Notices
Rough Country 4" Rough Country Suspension Lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $650.00
Average Price: $513.77
Manufacturer: Rough Country
Recommended?
Yes: 134 / No: 16
Just put this lift on installation was a breeze and came with everything needed rides good and easily clears 33s
None
Page 3 of 8 1 2 3 4 5 6 7 8 > Last
JeepJustin
JeepJustin's Reviews
04-30-2012, 05:10 PM
Price: $500.00
Pros: Great lift with a decent ride!
Cons: none
Recommended? Yes
Comments: great lift i should have just went with a 6 inch long arm kit though..
martinrof
martinrof's Reviews
04-06-2012, 10:17 PM
Price: $500.00
Pros: good tire clearance
Cons: none
Recommended? Yes
Comments: I installed a 4" Rough Country suspension lift kit after getting it by UPS in 1 week after ordering it. It was easy to install and came with all the instructions. The clearance I got after the install was awesome, because my stock lift was so worn down , the springs were almost flat. I would like to install another one one day if I had the chance.
ekillionc9
ekillionc9's Reviews
03-29-2012, 10:49 PM
Price: $400.00
Pros: Easy, simple, straight forward installation. Good looks for not alot of price.
Cons: Rough ride. Utilizes stock lower hardware for front sway links.
Recommended? Yes
Comments: i really liked the rough country 3.5 Fr swap kit I installed. It went together very easily and the directions worked to a t. I would recommend also always replace coil spring isolaters that have severe wear on them as mine were. It does ride a wee bit stiffer but I sure do look good doing it.
cmurr03
cmurr03's Reviews
03-28-2012, 02:27 PM
Price: $500.00
Pros: Able to fit 285/75 15 with minimal trimming
Cons: The track bar drop bracket was a POS. It was no where near strong enough and begin cracking from day 1. After tightening, it began to crack my chassis. Finally had to weld it in place. Customer service at Rough Country was horrible and rude.
Recommended? No
Comments: The track bar drop bracket was a POS. It was no where near strong enough and begin cracking from day 1. After tightening, it began to crack my chassis. Finally had to weld it in place. Customer service at Rough Country was horrible and rude.
mikesloudjeep
mikesloudjeep's Reviews
02-29-2012, 08:17 PM
Price: $500.00
Pros: It will lift the jeep. lol
Cons: High gravity who would have thunk. Pillow mounts to the upper shocks to soft they brake off while wheeling.
Recommended? Yes
Comments: Great bang for buck. Expext to blow things out if you're planning on really working this lift. For a daily driver to show off this is great. I learned you get whet you pay for. I'd still buy it. Just get some back up parts.
topalmer4
topalmer4's Reviews
02-19-2012, 12:25 AM
Price: $500.00
Pros: great price excelent lift and smooth ride
Cons: it is rough country you get what you payed for
Recommended? Yes
Comments: It is actually quite smoothe and the lift is a complete package.
chevypowered
chevypowered's Reviews
02-18-2012, 01:59 PM
Price: $423.00
Pros: inexpensive, easy installation
Cons: very rough ride
Recommended? Yes
Comments: great lift for the price
player101
player101's Reviews
02-09-2012, 08:38 AM
Price: $750.00
Pros: way more clearance for off roading, looks great, allows bigger tires
Cons: havent had any problems yet
Recommended? Yes
Comments: installing lift kit allowed me to be able to put on 33.5" x 12.5" mickey thompsons mtz baja's!
Coffeeman99
Coffeeman99's Reviews
02-08-2012, 08:06 PM
Price: $1,050.00
Pros: It's a lift. Price included installation and steering stablizer
Cons: none.
Recommended? Yes
Comments: Looks good, rides smoother than stock, better clearance and room for 33's.
ClarkJeeps
ClarkJeeps's Reviews
01-24-2012, 07:50 PM
Price: $500.00
Pros: Rides well
Cons: Death wobble like a bitch
Recommended? Yes
Comments: Rides fine the death wobble is very irritating but most wj's get it unless you get the parts you need like adjustable track bar, steering stabalizer, ect. so i highly recommend getting the x series its cheaper and you'll end up having to get all of it later anyways. unless you're really lucky!
