Rubicon Express RE6130 XJ 4.5" Super-Flex Suspension w/ Leaf Springs Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $1,300.00
Average Price: $1,172.40
Manufacturer: Rubicon Express
Recommended?
Yes: 11 / No: 0
Complete XJ suspension lift. It comes with all the parts and hardware you need.
None
NickInTimeFilms
NickInTimeFilms's Reviews
05-22-2014, 02:20 AM
Price: $1,050.00
Pros: Comes with everything you need to properly lift your XJ and help correct ride geometry. Includes Front Swaybar Quick-Discos. Allows you to choose your own shocks.
Cons: The Trackbar spacer fittings didn't fit the supplied bolt so I had to pick up a 9/16" bolt.
Recommended? Yes
Comments: After comparing high and low for the best lift, I decided on doing it correctly and making a well invested purchase. The RE 4.5" Super-Flex was only a little more than the RE 3.5" Super-Ride and came with longer brake lines and adjustable Track bar so I figured why not. The installation went smoothly as I only broke 1 rear upper shock mount bolt that I drilled and tapped to the next size bigger. The front upper control arms took a bit a wrestling to get in but it lined up eventually. The Trackbar spacers didn't fit the included 5/8" bolt so instead of trying to drill an already small fitting, I decided to just get a 9/16" bolt. My stock track bar bracket was wobble out a little even after drilling so I will update if I have any clunking problems. I also ordered the RE MonoTube shocks and RE Steering Stabilizer just to match. The Monotubes feel very smooth and are absolutely worth the extra $100 after feeling my friends twin tube skyjackers. Overall I netted about 5" in the front and 5.5" in the Rear. An SYE is rather important if drive shaft vibes bother you.
rapidcycler
rapidcycler's Reviews
08-04-2012, 07:35 PM
Price: $1,600.00
Pros: Lifted the heck out of my Jeep...laffs. Quality looks great. Company was very helpful. Got 6130 kit (4.5 inch)
Cons: Track bar install a pain drilling out bracket to 5/8 inch. Took mine bracket off and took to a machine shop.
Recommended? Yes
Comments: I am a casual car DIYourselfer. With weather, broken, and seized huge bolts. I took me a month to do it. But that's not a reflection on the product, just the magnitude of the job for the casual newb. It lifted my jeep like crazy, pretty sure above 3.5 inches. Sturdy, complete kit. I would recommend it. The $1600 includes SYE and Driveshaft.
Red91xj26
Red91xj26's Reviews
07-25-2012, 05:46 PM
Price: $900.00
Pros: Nice ride.
Cons: leafs
Recommended? Yes
Comments: Easy to install, customer support is very helpful
Surly
Surly's Reviews
12-30-2011, 01:51 AM
Price: $1,125.00
Pros: -durable quality parts -came with braided brake lines -leafs have shown minimal sagging overtime
Cons: -RE shock performance on and offroad
Recommended? Yes
Comments: I have had this suspension setup installed for roughly 20k miles now and i must say it is a performer offroad and a quality product for the price. My only grudge with the kit was the shocks. I personally didn't like the feel of them on the road and the dampening offroad. I replaced them with Fox 2.0s and its been smooth sailing offroad and on ever since.
spietrzak
spietrzak's Reviews
04-13-2010, 11:51 AM
Price: $1,049.00
Pros: so far from what i have done with the kit i do like. just wish i got the long arm kit for it. which i plan to upgrade to
Cons: should of came with the drop pitman arm
Recommended? Yes
Comments: i do recommend this lift for a xj if you are wanting to run small to medium tires. the kit allows you to flex pretty damn good
pmariolo
pmariolo's Reviews
10-30-2009, 12:18 AM
Price: $1,100.00
Pros: everything about it is great. tons of flex for a short arm kit.
Cons: rear springs a bit stiff but not too bad
Recommended? Yes
Comments: everything about it is great. tons of flex for a short arm kit.
jeepmansro
jeepmansro's Reviews
10-12-2009, 09:29 PM
Price: $1,300.00
Pros: Complete Kit, strong tubular control arms.
Cons: No real instructions or walk through. Alot of squeaks.
Recommended? Yes
Comments: Over all a good kit. On the high end of the price scale, but I got it with the regular mono tube shocks.
Some instructions or walk through would be appreciated, as I didn't really get too much direction about everything that was shipped to me. When replacing just about all of your suspension items it is also a great time of find out who your true friends are, as you will be calling on them alot.
Also installing an SYE that is required with this kit, (and sold separately) is really not that hard, and is one of the best ways you can get rid of drive line vibes. The SYE (adapter type SYE) with NEW RE drive shaft will run you roughly $500 so keep that in mind.
Secondly Rubicon Express also recommends 4 degree shims to be installed to angle the rear end upward, (depending on your year) to make it more inline with the drive shaft. Also sold separate.
NOW you can, as some others might say, go with a transfer case drop kit to make the drive shaft angle less severe, but i went for strength and pure manleyness.
Last it comes with front extended bumpstops, but the (usually) rotted ones in the rear are not mentioned. Im still looking into the proper length for mine.
Im sure there are better reviews out there, but there is my 2 cents. Will add more later.
olaf
olaf's Reviews
01-28-2009, 09:41 PM
Price: $1,200.00
Recommended? Yes
Comments: Excellent kit. The parts are much beefier than stock. The installation was pretty straight forward. I was able to complete it in two days with minimal assistance from a friend.
cavanhills
cavanhills's Reviews
01-03-2009, 10:37 PM
Price: $1,300.00
Recommended? Yes
Comments: This is easy to install and fun to drive and use. The flex that this suspension system allows changes the possibilities and areas one can explore.
98-XJ-Nate
98-XJ-Nate's Reviews
10-21-2008, 10:49 PM
Recommended? Yes
Comments: this is my first Jeep so I cant really say anything about other lifts but It came with my jeep and I have heard many times what a good lift it is!!
Silent
Silent's Reviews
08-29-2008, 06:26 PM
Price: $1,100.00
Recommended? Yes
Comments: I do not currently have this installed on my XJ. I have heard good things about Rubicon Express, so I bought it. I hope it rides and performs as good as I have heard.
ThreadForumRepliesLast Post
Rubicon Express 3.5" Super Flex TJ Complete Lift Kits 87 09-25-2013 10:51 AM
Rubicon Express RE6130 Super-Flex w/ Leaf Springs Complete Lift Kits 4 01-27-2013 07:47 PM
Rubicon Express RE7000 4.5" Super Flex TJ Complete Lift Kits 9 12-07-2012 03:17 PM
Rubicon Express RE8000 4.5" Super-Flex Complete Lift Kits 56 09-09-2012 11:10 PM
Rubicon Express RE8003 3.5" ZJ Super-Flex Kit Complete Lift Kits 9 06-03-2008 07:06 PM
