Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Rough Country 4.5" XJ
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Rough Country 4.5" XJ Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $755.00
Average Price: $569.68
Manufacturer: Rough Country
Recommended?
Yes: 31 / No: 0
4.5" lift for XJ
Page 1 of 2 1 2 > Last »
TimmyTattooXJ
TimmyTattooXJ's Reviews
02-13-2011, 04:20 PM
Price: $250.00
Pros: Great Flex and easy install
Cons: Not high enough
Recommended? Yes
Comments: Great overall lift. Have yet to have a problem with the lift.
katuah
Namaste, y'all.
katuah's Reviews
12-27-2010, 12:28 PM
Price: $700.00
Pros: Full leaf kit at an affordable price, great customer service
Cons: Stiff! Could use better shocks.
Recommended? Yes
Comments: This is a great bolt-on kit at a very affordable price for full leafs. It's not going to be as cush as one of the more expensive kits, but it's a great place to start.
mmachac
mmachac's Reviews
11-16-2010, 12:03 PM
Price: $460.00
Pros: good lift with everything thats needed
Cons: none
Recommended? Yes
Comments: it took me about 8 hours to lift it my self. the front also has a 1.75" coil spacer to level out the front. right now the front and rear are sitting 6" taller then stock. have no problems with really good flex. no front sway bar.
MoeGravey
The Lost Boys
MoeGravey's Reviews
10-05-2010, 06:22 AM
Price: $550.00
Pros: Great lift, Bolts in. (1st timers, make sure you have free time)
Cons: First couple months will be a stiff ride,
Recommended? Yes
Comments: I purchased the 4.5" RC kit with Full Rear leaf springs, 2.2 Hydro shocks and Steering stabilizer (recommended). The kit is very easy to put in once you know what you are doing. As a forewarning, PB Blast EVERYTHING!! for weeks before hand. It will save you the time and frustration. The instructions in the box were kind of vague, but crawling JP makes up for it. Be sure to have 1 spare set of arms. (i found having 2 spares was a waste of time, and led to drunkiness)
Wup This
Wup This's Reviews
08-10-2010, 08:56 PM
Price: $800.00
Pros: I opted for the X series lift with full rear springs. Includes ALL the parts you need. disco's included. Great price. BEEFY LCA and UCA's. EXCELENT customer support.
Cons: The grease fittings on the front are absolute junk...go to the store and buy new ones. 3 dollars well spent and I have extras now. The shocks that come with the lift are REAL stiff. The rear shackles are put at an angle that makes them contact the mount which will limit travel. No new bump stops with kit...not a big deal because everyone's needs in this area will vary a bit. Could've used some new hardware for CA's and trackbar.
Recommended? Yes
Comments: I opted for the X series lift with full rear springs. The kit was very nice and came with all the parts necessary to complete the lift....even stainless brake lines. The lift was a beast to install because of the age of the XJ and the crummy stock fasteners. The ride is OK but I recomend upgrading to the 2.2 or another brand of shocks. Fit was very good and overall quality of the lift is way better than I expected. Be patient with your brake lines as this was one of the harder parts of the lift to get done because of the XJ rusted OEM lines. Overall a GREAT lift at a GREAT price. I have had it on for several months and I am very please. I put 32's as recommended with 3.75 offset. I had to trim a little and ditch the front inner plastic wheelwells. I would also HIGHLY recommend a SYE as I still have vibes. I also ditched the rear sway bar and haven't looked back!
Boomerang shackles, better shocks, and an SYE and this may just be the perfect short arm!!!
jbruehler
jbruehler's Reviews
08-02-2010, 04:43 PM
Price: $600.00
Pros: Nice height, all components needed where included, price.
Cons: Most of them are not the kits problem, it is from a 10 year old jeep with 150k+ miles
Recommended? Yes
Comments: Good easy install, had a horrible DW problem that was mostly cured by the allignment. A little DW remained, so I am install UCA, that unfortunately didn't come with the kit.
viking1
viking1's Reviews
07-29-2010, 02:50 PM
Price: $580.00
Pros: Great stuff!!
Cons: Nada!
Recommended? Yes
Comments: Awesome, and pretty easy install for a first-time Jeeper!
s1xty7
s1xty7's Reviews
06-25-2010, 03:01 AM
Price: $650.00
Pros: Pretty flexible, easy to install, cheap
Cons: Directions aren't always correct.
Recommended? Yes
Comments: Great lift for a great price. Every dealing I've had with the staff at Rough Country has been great. The lift went in pretty easy. Took about a week when putting it in after work and on a Saturday with a couple days off. All in all, not too bad but more than the directions say. Lots of flex with the sway bars disconnected. You really need longer brake lines and diff breather tubes as well as bump-stops with this kit. I liked the product so much, I recommended and helped install it in a friend's XJ.
rjfster
rjfster's Reviews
05-25-2010, 03:25 PM
Price: $600.00
Pros: Provides good amount of lift, flexes pretty well, upgraded to full leaf instead of aal at purchase
Cons: ride is a little stiff, but not terrible, seems to have settled quite a bit (could be my imagination)
Recommended? Yes
Comments: Great kit, deffinatly go for full leaf instead of add a leaf. Would also recomend uca's since this kit only provides lca's.
psychoteen101
psychoteen101's Reviews
04-18-2010, 02:20 PM
Price: $450.00
Pros: Very detailed instructions, parts were of good quallity, and everything seemed to line up and bolt on just fine.
