Notices
Rough Country - Rough Country 4" Long Arm Kit Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $1,299.95
Average Price: $1,089.33
Manufacturer: Rough Country
Recommended?
Yes: 15 / No: 0
Company Website: http://www.roughcountry.com/index.html
Extreme Flex without the Extreme Price
Front: High flex coil springs, lower high clearance arms with X-Flex Joints, upper control arms with X-Flex Joints, control arm mounting brackets, adjustable track bar with drop bracket, drop pitman arm, sway-bar disconnects with parking bracket, and stainless steel brakelines.
Rear: High flex coil springs, lower high clearance arms with X-Flex Joints, upper control arms with X-Flex Joints, adjustable track bar, extended sway bar links, stainless steel brakeline, and bumpstop extensions.
Shocks: Kit includes (4) High Performance 2.2 series shocks.
Notes:
Does NOT fit Unlimited models
Slip Yoke Eliminator with CV Driveshaft is
recommended to avoid driveline vibration.
Rubicon models do not need SYE kit or
CV Driveshaft.
Exhaust will have to be cut and rerouted to make
sure it is away from the moving components.
Benefits:
Flex joints designed by Rough Country.
Includes our 2.2 High Performance Shocks.
Features high clearance lower control arm design.
Extreme travel long arms keep optimum alignment
and give optimum articulation.
Unbeatable value and best prices in the market!
Upgradeable with our Jeep X-tras. - Click Here -
Specs:
Part #: Perf663
Install Time: 8 - 9 hours
Wheel Backspacing: 4.5"
Recommended Tire Size: 33x12.50
None
kevinmoleyjr
kevinmoleyjr's Reviews
01-25-2016, 12:42 PM
Price: $1,600.00
Pros: lengthened adjustable control arms. complete kit, comes with everything
Cons: under skid bracket fairly large and not as sleek as kits that attach to a skid plate
Recommended? Yes
Comments: Pretty awesome kit. The bushings lock plates at the ends of the arms need to be stronger though
taborjoshjlt
taborjoshjlt's Reviews
09-22-2015, 06:47 AM
Price: $800.99
Pros: Cheap easy to install johnny joints when stock go bad
Cons: Joints are crap
Recommended? Yes
Comments: Good product for cheap price, adjustable arms allow some stretch
sweetschoolbus
sweetschoolbus's Reviews
08-27-2015, 09:46 AM
Price: $1,500.00
Pros: Long-arms replaced stock control-arm mounts, which had been damaged in an accident (Jeep was hit while parked).
Cons: Polyurethane bushings rattle more than OEM rubber bushings. Grease fitting design does not reach interior of bushings.
Recommended? Yes
Comments: The kit does a good job to address driveline and steering angle changes, but I didn't like the drop-brackets on rear swaybar and both bump stops. The polyurethane bushings aren't ported to accept grease - the grease fittings are practically decorative.
BlackWidowWJ09
BlackWidowWJ09's Reviews
05-26-2015, 02:26 AM
Price: $1,300.00
Pros: Great Articulation, Definitely Underestimated
Cons: Weak Flex joints
Recommended? Yes
Comments: Absolutely love this kit I would recommend it to anyone and really aggravates me people doubt Rough Country they have great products
Pinoy59
Pinoy59's Reviews
04-08-2015, 06:08 PM
Price: $1,200.00
Pros: cost, durability
Cons: incomplete installation instructions
Recommended? Yes
Comments: Great Product, you can see my review at roughcountry.com (4.5" long arm kit for the np242 t-case, 97 xj)
kaserWJ04
kaserWJ04's Reviews
05-20-2013, 12:58 PM
Price: $1,499.99
Pros: Good ride, smooth
Cons: Nothing so far
Recommended? Yes
Comments: I absolutely love this lift for my 04 WJ. I have had no trouble with this product so far, it has a great ride and everything has stayed tight.
kaserWJ04
kaserWJ04's Reviews
05-20-2013, 12:57 PM
Price: $1,499.99
Recommended? Yes
DNance1
DNance1's Reviews
10-19-2012, 01:24 PM
Price: $1,599.00
Pros:
Cons:
Recommended? Yes
Comments:
RWTJ02
RWTJ02's Reviews
05-09-2012, 08:01 PM
Price: $500.00
Pros: great price
Cons: shock bushings wear out
Recommended? Yes
Comments: Installed lift myself in a weedend, was pleased with outcome and perforamce. However the shock bushings wore out quickly.
2003X
2003X's Reviews
10-31-2011, 03:53 PM
Price: $765.00
Pros: Long arms, good ride quality.
Cons: Joints squeak a bit, but nothing major.
Recommended? Yes
Comments: Upgraded my RC Series II kit to the Long Arms. Very happy with them. Easy to install and ride great.
robbijer
robbijer's Reviews
03-28-2011, 01:27 PM
Price: $800.00
Pros: Ability to purchase long arm upgrade seperatly
Cons: Finish on parts isn't that good, flex joints on only one end of control arms, mounting for control arms is kinda low
Recommended? Yes
Comments: I used this kit as an upgrade to my Fabtech 4" lift. I also purchased Rough Countries skid plate which is great. The kit itself so far has performed fine without any problems. The instructions could have been a little more thorough. Main advantage of this kit is price. It has only been installed for 1000 miles, I am expecting many more and will update later.
markflexes
markflexes's Reviews
11-19-2010, 01:47 AM
Price: $1,175.00
Pros: Great budget kit with super strong and beefy links. Easy install and good fit and finish
Cons: none
Recommended? Yes
Comments: I got this kit for at least 1/2 of any other LA on the market and feel like it performs as well as any higher end kit. I would recommend highly.
Obnoxious1
Obnoxious1's Reviews
06-21-2010, 11:30 AM
Price: $400.00
Pros: pretty easy to install, most parts needed included
Cons: shocks not included, rides like a log wagon
Recommended? Yes
Comments: Install took a weekend ( more beer drinking than actual work) instructions were pretty clear. recommend a higher quality shock absorber to offset the rough ride
p3c0r
p3c0r's Reviews
04-21-2010, 02:26 PM
Price: $530.00
Pros: Great handling, awesome flex, good instructions
Cons: rough ride(not that I mind)
Recommended? Yes
Comments: It was great, instructions were easy, and very minor modifying was required
rideraa
rideraa's Reviews
12-15-2009, 01:20 PM
Price: $1,170.00
Pros: Price was list less the 10% JF member discount
Cons: none
Recommended? Yes
Comments: Installed great, no problems .... flex's great ... for up to 2k less then others it can't be beat ... I can't say enough good about this
When u get it check all your components, hardware, nuts & bolts .... that way when installing there are no hold ups, there are a *** load of pieces .... (i did) FYI I was missing a jamb nut for one of the track bars.. RC got it to me immediately
ThreadForumRepliesLast Post
Rough Country Rough Country 2.2 Shocks Shocks 34 05-29-2016 03:31 PM
Rough Country 3.25" Progressive Coil/Spacer Kit for 97-06 TJ Complete Lift Kits 74 01-21-2014 05:15 PM
Rough Country 4" Rough Country Suspension Lift Complete Lift Kits 134 10-05-2013 12:46 AM
Rough Country - Rough Country 6" Long Arm Kit Complete Lift Kits 6 09-15-2013 04:41 PM
Rough Country - Rough Country Bar Pin Eliminator Kit Shocks 1 01-08-2010 03:30 PM
