Rubicon Express RE7000 4.5" Super Flex TJ
Rating: |
Product Information
| MSRP: |
$2,381.00 |
| Average Price: |
$1,166.67 |
| Manufacturer: |
Rubicon Express |
| Recommended? |
Complete Kit, upgradable with all adjustable control arm, adjustable track bars and RE Monotube shock.
Netted about 5.5" of lift initially after the install.
rkwfxd's Reviews
11-16-2011, 02:19 PM |
Price: $1,499.00 Pros: Complete and fairly easy to install Cons: STIFF Recommended? No
Comments: I would have never purchased this kit for myself for two reasons. 1) I did not want to go over 3" of lift and 2) I have heard too many horror stories about the bushings.
Well, this kit was a gift so who was I to complain. Also, since RE went out of business and was purchased by 4WD Parts Warehouse the bushings have been completely re-designed.
The install was actually pretty easy/straight forward and all of the parts are very high quality. Between that and the SYE and DS it took me about 30 hours to complete. I upgraded to an RE adjustable rear track bar and I used a Moog TRE #ES2848LT on the front RE adjustable TB so that I would not have to drill the frame side mount. I am sure the larger bolt and heim joint that come with the front TB are stronger but I can always drill it out and use those if this TRE does not work.
I have only driven around the neighborhood so far and all I can say is this kit rides STIFF, ROUGH, HARD. When we finished the rear and lowered it off the jack, as soon as the tires touched the ground, the top of the jeep stopped also.
I have a friend with an old 5.5" long arm RE kit and his jeep is very smooth. Hopefully with some miles mine will soften up.
Ironmacruz's Reviews
Price: $1,800.00 Pros: Nice flexing Cons: None so far Recommended? Yes
Comments: When you buy the best, some times you pay more, but in long term you wont have any problems with your lift kit.
I recommend this lift kit a 100%
TJamie's Reviews
Price: $1,000.00 Pros: Good amount of lift, beefy components, flex joints Cons: A little stiff Recommended? Yes
Comments: I got the control arms used off of craigslist, and then bought the rest of the components new. The springs are very stiff at first, you'll feel every bump. After 1k miles and the addition of bumpers, I believe they've softened up (of maybe I have). Done some minor wheeling, so far so good.
failure2stop's Reviews
Price: $1,500.00 Pros: Better than stock on road great flex off road. Cons: No con's Yet.. Recommended? Yes
Comments: I really enjoy this lift. it came with everything you will need.
Kris B Krunch's Reviews
Price: $1,200.00 Pros: Good build quality of the control arms
higher than advertised amount of lift achieved
greasable flex joints Cons: Stiff Springs
Bushings wear out rather quick
too much suspension lift for short arms Recommended? No
Comments: I originally started out with the 3.5" kit, but since upgraded everything, including the coils over the last 5 years to the 4.5" kit.
I'll be swapping out the coils rather soon for some softer ones, as I did things a little backwards and just now realizing there are better riding short arm lifts out there....also will be dropping down to probably about 3" lift to help out with getting the control arm angles back down.
neZZr
 Lifted/Locked/Rolled/Sunk |
neZZr's Reviews
03-21-2009, 08:04 PM |
Recommended? Yes
Comments: Rear frame-side control arm bushings wore out quickly, but were cheap and easily replaced. Otherwise an awesome performing suspension and very complete kit. Only thing I would do different, is go straight to long-arm.
Apex
 Recon death squad |
Apex's Reviews
02-25-2009, 11:18 PM |
Price: $1.00 Pros: Flexes well Cons: RE monotubes are kinda stiff on a light jeep...easily correctable with a winch in front and some armor in the rear Recommended? Yes
Comments: I like this kit, I ordered it though redrock4x4 and it came with an AA SYE and a TW driveshaft
I also upgraded to all adjustable control arms, adjustable track bars, shock relocators, HD rear track bar, RE Monotubes. So that is factored into the price as well.
Everything works fantastic, and this kit flexes very well. Gave me just under 5.5" of total lift
