Rough Country 4" X-Series Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $900.00
Average Price: $748.88
Manufacturer: Rough Country
Recommended?
Yes: 119 / No: 9
Front and rear coil springs, front and rear upper and lower adjustable control arms, transfer case drop kit, front and rear track bar drop brackets, swaybar quick disconnects, power steering pitman arm, and 4 Heckethorn Nitro 9000 series shocks.
- 100% Bolt-On Installation, no cutting/drilling/welding
- Includes Rough Country's revolutionary rear coil spring
design to counter-act passenger side coil fatigue.
- Ride quality remains as stock
- Fits 33" tires with no rubbing or trimming of the fender well
- Kit is upgradeable with Rough Country's Jeep X-tras..
None
Page 4 of 7 1 2 3 4 5 6 7 > Last
chutta
chutta's Reviews
11-23-2009, 07:47 PM
Price: $900.00
Pros: price
Cons: threaded sleeved arms
Recommended? No
Comments: Other than 2 failed LCA's that stripped out the internal adjustment threads causing axle movement and kLUNKS, all is well after went to hydro shocks.
Kit has been superceded by one with heim joint/jamnut arms. Get it
CadyRyan86
CadyRyan86's Reviews
11-20-2009, 04:58 PM
Price: $999.00
Pros: Adj. Control arms, 2.2 option, RC customer service and the price
Cons: none so far
Recommended? Yes
Comments: Straight forward install, good product
weinbern
weinbern's Reviews
09-20-2009, 10:44 PM
Price: $1,300.00
Pros: 4" of lift, Cheap
Cons: paint chips, bushings squeek, and disco are a pain the neck
Recommended? Yes
Comments: 1300 bucks after upgraded shocks, stabilizer, and CV Drive shaft. 4" of lift for 1300 bucks and comes with JJ adjustable control arms. Not too shabby. Couple issues with the lift but over all not a bad product at all.
Mrozandy
Mrozandy's Reviews
08-21-2009, 07:22 PM
Price: $500.00
Pros: This was an inexpensive way to get some bigger tires to fit. I love the 2.2 series shocks. Easy to install. Customer service is awsome.
Cons: Front track bar bracket is hard to keep tight. I don't use it any more but my buddy had to have his welded. The kit uses all factory links (control arms, track bars). The caster bolts for the lower control arms don't provide enough adjustment.
Recommended? Yes
Comments: From the begining I planned on this lift kit being a starting point. I wanted to fit 35's under my jeep cheaply, without cutting of factory mounts or welding anything. The coil springs are good and I can tell you they compress very well, this kit is surprisingly flexy for a cheap lift. I LOVE the 2.2 shocks, they look cool and seem to work very smoothly. I added the 2.2 series dual steering stabilizer and like it as well. I would reccomend you plan on buying some adjustable lower control arms and at least an adjustable rear track bar ( this will still cost less than most other lift kits and you will like the result). I did'nt get it, but my buddy with the same lift kit got death wobble due to the caster not being adjustable enough. And with the rear trackbar relocation bracket in place my axle was noticably off to the driver's side, without it my axle is slightly off to the passenger side making it hard to get a good alignment.
arjunanand1
arjunanand1's Reviews
08-13-2009, 10:27 PM
Price: $1,500.00
Pros: Great price, great kit and excellent lift. Flexes well.
Cons: Slightly on the stiff side.
Recommended? Yes
Comments: Nothing can beat RC's price for the 4" lift kits.
SDT03GCOverland
SDT03GCOverland's Reviews
08-11-2009, 11:44 PM
Price: $450.00
Pros: Cheap.
Cons: Track bar drop bracket. Very stiff ride.
Recommended? Yes
Comments: Perhaps you get what you pay for and this being the cheapest complete 4 inch on the market...
Issue 1: The rear upper shock bushing-washer units were too long. I had to cut 1/2 inch off in order to match the picture on the inventory sheet and get them to fit correctly.
