Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Rubicon Express RE72X5 5.5" Extreme Duty Long Arm TJ
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGSALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30
Rubicon Express RE72X5 5.5" Extreme Duty Long Arm TJ Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $12,500.00
Average Price: $3,342.90
Manufacturer: Rubicon Express
Recommended?
Yes: 37 / No: 1
The Rubicon 5.5" Extreme Duty Long Arm kit is the most advanced, best performing suspension system available for the TJ. Designed as a complete replacement suspension, the Extreme Duty kit maintains proper control arm and steering geometry for lifted TJ’s, improving the stability of the vehicle on and off road. Drivers will discover marked improvements in their vehicle’s road manners, returning a nearly stock ride to their modified Jeep™ and unmatched performance where the pavement ends
Page 1 of 2 1 2 > Last »
camera-man
camera-man's Reviews
03-13-2011, 03:24 PM
Price: $13,900.00
Pros: everything
Cons: nothing
Recommended? Yes
Comments: this kit is built well and has the geometry you will want to max your flex but yet offer a nice soft ride.
larubie
larubie's Reviews
10-17-2010, 08:55 PM
Price: $1,800.00
Pros: NONE
Cons: Not enough space for them. This is a first class kit.
Recommended? Yes
Comments: You get what you pay for and this kit is no exception to the rule. RE states that you get 5.5" but after the install and 35" tires I was almost 10" higher and that is starting with a Rubicon suspension first (factory). The ride is great, the control is very good and in all this is the best kit out there (IMO that is). Spend the $$$ and get this kit.
JPIN4LYF
JPIN4LYF's Reviews
10-07-2010, 01:36 AM
Price: $3,200.00
Pros: Very strong, quiet, great flex and great pavement personality.
Cons: Break rear upper control arm bolts. tore control arm brackets off the axle tubes.
Recommended? Yes
Comments: I've been running the 5.5 on my TJ for 7 years. I run fabtech springs as the RE springs setteled in the rear pretty bad after 4 years. I have a tereflex High-steer kit in the front and it drives like a camry. haha
I would reccommend this kit to any TJ owner. It is also very great for a "bigger" platform.
maaghimself
maaghimself's Reviews
08-23-2010, 09:10 AM
Price: $2,800.00
Pros: Fairly Simple Installation Nice Skid Design Great flex
Cons: None so far.
Recommended? Yes
Comments: Very beefy kit. From the skid plate to the control arms, its heavy duty all around. It bolts into the frame in like 12 spots, so its not coming off. The skid isn't much of a belly up type deal, but it's real smooth, and it seems like it rose my driveline a little bit. Great ride on the road compared to my old 4" short arm kit.
autowelder
autowelder's Reviews
02-20-2010, 09:38 PM
Price: $2,500.00
Pros: Very flexible and great height. smooth ride. Parts Mike sales (the handler steering system that completes the lift Right.)
Cons: toe in and out when suspension travels up and down,under steer and over steer ( no steering system with kit or shocks, except drop pit man arm.)
Recommended? Yes
Comments: Very good lift kit, had every thing you needed. Doesn't drive bad, but needed the high steer, steering system installed to correct the under and over steer, do to the stock system design you have this problem even though it's not huge but noticeable when the big tires go on.
Thexonexkid
Thexonexkid's Reviews
01-28-2010, 05:39 PM
Price: $2,500.00
Pros: Good Travel, good articulation.
Cons: none
Recommended? Yes
Comments: http://photos-c.ak.fbcdn.net/hphotos-ak-snc3/hs140.snc3/18779_1138182253094_1183500848_30666072_283307_n.j pg
Amazing travel, I have an addition 1.25'' BL and tube fenders on 35s and can still stuff my tires. The best non-custom lift kit on the market for sure. O and triangulated suspension allows amaaaazing articulation.
oif03vet
oif03vet's Reviews
01-05-2010, 06:46 PM
Price: $2,500.00
Pros: Great Travel, better than stock ride characteristics, great fit and finish. Durable
Cons: Install was a little more time consuming than I was expecting.
Recommended? Yes
Comments: I bought the kit because even though it was expensive, I was told by many friends that it is the best kit around, well tested and from a dependable, stable company. The install took me a while because I only worked on it a couple hours a day and could never find my tools or had to go to the store to get tools I didnt have. Being my first Jeep I wanted to take my time on it so I could understand the mechanics behind everything. My fist outing in the Jeep after the lift was installed was to John Bull Trail in Big Bear, CA which I have heard is one of if not the most difficult trail there. I did it with no problems. Even with the extra height, which is over the 5.5 inches they advertise by at least an inch, I had no major concerns of flipping even on my last trip to Glamis, CA. All and all it is a great suspension and I highly recommend it.
Edilson Fabre
Edilson Fabre's Reviews
10-12-2009, 08:30 AM
Price: $3,000.00
Pros: Better driving than stock suspension
Cons: Nothing until now
Recommended? Yes
Comments: Detailed instructions make the installation easier.
No big deal with the welding, only relocating rear shocks brackets, and front track bar.
Very good approach in the erosions.
