Rough Country - Long Arm Upgrade Kit Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $899.95
Average Price: $844.00
Manufacturer: Rough Country
Recommended?
Yes: 6 / No: 0
Company Website: http://www.roughcountry.com/jeep_tj_663U.html
Extreme Flex without the Extreme Price
Front: Lower high clearance arms with X-Flex Joints, upper control arms with X-Flex Joints, control arm mounting brackets, rubicon compressor bracket, and hardware.
Rear: Lower high clearance arms with X-Flex Joints, upper control arms with X-Flex Joints, track bar bracket, and hardware.
Description:
Upgrade your existing 4" or 6" Jeep TJ suspension kit to a Long Arm kit!
Notes:
Does NOT fit Unlimited models
Upgrade for 2.5", 4" and 6" kits Only.
Slip Yoke Eliminator with CV Driveshaft is
recommended to avoid driveline vibration.
Rubicon models do not need SYE kit.
CV Driveshaft is still recommended.
Exhaust will have to be cut and rerouted to make
sure it is away from the moving components.
Benefits:
Features high clearance lower control arm design.
Extreme travel long arms keep optimum alignment
and give optimum articulation.
Unbeatable value and best prices in the market!
Upgradeable with our Jeep X-tras.
Features our NEW X-Flex control arms:
* Massive flex joints with 2.5" diameter body and huge 1.25" threads
* All joints are fully rebuildable
* Fully greasable
* Adjustable retainer ring
* Upper joints pivot up to 20 degrees
* Lower joints pivot up to 35 degrees
None
SteeleJay
SteeleJay's Reviews
08-07-2015, 09:22 PM
Price: $1,099.00
Pros: It's beefy all around, greasable joints
Cons: Questionable Rough Country quality control
Recommended? Yes
Comments: This is a bolt-in long arm kit that replaces the stock short arm setup. The longer control arms remain parallel to the ground at greater lift heights, allowing the springs to absorb the bumps.
somebody5788
somebody5788's Reviews
05-17-2015, 10:46 PM
Price: $900.00
Pros: Strong components simple designs
Cons: Not everything is 100% to specification.
Recommended? Yes
Comments: For an off road lift it works great. I wish the control arms were a little bit closer in specification to what they are supposed to be but it works.
sandresen
sandresen's Reviews
12-26-2013, 03:39 PM
Price: $899.00
Pros: Easy installation, smoothed out the road ride to better than stock. Good fit and finish.
Cons: Instructions were fairly straightforward, although I would recommend building the arms first, then dropping the skid plate and installing the mounts. You can do all this with wheels on the jeep.
Recommended? Yes
Comments: Easy installation, smoothed out the road ride to better than stock. Instructions were fairly straightforward, although I would recommend building the arms first, then dropping the skid plate and installing the mounts. You can do all this with wheels on the jeep. Very happy with the upgrade.
bomoto
Junior Member
bomoto's Reviews
12-20-2011, 06:22 PM
Price: $1.00
Pros: free
Cons: will see
Recommended? Yes
Comments: get it for free,if it is good or not i will see in the next weeks
markymarc
markymarc's Reviews
12-11-2011, 12:33 PM
Price: $1,400.00
Pros: it looks the same as the rusty
Cons: i havent found one yet other than the shocks are not the best
Recommended? Yes
Comments: really good quality i only went with a 2.5" cuz im running 35's and 37's next year with homemade tube fenders
2003X
2003X's Reviews
05-02-2011, 11:42 PM
Price: $765.00
Pros: Massive joints, no welding, bolts to the frame. You can add this to pretty much any short arm lift kit. Rides 10x's better then a short arm kit.
Cons: None.
Recommended? Yes
Comments: For the price it cant be beat. Very happy with my purchase. I added a Undercover Fabworks extra-clearance skid plate to it. The two corners had to be cut to fit around RC's brackets but it tucks up nicely. My exhaust did not interfere with the kit. The ride is great. A very good product for a wheeler on a budget. I added this upgrade kit to my Series II RC kit.
ThreadForumRepliesLast Post
Rough Country - Rough Country 6" Long Arm Kit Complete Lift Kits 8 11-24-2016 10:32 PM
Rough Country 4" Rough Country Suspension Lift Complete Lift Kits 150 09-26-2016 02:22 PM
Rough Country Rough Country 2.2 Shocks Shocks 38 05-29-2016 02:31 PM
Rough Country - Rough Country 4" Long Arm Kit Complete Lift Kits 15 01-25-2016 10:42 AM
Rough Country - Rough Country Bar Pin Eliminator Kit Shocks 1 01-08-2010 02:30 PM
