Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Rusty's OffRoad 2" Budget Boost
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Rusty's OffRoad 2" Budget Boost Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $300.00
Average Price: $191.29
Manufacturer: Rusty's OffRoad
Recommended?
Yes: 12 / No: 2
ZJ Grand Cherokee Budget Kit (includes shocks)
4 Coils Spacers, 4 Rusty's Performance Shocks. A great way to get your feet wet. If you decide to go bigger later, you can still use the coil spacers!
frenchg-c98
frenchg-c98's Reviews
01-23-2012, 10:47 AM
Price: $120.00
Pros: Inexpensive, great starting point.
Cons: Its still just poly spacers.
Recommended? Yes
Comments: Great way to start and get your feet wet. Simple install (took me 3 hours).
You dont need spring compressors if you disconnect sway bar linkages and shocks.
hafastjank
hafastjank's Reviews
04-25-2011, 10:33 PM
Price: $249.00
Pros: Cheap way to get some extra tire clearance. Installs in an afternoon with the right tools.
Cons: Cheap hardware. You'll probly be running to the hardware store in an effort to get rid of the clunking that shows up down the road.
Recommended? Yes
Comments: It's a cheap and really quick way to clear 245/75's with no rubbing. 32's will need some trimming. And you will be running to the hardware store in the future once the clunking appears and wont go away. They include some cheap hardware that isn't really the right dimensions, so 2 washers on either side of the rear upper shock mounts solved my issues for the most part. If your looking for a good, permanent lift. Look elsewhere.
overlandchris
overlandchris's Reviews
04-17-2011, 09:01 PM
Price: $120.00
Pros: Perfectly fitting spacers, easy to install
Cons: N/A
Recommended? Yes
Comments: The kit is very simple and easy to install. 4 spacers come in the kit, two front, and two rear. It can easily be done in two hours if you read the instructions completely first.
unlimited94
unlimited94's Reviews
02-01-2011, 07:25 PM
Price: $230.00
Pros: Fits 30x9.50's perfect.
Cons: Fits 31x10.50's, but with a little rub up front.
Recommended? Yes
Comments: Rides like a brick. But if you want a good cheap lift to fit some bigger meats, an excellent choice.
criket
criket's Reviews
08-17-2010, 09:22 PM
Price: $150.00
Pros: Easy install. No major modifications.
Cons: Seems that the rear is a bit lower than the front...but it could be my eye sight.
Recommended? Yes
Comments: Great Price. No problems as of yet. It's been on for a couple of weeks and it actually solved a weird clunk I had in front.
BFerrell
BFerrell's Reviews
04-05-2010, 12:17 PM
Price: $100.00
Pros: Simple and affordable
Cons: None
Recommended? Yes
Comments: I purchased this about 2 weeks after my latest Jeep buy. I was looking for something simple that would get the stock height up enough for 30"s with no rub. The install is straight-forward. It took about 5 hours with me working alone. A month later a friend wanted the same setup on his Cherokee and with his help it only took 3 hours. Driving characteristics are very similar to stock and the rear AAL still offers good (not great, but good; especially for the price) flex off road. I've had no rubbing issues on fenders or LCA's at full stuff. The rear has yet to settle, so I may finish this review when it does but for now I am happy and recommend this set up for those looking for a bit more clearance out of their XJ.
JohnnyCobra
JohnnyCobra's Reviews
06-04-2009, 05:31 PM
Price: $199.00
Pros: Decent instructions, works as advertised
Cons: it's a budget boost
Recommended? Yes
Comments: Shipping was complete and quick.
Instructions were good.
I actually needed a "strut compressor", not a "spring compressor" to get the fronts on, but the rears went on without any special tools.
I got the kit without the steering stabilizer upgrade, or the body lift.
I am still using the stock 30X9.5x15 goodyear wranglers on 15"X8" Ravines - need to get some 31X10.50X15 or 32X11.5X15 to make it look really right. Noticeable lift, the rear is a little "bouncier" on the highway than stock - which after 38k miles was feeling a little mushy.
I think the instructions should be clearer on the type of spring compressor and if the spring is to come out the "shock side" or the bumper side, no explanation as to why the pucks have a "flat side" - I just put the puck in with the flat facing the engine, and should definitively state if you need additional mods (Alignment, bumpstops, etc) but that's what jeepforum is for, right?
I'd buy this kit again - only have ~200 miles on it. Time will tell.
thething
thething's Reviews
03-27-2009, 06:11 PM
Price: $100.00
Recommended? Yes
Comments: I like them. Would recommend to anyone. but now I think that I want to go bigger
BradyAds.com
BradyAds.com's Reviews
03-06-2009, 10:07 AM
Price: $300.00
Recommended? Yes
Comments: Easy to install with a friend and a great ride. This install can be seen under my signature link and then to my homepage.
tjkj0602
tjkj0602's Reviews
10-28-2008, 10:52 PM
Price: $200.00
Recommended? No
Comments: garbage I do not like it at all the highway ride is ok but bumps hit the stops all the time
100kwj
100kwj's Reviews
07-31-2008, 05:39 PM
Price: $270.00
Recommended? No
Comments: The shock bushings are awful. Every one has fallen apart with normal street driving.
jopolly3
jopolly3's Reviews
05-27-2008, 01:45 PM
Price: $220.00
Recommended? Yes
Comments: A very subtle lift that you can install in your driveway in a few hours; the WJ should have left the factory looking like this...
thecommander
thecommander's Reviews
05-24-2008, 10:00 AM
Price: $220.00
Recommended? Yes
Comments: great customer service. easy to install, no problems with it yet. i need to get a real suspension since the winch and bumper are pulling the front end down.
Ds4x4
Ds4x4's Reviews
04-09-2008, 04:01 PM
Price: $200.00
Recommended? Yes
Comments: Great for the price but not a fan of hydro shocks..
ThreadForumRepliesLast Post
Skyjacker 2" Budget Boost Complete Lift Kits 43 09-24-2010 11:14 PM
Rough Country 2.5" Budget Boost Complete Lift Kits 13 06-23-2010 08:39 AM
Teraflex 2" Budget Boost WJ Complete Lift Kits 1 10-31-2009 09:24 PM
Rusty's Offroad Rusty's Preformance Shocks Shocks 2 05-27-2009 10:26 AM
Rusty's Offroad 2" Shackle Budget Boost Complete Lift Kits 3 09-28-2008 08:25 AM
Glock Forum