Cons: As of now, im very happy with the kit.
Recommended? Yes
Comments: The kit i bought came with the add a leafs. Everything was great, nothing seemed to give me trouble on installation and i had everything i needed pretty much. I do suggest to upgrade the shocks if being driven on the street. Id also replace the front brake lines instead of using the kits relocation brackets. Also, i would upgrade to the rear leaf kit instead of add a leafs because the OE springs tend to sag.
ScottD16
ScottD16's Reviews
04-15-2010, 05:10 PM
Price: $650.00
Pros: perfect size
Cons: none
Recommended? Yes
Comments: it is a great lift fairly easy to put on love it makes extremely capable for lots of fun
jeepinmichguy_
Resident *** Hole
jeepinmichguy_'s Reviews
01-15-2010, 09:29 AM
Price: $400.00
Pros: easy install
Cons: none
Recommended? Yes
Comments: It was everything I needed to fit some 32's on the XJ. I got it on Ebay for 400 shipped. Install took about 10 hours(beer). My XJ rode better than stock when we were done. I would highly recommend.
JxC_XJ94
Junior Member
JxC_XJ94's Reviews
12-10-2009, 02:31 PM
Price: $700.00
Pros: easy install, looks great
Cons: a bit rough
Recommended? Yes
Comments: i got a bit more than 4.5in of lift and its been about a year now... becides my old rusty bolts not wanting to come fof it was easy to install, i lvoe it its great!!
lliamsdad
lliamsdad's Reviews
11-14-2009, 05:33 PM
Price: $795.00
Pros: very easy install. came with all necessary hardware
Cons: had to deal with the "death wobble" but taken care of now
Recommended? Yes
Comments: i love this lift. it is a little bit of a rough ride but thats expected. its a 4x4. it was very easy to install. got the leaf spring pack, shocks, and everything. awesome lift for the price.
weegie22
weegie22's Reviews
08-05-2009, 08:01 AM
Price: $655.99
Pros: The full leaf packs are very stiff and i wont have to worry about sagging. Of course the price.
Cons: The only con is the rough ride but i expected that i dont mind it if i did i wouldnt drive a jeep.
Recommended? Yes
Comments: I am very pleased with the RC 4.5 lift the price was great and I acutally got about 6 inches of lift and the install wasnt bad.
NiCk-
NiCk-'s Reviews
05-24-2009, 12:23 PM
Price: $697.00
Pros: Great Price, Complete Kit
Cons: Little stiff
Recommended? Yes
Comments: I got a great deal on this kit. 10% JF discount plus the shop I ordered it from was good with RC. I got a kit with the full springs, adj. trac bar, and steering stabilizer for 697
mud-dog27
mud-dog27's Reviews
05-13-2009, 12:33 AM
Price: $1,000.00
Pros: great flex,easy install,great price
Cons: little rougher than other but its a jeep so i expect it to be rough and its held up better then anyone said it would
Recommended? Yes
Comments: given the amount of haters of rough country i admit i was a little scared when i bought this kit but i went with the full leaf pack and havent had any sagging yet(3yrs) and the part i love the most as usuall is all the people who complained about the kit either never ran the kit or cheaped out and went AAL which no matter what kit you run will sag
NiCk-
NiCk-'s Reviews
05-10-2009, 09:20 PM
Price: $691.00
Pros: 10% off JF :)
Cons: None
Recommended? Yes
Comments: Got full leaf packs, adj trac bar, steering stabilizer, and shock boots for this price. I guess they gave the shop I ordered it from a few extra goodies for free . Rides fine and looks great
mattiek
mattiek's Reviews
03-10-2009, 07:15 PM
Price: $449.99
Recommended? Yes
Comments: Good kit for a good price as well. Lot of bas things said but I love it, and so do most owners. Only thing i'd recommend is the full leaf pack
brand0nlp
brand0nlp's Reviews
02-17-2009, 06:57 PM
Price: $455.00
Recommended? Yes
Comments: well the ride is great, compared to other jeeps ive been in with different lifts, on road its comfortable, but off road its great i have great articulation, i have yet to get stuck, and i got more like 5 inchs out of the front.
ThreadForumRepliesLast Post
Rough Country 4" Rough Country Suspension Lift Complete Lift Kits 46 12-22-2011 04:52 PM
Rough Country Rough Country 2.2 Shocks Shocks 15 08-14-2011 12:09 AM
Rough Country - Rough Country 4" Long Arm Kit Complete Lift Kits 2 11-19-2010 12:47 AM
Rough Country - Rough Country Bar Pin Eliminator Kit Shocks 1 01-08-2010 03:30 PM
Rough Country - Rough Country 6" Long Arm Kit Complete Lift Kits 0 11-01-2009 12:16 PM
Glock Forum
