Notices
Rough Country 4" Rough Country Suspension Lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $650.00
Average Price: $513.77
Manufacturer: Rough Country
Recommended?
Yes: 134 / No: 16
Just put this lift on installation was a breeze and came with everything needed rides good and easily clears 33s
None
Page 1 of 8 1 2 3 4 5 6 7 8 > Last
Dougan2469
Dougan2469's Reviews
09-26-2016, 04:22 PM
Price: $500.00
Pros: Rides like stock suspension if installed correctly.
Cons: Powder coated lower control arms chip easily. Would rather them be painted for easy touch up.
Recommended? Yes
Comments: I have had this lift installed for three years and it is holding up to the abuse surprisingly well for an inexpensive lift. I also installed new u joints and ball joints and front hubs at the time of instillation. If you are still running a stock steering stabilizer NOW is the time to change it.
Shader
Shader's Reviews
02-18-2016, 08:52 AM
Price: $1,500.00
Pros: Great all-around package for the price.
Cons: Would be nice to have beefier sway arms included in kit. A little noisy in front with quick disconnects.
Recommended? Yes
Comments: Great Kit with excellent articulation and all the major suspension components in one package.
thetolleyman
thetolleyman's Reviews
12-02-2015, 10:22 PM
Price: $500.00
Pros: Inexpensive, fairly complete.
Cons: Not the highest quality.
Recommended? Yes
Comments: Good kit for the price. You get what you pay for.
bam678910
bam678910's Reviews
10-01-2015, 02:58 PM
Price: $500.00
Pros: Lift was easy to install.
Cons: Threw off the steering geometrey greatly. All drop brackets failed and were replaced with adjustable components.
Recommended? No
Comments: If you plan on lifting a WJ have enough money to lift it twice because there is much more involved than simply lifting the truck. At 4" of lift I would recomend replacing all the tierods, balljoints, tracbar, dont use the drop brackets, driveshafts. This all depends on the state of your components but if you plan on doing more than just mallcrawling this is what you should do.
ikiltme
ikiltme's Reviews
07-29-2015, 07:41 PM
Price: $750.00
Pros: See review.
Cons: None yet!
Recommended? Yes
Comments: As advertised, this lift kit didn't cause any issues with highway handling and ride. The install allowed for factory ball joint orientation to prevent frequent wear and maintained "auto centering" of steering wheel.
imthejason
imthejason's Reviews
06-12-2015, 10:53 PM
Price: $1,500.00
Pros: Cheap
Cons: Cheap
Recommended? Yes
Comments: Was on the JK when I bought it. Has held up well
meatmarketwj
meatmarketwj's Reviews
12-08-2014, 06:11 PM
Price: $799.00
Pros: get lifted
Cons: needed to move axle forward, upgrade to dual cardigan.
Recommended? Yes
Comments: Loved it, easy to install on a lift, just be aware you will need to move your axle forward an inch with adjustable upper control arms.
Chase58
Chase58's Reviews
11-22-2014, 12:05 AM
Price: $500.00
Pros: It lifts for clearance
Cons: If you have a soft top it will look like a stink bug and a pretty rough ride
Recommended? No
Comments: I cannot relate with the hard top crew but with a soft top it's a pretty rough riding suspension kit. With the soft top and no other "extra" weight on the tail (i.e. heavy bumper, heavy spare with carrier etc.) the rear is too high. Maybe with those options it might ride better.
Bobbyreb97
Bobbyreb97's Reviews
08-03-2014, 11:08 AM
Price: $500.00
Pros: stable ride
Cons: hard to install tough ride
Recommended? Yes
Comments: Took like two days to put in because of all the rot on my jeep but a stable great ride. I like it a lot
befirst
befirst's Reviews
08-02-2014, 11:15 PM
Price: $649.00
Pros: Price. Springs give good ride. Fixed lower control arms fix castor.
Cons: Junk track bar drop bracket.
