 2 07-30-2009 03:00 AM
Teraflex 5" LCG Pro Complete Lift Kits 2 01-31-2009 08:25 PM
teraflex 2" BB WJ Complete Lift Kits 1 11-07-2008 01:37 PM
teraflex st4 Complete Lift Kits 4 08-06-2008 02:33 AM
Glock Forum
