Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Skyjacker 2" Budget Boost
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Skyjacker 2" Budget Boost Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $300.00
Average Price: $199.87
Manufacturer: Skyjacker
Recommended?
Yes: 52 / No: 5
The 2" Spacer Lift Kits for '97-'06 Wranglers include front and rear urethane coil spring spacers, bump stop extensions and shocks. Allows up to 32"x11.5" tires if wheels have proper backspacing.
Image: http://www.quadratec.com/Assets/Images/23559/23559-md.jpg
Page 1 of 3 1 2 3 > Last »
05midnite
05midnite's Reviews
10-23-2011, 12:41 PM
Price: $1.00
Pros: 2 inches higher is nice
Cons: shocks are white
Recommended? Yes
Comments: performs great and being that little bit higher is nice. only complaint is that the shocks dont come in any other color than white.
Jeepnation2011
Jeepnation2011's Reviews
07-09-2011, 08:23 PM
Price: $250.00
Pros: good for starter kit. ready to upgrade
Cons: shocks are not the best, but for the price there not bad
Recommended? Yes
Comments: Good for someone on a budget. still running it with my 33"s but ready for upgrade. Not to bad of a kit though. It did come with the bracket for the 4x4 lever and is a must. had viberation in drive shaft and had to buy transfercase drop, which took care of it.
pkwon5
pkwon5's Reviews
06-01-2011, 12:55 AM
Price: $250.00
Pros: Easy to install and no problems what so ever.
Cons: Bad instructions but if you know what ur doing its easy.
Recommended? Yes
Comments: Its cheap and a great starter lift to get bigger tires. Get a spring compressor because it helps a lot. Im running 32x12.5 pro comp mud tires and its still great. Installed in 2007
Wrangler30
Newbie
Wrangler30's Reviews
05-20-2011, 05:24 AM
Price: $310.00
Pros: Great lift for the money.
Cons: If any cons, the spacers are bright red and you see them in the wheel wells, but that is it. no product issues.
Recommended? Yes
Comments: This lift works for me. The Jeep is my DD and I may throw in a little off road here and there, so it helped improve the stance and let me slide 31s on with no issues.
I would recommend to anyone.
ShogunTJ04
ShogunTJ04's Reviews
04-28-2011, 11:11 PM
Price: $265.00
Pros: Easy install, Good shocks, great ride quality
Cons: Urethane spacers aren't really 2.00 inches, Actual height is 1.75in. Urethane bushings are really hard to insert in the shocks.
Recommended? Yes
Comments: I got this lift just so I could fit some cheapo tires I got from a friend. The kit installs easily in a few hours with hand tools and does its job. I can fit 33's without any rubbing on road, minimal off.
The shocks that came with it were Hydro 7000's and they seem to ride a lot better than the stock shocks, control and roadfeel is much smoother. I'd probably compare the ride quality to a Lincoln Towncar, floaty but not too bouncy. I'd recommend them to anyone who has worn out shocks or a stiff ride.
EndGame
EndGame's Reviews
04-16-2011, 09:23 AM
Price: $200.00
Pros: Red Awesome Instructions Ease of install
Cons: none yet
Recommended? Yes
Comments: An awesome BB.. makes my WJ sit at a height it should be, without going higher and having to purchase more upgrades.
gtnutz
gtnutz's Reviews
03-09-2011, 09:31 PM
Price: $300.00
Pros: cheap
Cons: its not a 4" lift
Recommended? Yes
Comments:
For the money and for the trails I run theres really nothing bad to say.
JeepTJMike
JeepTJMike's Reviews
03-04-2011, 03:43 PM
Price: $248.99
Pros: Went with Nitro Shocks
Cons: Garbage Instructions
Recommended? Yes
Comments: Good stance. Download the Superlift instructions for install. Good kit for the price
rrmckinney
DirtyCountryMan
rrmckinney's Reviews
02-01-2011, 02:13 PM
Price: $200.00
Pros: Pro's are its a good suspention lift and I have been happy with it so far
Cons: Can't tell as of yet
Recommended? Yes
Comments: I have gotten a 2" skyjacker suspention lift! I do not have any bad things to say about it and hope I don't.
RDaniel2405
*lllll*
RDaniel2405's Reviews
12-27-2010, 11:56 AM
Price: $1.00
Pros: nice easy set up. easy install
Cons: not big enough.
