Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Rough Country 4" Series II
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Rough Country 4" Series II Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $1,300.00
Average Price: $535.98
Manufacturer: Rough Country
Recommended?
Yes: 96 / No: 2
4" Series II Suspension lift
Page 1 of 5 1 2 3 4 5 > Last »
MoSutty
MoSutty's Reviews
01-11-2012, 03:09 PM
Price: $660.00
Pros: Easy install, great customer service, looks great.
Cons: A little squeaky and noisy.
Recommended? Yes
Comments: My cousin and I put it on working 2-3 hours a night for 4 nights. As we were finishing the rear of the vehicle we noticed we were short a set of bushings. Called Rough Country at 3 pm on a Thursday the parts were there by 10 am Friday. Got the steering stabilizer and nitro shocks upgrade. Had it on for close to six months now, so far no problems with the lift kit.
sevenscrew
sevenscrew's Reviews
01-02-2012, 08:33 PM
Price: $600.00
Pros: Looks Great, Great quality
Cons: Instructions fail to tell you all the tools you will need before you start, causing you to run out and delay the project
Recommended? Yes
Comments: Instructions did not include at the beginning that you would need a 11/32 drill bit and coil compressor under the "Tools needed" both these made me run out twice..
kbman
kbman's Reviews
11-17-2011, 05:52 PM
Price: $700.00
Pros: easy install great bang for your buck
Cons: none
Recommended? Yes
Comments: i dont care what anyone says the rides not tht bad its a jeep get over it
i recomend purchasing brakelines, drop pitman arm, and adj trac bar
steering is great no wandering besides my tires
straight forward install no complaints
Outdoors
Outdoors's Reviews
11-15-2011, 09:21 AM
Price: $499.00
Pros: Ride much smoother, these reviews for the series II UPDATES were not in effect until sometime after MAY,2011.
Cons: rear upper shock mount slid out of it's bushing, reinstalled no problem. Rear track bar bracket bolts backed out replaced with nylocks no problems now.
Recommended? Yes
Comments: People talk about it not being a complete kit? Consider this a lot of other "complete" kits do not come with shocks.. This kit does come with decent shocks.
I do Recommend a JKS or similar adjustable front track bar. Also purchased some 2" bumpstops and JKS discos too. Consider getting YJ front brakelines at least too.
The ride I'm getting out of this kit since June is really nice and smooth, I have owned a BDS, RE kits and this kit on road is better riding then EITHER KIT for me. OFF road the RE kit is better no illusions here. For the price range this kit is it.
tycal
tycal's Reviews
09-01-2011, 08:04 PM
Price: $450.00
Pros: Cheap, included everything needed but front disco's for the beginning/moderate jeeper. Shocks/springs ride GREAT!
Cons: upper bushings in rear shocks easily slide themselves out. Had to install upper bar pin eliminators
Recommended? Yes
Comments: CS is great and responsive. Shocks/spring rates are really great and beat out my $1k skyjacker kit for ride and driveability(on road). Flexes nearly as much with the rubber bushings as my value flex skyjacker kit did with the heim joints.
with the 4" lift, you will most likely need a 1" mml or go the sye/cv d-shaft route to keep your vibrations down.
blah402
Jeep Addict
blah402's Reviews
07-07-2011, 10:41 AM
Price: $555.00
Pros: Fairly easy to install. 4 inches of awesomeness
Cons: Instructions could of included detailed photos with all steps.
Recommended? Yes
Comments: Very nice lift for the price.
ronks97
ronks97's Reviews
05-13-2011, 07:22 AM
Price: $500.00
Pros: amount of lift
Cons: no tracbars and the rear bracket is poorly designed
Recommended? Yes
Comments: it took a full day because it was my first lift install and i wouldnt recomend the indtructions because its much harder getting the springs in the way they explained how to do it i just dropped all control arms then put the springs in and was ready to go
PeeWeeHerman
PeeWeeHerman's Reviews
04-18-2011, 05:49 PM
Price: $800.00
Pros: Easy install for novice.
