The 2.5" Lift Kits for '97-'02 Wranglers include extended control arms, shocks, coil springs, transfer case lowering kit & bump stop spacers. Standard kits can be purchased with either Hydro or Nitro Shocks. Allow fitment of 32"x11.5" Tires.
Comments: This product was very tedious to install but once I got it on it has been a blast and very reliable. Besides the fact that it took my freind and I a total of 6 hours to install it was rediculous but well worth the time.
Great starter kit for someone looking to lift their Jeep with a little more than a BL.
Cons
After 6 years the control arms have worn out and I had to replace the shocks after about 3 years.
Recommended
yes
Comments: This kit is an excellent starter kit for someone looking for a little lift that does not want to do a BL. I got mine about 6 years ago and It's held up pretty well until recently. The control arms are starting to wear out and I had to replace the shocks that came with the kit after about 4 years.
I would definitely recommend this to someone looking for something to build on or if the Jeep is your DD. It's relatively inexpensive and you can run 33" tires with it without any rubbing issues. It's not bad for mild off-roading and it gives you a little more clearance.
I recommend buying an adjustable front trac bar and quick disconnects with this as well because it does set your wheels a little off center after installation and the stock disconnects will disconnect a lot.
not top of the line, but for my wants it was perfect
Recommended
yes
Comments: Installed this lift kit with 3 friends. Only one had experience in lifts and it took us 7 hours. Great learning experience and everything seemed easy
Drives very nicely, fits 35's. Ive had it for almost 2 years and havent had a problem
Cons
Little bit of front sag still but nothing else i can tell.
Recommended
yes
Comments: Its a very affordable lift that will fit 35's and looks nice. The only thing i dont like it that it still has a little bit of front sag, but that maybe from the plow frame. I have a BOSS plow that my dad put on for a back up if his on his TJ freezes. Besides that it has been great. I think my dad paid 700 dollars for it and to be installed at Jeff Daniels.
Comments: Nice kit for the price. Wish I would of got 4" kit. All in all a nice lift kit.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