Issue 2: The additional bolt needed to keep the track bar drop bracket can NOT be made tight enough so as to not wiggle and I have to tighten it after every 30 miles or so. This results is a "spongy" steering feel and one single instance of severe death wobble. I've already ordered a JKS adjustable track bar to resolve this issue. Even with the additional cost of the JKS track bar, the kit is STILL well below the cost of any other kits I've found for the WJ that come with a new track bar.
ryancarlson123
ryancarlson123's Reviews
07-31-2009, 10:19 AM
Price: $550.00
Pros: cheap
Cons: not that great of shocks and no boots
Recommended? Yes
Comments: if you want a cheap suspension lift, thats the one to get
Irockatgms
Irockatgms's Reviews
03-21-2009, 11:47 PM
Price: $900.00
Recommended? Yes
Comments: Great lift, not anything like a friend of mine who had the 4" skyjacker lift the rear right sock started to collapse instantly, this holds up well, and fantastic flex
gabriel05
gabriel05's Reviews
03-12-2009, 02:50 PM
Price: $500.00
Recommended? Yes
Comments: Over all this is a decent kit to start with. The only complains I have is it ride pretty harsh, that is to be expected with a 4" short arm lift though. Also the track bar relocation brackets left something to be desired, I recommend getting adjustable trackbars.
jason0923
jason0923's Reviews
03-12-2009, 03:10 AM
Pros: CHEAP
Cons: ROUGH
Recommended? Yes
Comments: AWSOME BUT SHOCKS SUCK
jason0923
jason0923's Reviews
03-12-2009, 02:29 AM
Price: $900.00
Recommended? Yes
Comments: really nice kit complete comes with damn near everything but ive had trouble keeping bushings in my shocks i whish i would have upgraded but they didnt have the 2.2 s in stock at ntl
justooln2
justooln2's Reviews
03-10-2009, 07:17 PM
Price: $850.00
Recommended? Yes
Comments: Great bang for your buck.. No tire rub with 33X12. Not the best quality but I would install it on a friends Jeep now. One day install with regular garage minds and tool.
Havin-fun-N-TN
Havin-fun-N-TN's Reviews
03-04-2009, 11:48 AM
Price: $800.00
Recommended? Yes
Comments: This lift functions well for the little bit I go off road. My Jeep may see the rocks and mud 4 or 5 times a year.
2003X
2003X's Reviews
01-24-2009, 08:15 PM
Price: $529.00
Recommended? Yes
Comments: Gave me more then 4" of lift. Needs better shocks. But I am very pleased with it.
04wrangler221
04wrangler221's Reviews
01-04-2009, 11:36 PM
Price: $800.00
Recommended? Yes
Comments: Most people say its not good but i have yet to have a problem i like it and it fits in a tight budget!
Jumphog
Jumphog's Reviews
01-01-2009, 11:09 AM
Price: $400.00
Recommended? Yes
Comments: I needed a heavier set of springs when I mounted my winch/tire carrier, so went with the heavy duty. Ride is still good, but as expected, a little stiff. Like it offroad
jeff83
jeff83's Reviews
12-27-2008, 01:56 PM
Price: $500.00
Recommended? Yes
Comments: Love this kit can't beat it for the money just deffinatly fet the 2.2 shocks because the stock ones suck
mikekelly77
mikekelly77's Reviews
12-16-2008, 10:04 AM
Price: $300.00
Recommended? Yes
Comments: Rough on road, great off it. Would reccomend to someone who will be wheeling and does not need tons of atriculation.
Camo Deere
Camo Deere's Reviews
12-07-2008, 02:17 PM
Price: $499.00
Recommended? Yes
Comments: The kit is the best bang for the buck IMO, it gave me more than enough clerance for my 33s, the shocks are a bit stiff, I would recommend the shock upgrade for a smoother ride but besides that, it's a great lift, no problems yet
jeepin_98
jeepin_98's Reviews
11-25-2008, 12:17 PM
Price: $350.00
Recommended? Yes
Comments: I have been very happy with this lift, it performes well and have had no problems for any of it. Plus with the lifetime warr rough country gives shouldnt have any problems
ThreadForumRepliesLast Post
Rough Country - Rough Country 6" Long Arm Kit Complete Lift Kits 8 11-24-2016 10:32 PM
Rough Country 6" X-Series TJ lift Complete Lift Kits 20 03-27-2016 09:49 PM
Rough Country - Rough Country 4" Long Arm Kit Complete Lift Kits 15 01-25-2016 10:42 AM
Rough Country 4" Series II Complete Lift Kits 109 05-11-2015 09:39 PM
Rough Country Suspension Systems 1997-06 Jeep TJ 4" X-series Suspension (redesigned) Complete Lift Kits 6 04-07-2012 05:34 AM
