Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Rough Country 3" Lift Kit w/ Control Arms
Rough Country 3" Lift Kit w/ Control Arms Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $400.00
Average Price: $367.32
Manufacturer: Rough Country
Recommended?
Yes: 24 / No: 1
This kit contains....
+ New front replacement coil springs
+ long add-a-leafs w/ necessary hardware for the rear
(the long ones provide a much better ride over the short ones on the market)
+ Front extended lower control arms with poly bushings and new sleeves to maintain proper alignment
+ (4) Rough Country 8000 series premium grade shocks
+ All necessary hardware which is zinc plated
+ Complete instructions
Page 1 of 2 1 2 > Last »
ahoyt653
ahoyt653's Reviews
02-06-2012, 09:57 AM
Price: $399.00
Pros: Very easy to follow instructions
Cons: reuse most stock hardward, Driveline vibrations after install
Recommended? Yes
Comments: If you are planning to install this kit, give yourself more than the 2-3 hour install time, alot more. Be more prepared, rent a spring compressor, order new cam bolts, and use wd-40 or PB blaster on everything you will need to take part. Really the kit is not that bad to install, it is just removing the old parts that takes time. Then again this is to be expected on a 17yr old Jeep. I have some driveline vibration now, I will update this when I get that worked out
Azzy
Kamen Rider
Azzy's Reviews
10-01-2011, 07:37 PM
Price: $350.00
Pros: Good quality, nice parts, super service.
Cons: Light on hardware and instructions. Could use better photos.
Recommended? Yes
Comments: Shops fast, parts are decent quality, great for the money. Dont get much hardware, it would be nice to at least get nuts for the tops of shocks and things like that, where you know you are going to destroy the old stock pulling out control arm bolts especially). Customer support is helpful on any questions, I've chatted with them a few times.
JeepStar007
JeepStar007's Reviews
09-26-2011, 04:28 PM
Price: $255.95
Pros: fast shipping
Cons: none
Recommended? Yes
Comments: It wasn't as easy as the instructions described. (What is though?) I ended up making my own leaf packs for the rear so I just used the shocks and coils. Over all its stiff and works great off road. Would reccomend an allignment after lifting...
makemusic116
Just Expect Every Problem
makemusic116's Reviews
04-15-2011, 08:20 PM
Price: $311.00
Pros: Price and quality
Cons: Doesn't come with extended sway bar links.
Recommended? Yes
Comments: I love my RC lift this is the third one I have installed and have had little to no issues with all my lifts from them. Their customer service is unbeatable and their prices are very competative. I would definitely recommend RC products to anyone.
makemusic116
03-17-2011, 07:22 PM
Price: $311.36
Pros: Price! Parts are beefy and well made and it comes with very detailed instructions.
Cons: Comes with sway bar drop brackets instead of extended links.
Recommended? Yes
Comments: I have not installed it yet but I had this same lift on my '96 and I loved it. I will update this again after it is installed.
bcusstc
bcusstc's Reviews
02-28-2011, 02:57 PM
Price: $625.00
Pros: came with everything i needed
Cons: Would have been nice to have a TC drop
Recommended? Yes
Comments: Everything went together smooth. No issues.
bcusstc
bcusstc's Reviews
02-28-2011, 02:55 PM
Price: $625.00
Pros: Came with everything i needed
Cons: Would have liked to see it come with a TC drop just in case.
Recommended? Yes
Comments: Fits my needs perfect as an entry level lift. Directions could be a little better if someone doesnt know much about mechanics.
njaimet
njaimet's Reviews
01-04-2011, 01:41 PM
Price: $500.00
Pros: Good quality
Cons: Cannot get vehicle to align straight
Recommended? Yes
Comments: I have 20" wheels with 35" tires and no rubbing...I actually have the 3.5" Rough Country lift
brendancfarrell
brendancfarrell's Reviews
11-17-2010, 12:39 AM
Price: $460.00
Pros: love the stance, great flex
Cons: look a couple tries for them to send me the clamps
Recommended? Yes
Comments: this is an excellent starter lift kit for any first time jeep owner. easy to install, and looks and rides great. I do recommend getting RC's wheel spacers to widen the stance of your jeep to account for this lift. all in all, great inexpensive lift($460 shipped to my door)
brandcha000
brandcha000's Reviews
11-01-2010, 12:26 PM
Price: $250.00
Pros: rides smooth
Cons: took awhile to install :(
Recommended? Yes
Comments: Took awhile to install because it was my first install. but overall it was worth it. it makes huge difference in ride height, for bigger wheels, rides smoother then the stock suspension and it does flex!
