Rubicon Express 3.5" Super Flex TJ Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $1,500.00
Average Price: $811.28
Manufacturer: Rubicon Express
Recommended?
Yes: 89 / No: 4
RE7002 3.5" Standard Kit TJ/LJ - The Standard kit is a perfect entry for those looking to run 33" tires on a smaller budget. The 3.5" Standard kit includes springs, and bump stops, but maintains stock control arms and track bars. On and off road performance of this kit is excellent and is easily upgradeable to the Super-Flex kit by adding our control arms and other Super-Flex components.
None
Page 2 of 5 1 2 3 4 5 > Last
BrandonRay
BrandonRay's Reviews
07-05-2010, 02:43 AM
Price: $1,050.00
Pros: better than stock ride, so far no issues
Cons: nothings adjustable except disco's
Recommended? Yes
Comments: All the components that came with the kit seem to be pretty quality, and much beefier than stock. I went with monotube shocks and the ride is great. I got close to 4" with this lift. I do need a bring the front end up a little more to level it. I had to redrill the the front track bar mount, which has been fine so far but it's the only real area of concern I have safety wise. I read some threads talking about adjustable track bars hitting the front differential cover with lower lifts, so I'll probably just keep the stock track bar and weld on some steel to reinforce the track bar mount.
This was my first lift and I do weld and I did weld the rear track bar bracket on that comes with the kit, but welding is not required. As I said though this was my first lift and I was able to do it by myself with no extra hands around to help. Theres a link to a great write up on this forum and that was invaluable for me as the instructions that came with the kit were very vague. Any more questions feel free to PM me.
Fett
Mechanically Declined
Fett's Reviews
06-30-2010, 11:12 AM
Price: $1,400.00
Pros: Reputable, good quality, easy install.
Cons: None yet (at least for the kit as advertised).
Recommended? No
Comments: This kit is easy enough for a novice like me to install.
IF YOU INSTALL A SYE/CV SHAFT WITH THIS KIT......buy the angled rear track bar bracket, adjustable track bar and rear adjustable upper control arms. It will make your life a lot more simple. You'll also need to either purchase rear shock relocation brackets or trim the spring plate so that the shock doesn't hit it.
jeepgranger
jeepgranger's Reviews
04-09-2010, 12:59 AM
Price: $950.00
Pros: great height looks awesome with 33x12.50
Cons: none!
Recommended? Yes
Comments: Rubicon will always make thee best of the best!
03TJ_Freeride
03TJ_Freeride's Reviews
03-05-2010, 10:16 AM
Price: $850.00
Pros: Fairly cheap price with quality components, flex, should be a great base for a build
Cons: Don't know that this is really a con but actual lift seems to be 4"+(for you low COG people), may just be my springs. . .
Recommended? Yes
Comments: Great lift for the money. Did some research and at this price point could not find a better deal. I got the standard kit, which comes without the control arms, but got RE monotubes with the kit. Installed this kit cost me $1247 with tax and alignment and a 9-5 turnaround. Would have rather done it myself, but I have no access to a shop or tools atm.
Richd1963
Richd1963's Reviews
02-19-2010, 07:35 AM
Price: $960.00
Pros: Nice looks, fairly easy to install.
Cons: Rear track bar bracket needed some creative custom fitting.
Recommended? Yes
Comments: It was fairly easy to install. I did end up using my coil spring compressor to install new springs. I also went with an adjustable front trac bar instead of using the supplied bracket. The rear trac bar bracket did not line up correctly so I had to modify the holes a tad bit. Fits 33" tires great. Plenty of room for 35"s. I had is on for a day and then went out and had an alignment. Went playing in the Sespe creek and wheeling around the trails for the day. Suspension settled in during that time so now my trac bar needs adjusting a bit. Will re-align. My advice: if your going to get an alignment? First flex it a bit and let the lift settle in. That way you won't have to get two alignments. Went with the reccomended RE Monotube shocks.
steviej35
Junior Member
steviej35's Reviews
02-12-2010, 07:38 PM
Price: $500.00
Pros: Used kit came with adjustable trac bar
Cons: None as of yet
Recommended? Yes
Comments: Rides good defiantly need a sye with this kit gets some vibes in 2nd gear.
famousstar1026
famousstar1026's Reviews
02-09-2010, 08:29 PM
Price: $827.00
Pros: looks clean easy install
Cons: does not come with upper control arms bushing are iffy
Recommended? Yes
Comments: recommened
TennesseeTJ02
TennesseeTJ02's Reviews
02-02-2010, 03:01 AM
Price: $1,200.00
Pros: Its a great lift with a lot of flex.
Cons: the quick disconnects squeak after awhile but just WD-40 them.
Recommended? Yes
Comments: The lift is a great lift for the price. It has a lot of flex.
sar50
Junior Member
sar50's Reviews
12-14-2009, 07:36 PM
Price: $1,000.00
Pros: Good design, easy install, modular, lots of flex
Cons: none
Recommended? Yes
Comments: I purchase this from Groupbuy4x4 with shocks good deal & good service
HamBone5187
HamBone5187's Reviews
12-13-2009, 04:06 PM
Price: $1,000.00
Pros: Not a bad ride. I installed it and then they gated my 4-wheeling spot and posted it, so I haven't been able to try it out.