Cons: Rough Ride
Recommended? Yes
Comments: Included Shock Upgrade, Adjustable Front Track Bar, Drop Pitman Arm(not used), and Performance Steering Stabilizer. I like Rough Country stuff a lot, I'm not a hardcore wheeler, but plan on doing a good amount. The price and customer service is great on from RC. The kit should include all new hardware even if it costs a couple more bucks and new brake lines.
teamhirev
teamhirev's Reviews
04-11-2011, 01:13 PM
Price: $500.00
Pros: Complete with everything needed
Cons: A little rough
Recommended? Yes
Comments: Bought this lift since it was very affordable. Rides okay a bit rough but I didn't by my jeep expecting a smooth suspension anyways.
bbunchjeepers
bbunchjeepers's Reviews
04-04-2011, 07:28 PM
Price: $499.95
Pros: easy to install, rides good
Cons: none so far
Recommended? Yes
Comments: never had done any kind of suspension lift before this one. It was easy to install with the directions pretty clear and straight forward. The ride is good and handles great. Zero wobbles or any other kind of issues
mcgoo26
mcgoo26's Reviews
03-23-2011, 12:43 PM
Price: $499.00
Pros: None yet
Cons: None yet
Recommended? Yes
Comments: I just purchased the lift and have not installed it yet. I will post what I find after I take it out.
Drix
my other ride is an F-250
Drix's Reviews
03-15-2011, 11:36 PM
Price: $1.00
Pros: LIFT
Cons: Bit Rough on the Tush.
Recommended? Yes
Comments: Purchased my YJ with the lift I have no comparison to stock from it.
JAGGERTS
JAGGERTS's Reviews
03-01-2011, 02:29 PM
Price: $749.00
Pros: Gobs of clearence!!
Cons: Dint come with upper control arms
Recommended? Yes
Comments: Love it!! It is a great lift, the only down fall is that it dint come with upper front CAs
Cavguy1965
Old Cavalry Trooper
Cavguy1965's Reviews
02-22-2011, 05:42 AM
Price: $1,000.00
Pros: inexpensive, esay to install
Cons: none really
Recommended? Yes
Comments: I am going to the long arm conversion soon but great lift for the money.
4WheelingPlus.c
4WheelingPlus.c's Reviews
01-28-2011, 03:00 AM
Price: $459.00
Pros: Easy install, includes WAY more stuff (for the price) than other companies do. Easy to upgrade if I want to.
Cons: na
Recommended? Yes
Comments: Love this Rough Country 4.5" lift kit.
foxrider2f
foxrider2f's Reviews
01-23-2011, 04:42 PM
Price: $550.00
Pros: Value, ride height
Cons: no track bar relocator for front, PITA to put on rear lower control arms
Recommended? Yes
Comments: Great lift and the most complete lift I could find in the price range I was looking for. It seems to get a little stiff when it is cold outside. The front sway bar hits my frame making a popping sound because i need to upgrade to a adjustable track bar. Overall i am very satisfied
motorcycle2
motorcycle2's Reviews
12-30-2010, 10:24 PM
Price: $300.00
Pros: Good hardware
Cons: Cheap shocks.
Recommended? Yes
Comments: Decent hardware and flex. Extend your brake lines by using stock YJ front brake lines.
Ride is very stiff. Suggest new shocks.
andrewk
andrewk's Reviews
11-25-2010, 06:03 PM
Price: $599.00
Pros: great for off road
Cons: too soft for on road
Recommended? No
Comments: the lift was on the jeep when I bought it.. I don't like it.
I want a more stable ride going down the road. since I won't be going off road anytime soon,will be switching back to stock.
gattaca37
gattaca37's Reviews
10-16-2010, 06:33 PM
Price: $639.00
Pros: lift, upgrade shocks 2.2, and front sway bar disconnects delivered to my house for 639. installed very easily
Cons: told didn't need SYE kit by rough country's rep, I need the SYE kit
Recommended? Yes
Comments: Installed easily and flexes nice, just wasnt expecting to have to purchase SYE kit. 1 customer rep said nope should be fine, i purchase and install and have some binding issues. I call back to rough country and talk with 2 other reps and they say they strongly recommend it. Sales are based on commision! Overall I am happy with the lift, just have to get few more parts and she is done.
Meep97
Meep97's Reviews
10-05-2010, 04:50 PM
Price: $590.00
Pros: easy to install, looks good
Cons: starting to sag, shocks are rough unless you have weight on them
Recommended? Yes
Comments: the lifetime warranty is great, cheap price, looks good, shocks are pretty rough but if you add some weight not so bad, starting to sag a little but overal pretty good for price
ThreadForumRepliesLast Post
Rough Country 6" X-Series TJ lift Complete Lift Kits 7 12-07-2011 03:26 PM
Rough Country 4" X-Series Complete Lift Kits 97 05-05-2011 09:01 PM
Rough Country - Rough Country 4" Long Arm Kit Complete Lift Kits 2 11-19-2010 12:47 AM
Rough Country - Rough Country 6" Long Arm Kit Complete Lift Kits 0 11-01-2009 12:16 PM
Rough Country Suspension Systems 1997-06 Jeep TJ 4" X-series Suspension (redesigned) Complete Lift Kits 4 03-07-2009 11:46 PM
Glock Forum