KevLaredo
KevLaredo's Reviews
09-13-2010, 03:28 PM
Price: $300.00
Pros: great kit
Cons: comes with end links not discos
Recommended? Yes
Comments: Great kit. No complaints. Wheeled the devil out of the Zj at windrock with no issues next day after install. Wish id ordered it with quick discos though.
btait1
btait1's Reviews
08-12-2010, 06:58 PM
Price: $550.00
Pros: Very nice quality. So far, no need for Transfer case drop kit.
Cons: Does not come wit every single brand new bolt. one of the U-Bolts they sent me had thread damage.
Recommended? Yes
Comments: Its the perfect size lift for someone who needs to replace an old worn suspension and doesn't want to deal with much, my rear leafs were sagging 3".
Its about the same price as stock replacement size parts. so its totally worth it.
Telecaster31
Telecaster31's Reviews
04-12-2010, 05:06 PM
Price: $300.00
Pros: .
Cons: .
Recommended? Yes
Comments: good stuff...for now
damidget
damidget's Reviews
03-25-2010, 06:20 PM
Price: $400.00
Pros: great lift kit quality parts
Cons: none
Recommended? Yes
Comments: its a great kit for the price, many parts that rustys didnt have come with this kit. i got the nitro shocks and the bigger stabilizer. you will need a trac bar no doubt about it and i also did the steering box brace for good measure.
great flex and clearance, i follow my friend through almost everything he does and hes got a 8 inch rustys long arm with 35s and arb lockers
dagr8tim
dagr8tim's Reviews
02-21-2010, 09:03 AM
Price: $360.00
Pros: Great "entry level" lift
Cons: Harsh Ride
Recommended? Yes
Comments: I was looking for something entry level, and a friend is a retailer for RC. I got a great deal on the lift.
s2ooo4me
s2ooo4me's Reviews
02-09-2010, 05:51 PM
Price: $1.00
Pros: N/A
Cons: N/A
Recommended? Yes
Comments: I bought the Jeep with the lift already installed.
tacweapon
tacweapon's Reviews
11-04-2009, 02:19 AM
Price: $350.00
Pros: complete kit cheap
Cons: none so far
Recommended? Yes
Comments: I have had mine for about 5 months now and so far I haven ot had any major issues. It is by far worth the price, I have an add a leaf right now and I think that I would prefered a complete leaf but its not that bad.
jonzer12
jonzer12's Reviews
05-22-2009, 10:11 AM
Price: $450.00
Pros: full leaf packs and good price
Cons: none so far, few shipping errors
Recommended? Yes
Comments: I got a great price for a kit wil full leafs. I paid 450 shipped! I let them keep their shocks however which may have helped the price as I had a set of high end shocks that would fit already.
They sent me f-250 leaf springs by mistake, one phone call and it was corrected and they let me keep the ford springs! I should be able to get $100 bucks for them no problem.
They sent me the wrong u-bolts as well I just ran out and bought them myself.
Good customer service, they answer the phone right away and email you back literally in minutes.
I got 4" in the front and 2 3/4 in the rear. I will even it out with shackles.
Using Edelbrock Extreme IAS shocks this lift rid rides like a cadilac compared to my old stock setup.
jd4x426
jd4x426's Reviews
04-09-2009, 06:04 PM
Price: $400.00
Pros: great cost great off road ride so far its been awesome
Cons: aal suck shocks could be betteer
Recommended? Yes
Comments: the kit went on really easy not the best instructions but i new what i was doing all the parts fit right no problems it shipped super fast great customer service the kit is nice its great off road rides a little rough but i beleive its mostly the crappy shocks also the aal are starting to sag a little i wish iwould have gotten the full packs but other then that i would definitely buy from them again
fisher2985
fisher2985's Reviews
03-14-2009, 03:44 PM
Price: $360.00
Recommended? Yes
Comments: easy install
shackle nuts inside of frame broke loose though
not rough country fault
ThreadForumRepliesLast Post
rough country 3" lift kit Complete Lift Kits 36 01-10-2012 04:53 PM
Rough Country 4" Rough Country Suspension Lift Complete Lift Kits 46 12-22-2011 04:52 PM
Rough Country - X-Flex Adjustable Control Arms Lower Control Arms 4 01-05-2010 02:30 AM
rough country Adjustable greasable front upper and lower control arms Control Arms 6 11-23-2009 06:37 PM
Rough Country YJ 1.5" Lift kit Complete Lift Kits 1 08-25-2008 07:18 PM
Glock Forum