26679cj7
26679cj7's Reviews
01-23-2012, 07:10 PM
Price: $479.00
Pros: good fit
Cons: none
Recommended? Yes
Comments: I love the rough country lift kit .The ride is just right and no sag after 2 years.thanks rough country for a good product.
rick700raptor
rick700raptor's Reviews
12-24-2011, 03:46 PM
Price: $500.00
Pros: good kit good price. thick material, correct geometry, it needs the lower front control arms. Coil shims in rear are also needed.
Cons: shocks are on the soft side
Recommended? Yes
Comments: This is a good kit. I had a lot of other suppliers dis. this kit, yet their kit didnt have some of the items this kit had and some at 3 times the price, like the Mopar kit.
One guy said the material is to thin, not true they changed the kit to thicker material. Lower control arms, rear coil shims, Pittman arm, everything for correct geometry.
This is the 3.5 kit, the drop down did not show this newer kit.
My only complain about this kit would apply to all the other kits I have seen and that is it need the rear coil spring clamp added. Its only a $25.00 part, but I have seen JKs on the trail with a coil spring laying on the ground when flexed. No matter what kit you run, add the rear coil spring clamps to clamp the rear coils to the axle!.
dirtysanchezatv
dirtysanchezatv's Reviews
12-23-2011, 06:44 PM
Price: $400.00
Pros: Complete kit, very reasonable price.
Cons: Control arms not adjustable
Recommended? Yes
Comments: It is a very complete kit. I wished I would have gotten a long travel kit, but this one does well for the amount of off-roading I do.
canesfanken
canesfanken's Reviews
12-22-2011, 05:52 PM
Price: $600.00
Pros: NONE!
Cons: EVERYTHING!
Recommended? No
Comments: I've replaced damned near the whole kit after a year and a half due to it being crappy! And R/C will not replace any of the defective parts and blame stuff on a bumper/winch. Save your money and buy a quality lift!
NIYJ
NIYJ's Reviews
12-10-2011, 05:06 PM
Price: $499.95
Pros: Easy to install in the driveway
Cons: nothing yet
Recommended? Yes
Comments: Threw it on in the driveway. I don't think the Jeep came from Indiana due to being able to remove all of the bolts and nuts by hand. I put all new bolts back in to eliminate any problems. Had it on for 2 months and not even a squeek.
SwampFox375
SwampFox375's Reviews
11-01-2011, 02:24 PM
Price: $1.00
Pros: great starter kit
Cons: not the best
Recommended? Yes
Comments: great kit for the price. if you dont do extreme offroad activities in your jeep but want the nice aggressive looking lift, this kits for you.
secretspy711
secretspy711's Reviews
10-21-2011, 11:16 AM
Price: $499.95
Pros: Good price for a lift kit. Rides like I would expect. Not much body roll in turns.
Cons: uses cam bolts instead of adjustable control arms.
Recommended? Yes
Comments: Installed when I bought the jeep, so far I can't complain. Has cam-bolts to adjust the caster, and mine need to be adjusted, but I may need adustable lower control arms as well because the steering wanders a bit.
thegladiator
thegladiator's Reviews
09-26-2011, 11:03 AM
Price: $439.00
Pros: good price
Cons: none yet
Recommended? Yes
Comments: Good price for the lift. I've been deployed hope to drive it soon.
RubiconChris
RubiconChris's Reviews
09-21-2011, 09:59 AM
Price: $500.00
Pros: cheap
Cons: junk
Recommended? No
Comments: gave me death wobble
98cherrypopper
98cherrypopper's Reviews
09-11-2011, 09:54 PM
Price: $500.00
Pros: cheap lift that looks good and good clearance
Cons: rides a little rough.
Recommended? Yes
Comments: i like the lift, didn't have a lot of money so went cheap. if you have the money don't buy it.
ThreadForumRepliesLast Post
Rough Country - Rough Country 6" Long Arm Kit Complete Lift Kits 8 11-24-2016 10:32 PM
Rough Country 4.5 inch suspension lift Complete Lift Kits 45 04-08-2016 10:22 AM
Rough Country - Rough Country 4" Long Arm Kit Complete Lift Kits 15 01-25-2016 10:42 AM
Rough Country YJ 4" Suspension lift Complete Lift Kits 113 10-15-2014 06:06 AM
Rough Country yj 2.5" suspension lift kit Complete Lift Kits 21 04-13-2014 07:15 AM