Recommended? Yes
Comments: I have installed these before for other people, but mine was on the jeep when i bought it.
Its a nice setup for weekend off roading with some 32's but a bit too small for me. I want a good 4'' short arm lift kit for my jeep.
torque
torque's Reviews
12-27-2010, 07:43 AM
Price: $0.01
Pros: looks
Cons: ?
Recommended? No
Comments: PO had a small skyjacker lift on the jeep when I got it, nothing too big as all the factory brake lines and things are still there. I am not sure that it was actually 2" or not but it is probably the smallest thing you can get with the skyjacker name on it.
tearlenb
tearlenb's Reviews
10-05-2010, 10:47 AM
Price: $240.00
Pros: cheap lift
Cons: not as easily installed as one would imagine.
Recommended? Yes
Comments: This was a great cheap lift. The only difficulty was in trying to add the spacers without a coil compressor. Had to drop the whole axle to get the last one on.
slamin04
slamin04's Reviews
09-24-2010, 11:14 PM
Price: $267.00
Pros: great for the beginner
Cons: none
Recommended? Yes
Comments: i love the kit i ran a 33 12.5 for a while with very little rubbing
Emtpbill322
Emtpbill322's Reviews
09-18-2010, 02:08 PM
Price: $241.00
Pros: Mechanic took 3 hours to install.
Cons: I didn't have my jeep for 3 hours.
Recommended? Yes
Comments: Came with coil spacers and Hydro shocks from skyjacker. The Shocks make the ride stiffer than stock, but not unbearable. So far i love the size of the lift i got. Not too much. But enough for when i have the bank to put 33's on.
jpin321
jpin321's Reviews
05-24-2010, 06:52 PM
Price: $200.00
Pros: Nice quick lift.
Cons: As usual installation difficulties.
Recommended? Yes
Comments: Good product installation was fairly easy. Do it one corner at a time and have some help. The bump stops are a huge pain to get back in. Put some bearing grease on em and they popped right back in.
Warning you will need to buy a track-bar relocation bracket or and adjustable track-bar, trust me after you price it you will buy the bracket. My jeep was dog tracking about an inch and a half.
Also I had some drive-line vibrations after the lift. From what I've heard not everyone experiences this.
I purchased to originally with the nitro shocks, wow those things are strong. So stiff I had trouble putting them on, and it took to people to get the front ones pulled out of the towers. Traded them for some hydros rides slightly stiffer than stock but feels good to me.
GTM
GTM's Reviews
02-23-2010, 02:58 PM
Price: $229.00
Pros: easy
Cons: none
Recommended? Yes
Comments: It's really a Redi Lift not listed here. 2 in front 1 inch back
94xj4x4
94xj4x4's Reviews
02-07-2010, 10:34 PM
Price: $60.00
Pros: looks better than stock
Cons: to low for me
Recommended? Yes
Comments: ....rr.rrr.
TYLER_USCG
TYLER_USCG's Reviews
12-23-2009, 07:28 PM
Price: $200.00
Pros: great ride
Cons: none yet
Recommended? Yes
Comments: easy to instal looks clean
TraumaMonkey
TraumaMonkey's Reviews
12-15-2009, 01:47 PM
Price: $1.00
Pros: already installed
Cons: stiffer ride + vibes
Recommended? No
Comments: Came on my used TJ. Plan on removing in the future for a 3" lift sans spacers.
2THEXTRM
2THEXTRM's Reviews
12-14-2009, 02:47 AM
Price: $250.00
Pros: Raises Jeep noticeably for more height to fit larger tires.
Cons: Shocks with kit suck
Recommended? Yes
Comments: Sky Jacker Hydro Shocks road like a lumber wagon so I tossed them and upgraded to MX-6's.
ThreadForumRepliesLast Post
4 Wheel Customs TJ/LJ 2.25 Inch Complete Budget Boost Kit w/(4)Skyjacker Hydro Shocks Complete Lift Kits 6 09-08-2011 03:28 AM
Rubicon Express Budget boost Complete Lift Kits 85 09-24-2010 11:29 AM
Rough Country 2.5" Budget Boost Complete Lift Kits 13 06-23-2010 08:39 AM
Teraflex 2" Budget Boost WJ Complete Lift Kits 1 10-31-2009 09:24 PM
Rusty's OffRoad 2" Budget Boost Complete Lift Kits 8 06-04-2009 05:31 PM
Glock Forum