I am very satisfied.
nelsonlandworks
nelsonlandworks's Reviews
07-05-2009, 09:01 PM
Price: $2,500.00
Pros: Great Flex
Cons: Stock wheelbase
Recommended? No
Comments: I recommend it, but would rather have built my own lift at this point!
jetter
jetter's Reviews
03-25-2009, 11:40 AM
Price: $2,300.00
Recommended? Yes
Comments: Install was not difficult at all. The hardest part was cutting the factory control-arm brackets off the frame with a grinder and cut-off wheel.
The only improvement they could make to the kit would be shortening the threaded section of the front upper control-arms. They bottomed out before getting the castor set correctly.
The overall ride and handling improved dramatically over the previous RE 3.5" standard lift. Ride is just a little stiffer than a stock jeep. Get the castor set correctly and it handles like a car. The flex is incredible to say the least.
gatornut30
gatornut30's Reviews
03-01-2009, 08:23 AM
Recommended? Yes
Comments: Came with the jeep and will not be able to try it out till I get to Germany in May.
jjeepnewb101
jjeepnewb101's Reviews
11-28-2008, 05:32 PM
Recommended? Yes
Comments: lol alright this seems to be the kit i want to purchace but like my name says im a newb when it comes to jeeps...and as i was looking at the kit it gave me the option of diffrent shocks...i have no idea what any of them are and was hopeing some one could tell me the best choice?
TJ/LJ 5.5" BILSTEIN LONG ARM
TJ/LJ 3.5"-5.5" DT3000 SHOCK
TJ/LJ 3.5"-5.5" OME SHOCK KIT
TJ/LJ 5.5"-7.5" RUBICON MONO
TJ/LJ 5.5"-7.5" RUBICON TWIN
snowcrash
snowcrash's Reviews
11-12-2008, 05:32 PM
Price: $2,500.00
Recommended? Yes
Comments: Its AWESOME!! Love it, great on street and awesome on trails. Had their 3.5" and it was great as well. I would highly recommend Rubicon Express
CanadianCon
CanadianCon's Reviews
10-30-2008, 12:27 AM
Price: $2,500.00
Recommended? Yes
Comments: This lift is sweet, My jeep rides nicer then when it was stock. I would use this lift on any jeep i own
Sccafire
KMG 365
Sccafire's Reviews
10-28-2008, 01:46 PM
Price: $2,300.00
Recommended? Yes
Comments: Great overall kit. I have had no issues at all with this kit. Company being local makes it even better.
Pionex311
Pionex311's Reviews
08-19-2008, 03:16 PM
Price: $2,700.00
Recommended? Yes
Comments: I really haven't had the chance to put this through it's paces yet, but with 31 1050 Cooper STT's, they have done excellently. Trust me, if you want flex, this is the way to go. I also bought the sye and chromoly tie rod with the kit too.
rkcrwln99
rkcrwln99's Reviews
07-25-2008, 07:13 PM
Price: $1,600.00
Recommended? Yes
Comments: THE BEST LONG ARM KIT BUILT ON THE MARKET, I UPGRADED THE SPRINGS TO 7.5. TO CLEAR 37S.
wallyb
wallyb's Reviews
07-24-2008, 05:56 PM
Pros: Perfect fit, articulates and level, smooth ride on and off road
Cons: None so far.
Recommended? Yes
Comments: 98 TJ>I can't compare it to other long arms but I can say it went way beyond my expectations. I installed the Tri-Link running Rubicon Dana 44 axles 4:88 gears, 35 spline OX Locker front and rear, and 35" BFG KM2. The mfgr recommended 35's. This was my first lift and I don't need an improvement. My front springs drop out of the buckets and return home no problem. It's hard to get air time. The Tri-Link is stable and tucks with minor rub. No body lift and no trimming. What more can you ask for? It was professional alligned before highway and trail use. Be wise to good advise. We finally found a Magnaflow cat back to fit. The research paid off..Big-Time. RubiconTrail tested.
TJGIP
TJGIP's Reviews
07-11-2008, 08:01 AM
Price: $2,790.00
Recommended? Yes
Comments: Installation of this kit is fairly smooth. Completed the entire install by myself in a total of about 40 hrs with little previous suspension experience. One problem I ran into was clearing the rear track bar from the stock gas skid. This could be eliminated with an aftermarket skid or some cutting of the stock. I went with the latter to save expenses.
I'm very satified with the way it turned out. Looks great and rides way better than it did before with BB and 33's. I recomend this lift, however if I were to do it again I would spring for the tri-link setup.
1997jeeptj
1997jeeptj's Reviews
06-03-2008, 08:31 AM
Price: $3,000.00
Recommended? Yes
Comments: I went with 4.5" kit, I have now installed 5 of these, with 2 of them on my own jeeps. I love them. I have thought about building my own suspension system, but this is a bolt on kit that works, and drives better than stock.
ThreadForumRepliesLast Post
Rubicon Express RE5525 4.5" Extreme Duty CJ Kit Complete Lift Kits 10 12-25-2009 07:20 PM
Rubicon Express 4.5" Extreme Duty Yj Complete Lift Kits 13 09-30-2009 08:04 PM
Rubicon Express Extreme Duty Springs 8 03-07-2009 01:08 AM
Rubicon Express RE8300 ZJ 4.5" Extreme Duty Long Arm Kit Complete Lift Kits 3 12-15-2008 06:27 PM
Rubicon Express RE6300 5.5" Extreme Duty Long Arm XJ Complete Lift Kits 2 10-04-2008 03:32 PM
Glock Forum