Cons:
Recommended? Yes
Comments:
JVRuby
JVRuby's Reviews
12-10-2009, 04:00 PM
Price: $800.00
Pros: Nice height, firm ride, complete kit
Cons: No upper control arms or front track bar included.
Recommended? Yes
Comments: Complete kit. Installed the kit by myself in about 6 hours. I purchased the twin tube shocks and would probably go with monotube if I had to do it again.
Installation was pretty straightforward, following the RE instructions. I would recommend adj. upper control arms and front track bar to ease/correct alignment and pinion angles.
Very solid lift for the $$.
jerzyjeep09
jerzyjeep09's Reviews
11-19-2009, 01:10 PM
Price: $900.00
Pros: It gave me the Clearance and look I wanted
Cons: Price
Recommended? Yes
Comments: The kit is new and I wasnt sure how it would go. I bought the Rubicon Express 3.5 lift kit and Rubicon Mono-Tube shocks. The install was easy, and the ride stayed about the same, just a little stiffer than stock. Im real happy that I spent the extra money and went with this lift. I also keep in mind that this kit is engineered to be easily up-graded to a Super-Flex system. Overall it gave me the clearance I needed and the look I wanted.
mattiacono
mattiacono's Reviews
11-18-2009, 07:20 PM
Price: $820.00
Pros: rides great on the streets, flex is amazing and reasonably priced compared to others
Cons: no problems yet just be sure not to skimp out on shocks
Recommended? Yes
Comments: i would recommend this kit to anyone who is looking to run 33's on a smaller budget. the flex on this kit is amazing and the ride is close to stock. i have had it for almost a year and have no squeaks or problems. i installed a sye and cv along with it so i wouldn't have to worry about vibrations. if i had to do it all over again i would buy this kit again.
evan1395
evan1395's Reviews
11-16-2009, 12:28 AM
Price: $950.00
Pros: Front Swaybar Disco ;), rides like a dream on the freeway
Cons: Havnt found any yet
Recommended? Yes
Comments: BAdass flex, good quality, put it through alot so far and all bushings are still good after about 35k miles
Damonec
Damonec's Reviews
11-03-2009, 10:09 PM
Price: $350.00
Pros: great price, enough lift to fit 33's and have decent articulation
Cons: shocks and steering stab aren't included, must be bought as extras
Recommended? Yes
Comments: Pretty decent articulation out of the kit not exactly sure on how much just yet I'll update later when I've tested it out more.
Jim Shanks
Jim Shanks's Reviews
11-02-2009, 09:03 PM
Price: $350.00
Pros: Awesome used price, awesome flex!
Cons: Springs rusted a bit
Recommended? Yes
Comments: This kit simply amazes me, I have kept up with quite a few long arm'd rigs with my somewhat little short arm'd setup.
Jim
DeathMonkey007
DeathMonkey007's Reviews
09-17-2009, 01:22 PM
Price: $1.00
Pros: I haven't had a chance to use it much yet. Then one pro that I do like already though is that its upgradeable.
Cons: The disconnects sure do rattle a lot.
Recommended? Yes
Comments: I haven't had a chance to use it much yet. Then one pro that I do like already though is that its upgradeable.
Oaktree
Oaktree's Reviews
07-29-2009, 08:28 PM
Price: $600.00
Pros: amazing.
Cons: nothing is wrong with it
Recommended? Yes
Comments: great for any type of wheeling.
GREASEMONKEY
GREASEMONKEY's Reviews
06-06-2009, 02:07 AM
Price: $900.00
Pros: Tough axle end spherical joints, higher lift than advertized, decent ride, decent price, and easy to install
Cons: control arm bushings at frame end, are crap. I have been through 3 sets of bushings in 6mo, and that's daily driving/light wheeling. The warranty on the bushings is a joke, they only replaced one set of bushings under warranty, and I have come out of pocket $50+ for each set of 4.
Recommended? No
Comments: I wa extremely happy withthe easy install, tough looking parts, actual lift i gained, and decent ride. I have one major problem, that's the cheap junk control arm bushings they use in the SF kit. If anyone is interested in this kit, I suggest selling the RE arms, and getting some good currie arms, or similar.
gator055
gator055's Reviews
04-08-2009, 11:18 AM
Price: $900.00
Recommended? Yes
Comments: Great life, great ride, great components, completely recommend this lift to anyone looking for a great TJ lift.
ThreadForumRepliesLast Post
Rubicon Express RE7000 4.5" Super Flex TJ Complete Lift Kits 13 06-23-2016 03:29 PM
Rubicon Express RE6130 XJ 4.5" Super-Flex Suspension w/ Leaf Springs Complete Lift Kits 11 05-22-2014 12:20 AM
Rubicon Express RE6130 Super-Flex w/ Leaf Springs Complete Lift Kits 5 12-20-2013 03:13 PM
Rubicon Express RE8000 4.5" Super-Flex Complete Lift Kits 56 09-09-2012 11:10 PM
Rubicon Express RE8003 3.5" ZJ Super-Flex Kit Complete Lift Kits 9 06-03-2008 07:06 PM
