Rubicon Express RE6030 3.5" Superflex - XJ
Rating: |
Product Information
| MSRP: |
$3,000.00 |
| Average Price: |
$783.79 |
| Manufacturer: |
Rubicon Express |
| Recommended? |
Rubicon Express' 3.5" Superflex lift for XJ's.....
Jeeper1973's Reviews
Price: $550.00 Pros: Complete kit... except shocks. nets at least 4" Cons: shocks included in kit would be nice. Recommended? Yes
Comments: This kit was the best bang for your buck when I was looking. I wanted approx. 4" of lift and this kit gave that in the front and a bit more in the rear. I chose to do the SYE kit at the same time as this lift.
I learned a neat trick when searching for this lift. The RE6030 lift kit and a SYE kit (not a hack-n-tap) will allow for an XJ front driveshaft to be used in the rear. cheaper than a custom drive shaft and now both driveshafts are identicle.
Avor
 Registered User |
Avor's Reviews
Price: $800.00 Pros: Good lift; good ride. Cons: None. Recommended? Yes
Comments: Great lift. I can't comment on installation. My leaf spring bolts were frozen and ended out having to be cutout, so I had a shop do the install.
I have no complaints. I recommend lubing up all the joints on the front end to insure there's no squeakage.
wjjeep4x4's Reviews
Price: $150.00 Pros: Great flex and lift was not too difficult to install. Cons: Leaf spring bolts have excessive play and are noisy in bumps and turns. Recommended? Yes
Comments: This lift gave me more than the 3.5" advertised. Quality products. The instructions given were thorough and made the install not too difficult. Great on road and off road performance.
andrij13's Reviews
Price: $760.95 Pros: It's a lift kit right? Quick disconnect... Cons: You need to get bigger tires with a bigger lift, only way to fix the rubbing is to trim, which I DON'T wanna do. Recommended? Yes
Comments: The 31s rub on front, if I got a 4.5 inch lift, I would have to get bigger tires, which would still give me the same problem
OCsurfin's Reviews
Price: $1,200.00 Pros: AMAZING Cons: havent found one yet Recommended? Yes
Comments: i upgrade my kit to JKS Quicker disco's, i never attach them so i smash curbs and hit the fields whenever i want, so it wasnt worth it. i also got the Old Man Emu shocks, they are soooooooo good, i never use anything else.
xjsport96's Reviews
Price: $750.00 Pros: Higher then advertised lift height rides great looks great flexes well. Cons: Back sits higher then front but it should settle Recommended? Yes
Comments: Really complete lift definately top of the line, also bought monotube shocks adjustable track bar and t case drop.
Saint18z's Reviews
Price: $1,000.00 Pros: doesnt take away from the handling on road, and is great off road Cons: shocks were messed up when i got them (ups's fault) jeepin sent me a new pair free of charge Recommended? Yes
Comments: great product. ordered it from jeepin and got the old man emu shocks and jks quicker discos. couldnt be happier with it. Ive had it installed for four years now, and almost no sag
nrpalmer32's Reviews
Price: $720.00 Pros: Keeps a good COG while still lifting
Easy install (as long as you pre-soak all bolts)
Cons: Once you lift you always want it higher. Recommended? Yes
Comments: The lift kit is definitely beefy! I heard to install a longer track bar so I did, but besides that the kit comes with everything needed.
bob6987's Reviews
Price: $1.00 Pros: its lifted Cons: noisy Recommended? Yes
Comments: Came installed when i bought the jeep
justanotherjpr's Reviews
03-30-2009, 03:21 PM |
Price: $650.00 Recommended? Yes
Comments: Added 1.5" shackle with .5" block and 2" spacers up front. Great springs, ok shocks. Have blown out both rear shocks within a year. Rear springs don't flex that well and are still a little stiff after 1.5 years. Front flexes great.
Captainofiron's Reviews
02-18-2009, 02:04 PM |
Price: $450.00 Recommended? Yes
Comments: Great kit, really good quality. Everything stood up well to all abuse, easy to understand instructions. No regrets
oOEVIDENCEOo's Reviews
01-31-2009, 08:03 PM |
Price: $3,000.00 Recommended? Yes
Comments: 1 in shackles 3/4inch coilspacers puts it at 4.5 not to happt atm but might be ez to fix
HornedFrogHooah's Reviews
01-20-2009, 02:52 PM |
Price: $1,126.73 Recommended? Yes
Comments: Absolutely amazing. I did go ahead and get a SYE and CV, I didn't have too, I just felt better knowing it was there. Total price included four monotube shocks as well.
Steve2237's Reviews
01-13-2009, 10:16 PM |
Price: $600.00 Recommended? Yes
Comments: Just installed......................................... .................................................. .................................................. .................................................. ....
pfcstone777's Reviews
01-13-2009, 06:54 PM |
Price: $700.00 Recommended? Yes
Comments: Great product. gives great flex and drives very well on the road. Gave me around 5'' at first. settled down to around 4 after a while.
JJR00XJ's Reviews
12-17-2008, 07:22 PM |
Price: $862.00 Recommended? Yes
Comments: Its not installed yet I hope it turns out well 2 shocks were back ordered.
srmitchell's Reviews
11-27-2008, 09:29 PM |
Comments: Amazing ride, everything included, easy install.
I have ome shocks, front stainless brake lines, and the RE 1600 track bar to round out the package.
jps4wd's Reviews
11-12-2008, 01:48 PM |
Price: $900.00 Recommended? Yes
Comments: everything fit great and products seemed high quality, but do not get the dt3000 shocks cause they ride really rough
4X4XJJeep's Reviews
09-05-2008, 03:39 PM |
Price: $529.00 Recommended? Yes
Comments: I have the super ride and love it. It is smooth off road. Nice travel and solid parts. Great lift for the money.