Recommended? No
Comments: The kit when on fairly easy. The track bar drop bracket is cheap and a waste of time. The only thing you will get from using the drop bracket is wobble and wallered out bolt holes on the original track bar mount. The only pieces of the kit that will likely remain on the jeep are the springs and bump stop lowering blocks. I already (1 month in) removed the drop bracket and installed a JKS track bar. I will be replacing the new lower arms (front) when I can with adjustables ( not RC). I am fixing to replace rear lowers and upper first, then return to finish the front. If I was going to do it again I would spend the money and do it right the first time. Problem was I didnt know what was right until I saw what was wrong. Bought kit off of craigslist new in box for $300.
tj06MosesNeri
tj06MosesNeri's Reviews
06-02-2014, 11:33 PM
Price: $499.00
Pros: Affordable and looks real good with 32 or 33 tires
Cons: If you have a 6speed. You got to modified the linkage to the transfer case the lift and the modification will run you 650$
Recommended? Yes
Comments: Jeep suspension lift it's affordable. It's basic the only thing you need to get extra is if you have a 6th speed jeep. It is a linking modification. You can find these at any off roading shop you know.
fohringer89
fohringer89's Reviews
04-09-2014, 09:21 AM
Price: $500.00
Pros: Cheap affordable lift
Cons: Gas prices
Recommended? Yes
Comments: 4 rc lift rides nice. I like the price and the stance. Seems to handle well on and offroad.
kydoghunter
kydoghunter's Reviews
03-08-2014, 09:14 PM
Price: $500.00
Pros: its a lift
Cons: rough ride
Recommended? Yes
Comments: Lift seems to be ok. Upgrade shocks is a must for a good ride
01Stormtrooper
01Stormtrooper's Reviews
02-18-2014, 06:13 PM
Price: $500.00
Pros: good height and clearance
Cons: none yet
Recommended? Yes
Comments: no problems yet, eventually switching all components to IRO
Max_1999_Sahara
Max_1999_Sahara's Reviews
02-08-2014, 02:04 PM
Price: $500.00
Pros: Much better ride than I was led to believe it would have. I added their double steering stabilizer and front track bar relocation bracket, as they're pretty much needed and not included. Total price was $700.
Cons: Not much for the price, it could be better if I paid more. It gets me over 33's and I can always upgrade as needed.
Recommended? Yes
Comments: This lift kit seems to be pretty decent. My jeep won't see much hardcore use so I didn't spend a lot initially. The base shocks aren't as bad as some claim. They are a little firm, but still comfortable on old country roads. Not the fault of the lift, but the included TC drop did not cure my vibes. Looking into SYE and CV shaft now. Just beware that this may be required when you start budgeting.
Scubby
Scubby's Reviews
12-13-2013, 05:21 PM
Price: $400.00
Pros: its strong and does the job
Cons: Extra bumpy, even for a jeep
Recommended? No
Comments: It works fine and definitely does the job as advertised. Its a fine kit and comes with everything that is needed, but It does ride extra rough, even for being a jeep. Get a kit that is better quality with springs that are softer.
love2offroad
love2offroad's Reviews
10-05-2013, 01:46 AM
Price: $399.99
Pros: Works like advertised
Cons: have to drill hole for track bar or get adjustable for front
Recommended? Yes
Comments: I love my lift. My jeep looks 10x better with it. It does ride a little stiffer, but within a week or so you get used to it and don't even notice a difference
Jaymes1980
Jaymes1980's Reviews
08-05-2013, 09:08 PM
Price: $700.00
Pros: Good springs
Cons: very bad front end drop down mount for the track bar. Its very small and flexes a lot.
Recommended? No
Comments: I had a hell of a time installing the lift, for i had never done it. All in all its a good lift to start with and learn from.
Laxplaya3358
Laxplaya3358's Reviews
07-24-2013, 10:00 PM
Price: $500.00
Pros: smooth ride
Cons: none
Recommended? Yes
Comments: Smoother than factory springs and shocks recommend installing a steering stabilizer helps a lot.
givingtheheat
givingtheheat's Reviews
07-17-2013, 03:29 PM
Price: $500.00
Pros: Cheap
Cons: None
Recommended? Yes
Comments: Decent
ThreadForumRepliesLast Post
Rough Country - Rough Country 6" Long Arm Kit Complete Lift Kits 8 11-24-2016 10:32 PM
Rough Country 4.5 inch suspension lift Complete Lift Kits 45 04-08-2016 10:22 AM
Rough Country - Rough Country 4" Long Arm Kit Complete Lift Kits 15 01-25-2016 10:42 AM
Rough Country YJ 4" Suspension lift Complete Lift Kits 113 10-15-2014 06:06 AM
Rough Country yj 2.5" suspension lift kit Complete Lift Kits 21 04-13-2014 07:15 AM
