Notices
Rough Country 2" budget lift Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $300.00
Average Price: $164.15
Manufacturer: Rough Country
Recommended?
Yes: 62 / No: 4
kit includes two 2" inch front spring spacers and two 2" lift shackels.
None
Page 3 of 4 1 2 3 4 > Last
RPDjeep
RPDjeep's Reviews
02-24-2010, 02:07 PM
Price: $90.00
Pros: Cheap way to get some extra clearence.
Cons: None.
Recommended? Yes
Comments: Easy to install. A great way to get a little extra clearence. My jeep is currently my DD and I did not want to lift it to much at this time.
Trombly
Trombly's Reviews
01-07-2010, 10:08 PM
Price: $450.00
Pros: First one good enough for me
Cons: None, works well so far
Recommended? Yes
Comments: Does work and holds up
muskrat358
muskrat358's Reviews
10-26-2009, 07:20 PM
Price: $71.95
Pros: Just recieved not intalled yet
Cons: Just recieved not installed yet
Recommended? Yes
Comments: I will be back on after my intall and drive a bit to give some details
gmp211
gmp211's Reviews
07-07-2009, 06:58 PM
Price: $200.00
Pros: Very inexpensive and the Nitro shocks are awesome. Also, great customer service.
Cons: Shocks could be smoother, but its nothing to noticeable.
Recommended? Yes
Comments: As I said, its a very basic kit, and nothing too special. I wouldn't get it with the hydro shocks though. Shell out the extra $30 or w/e to get nitros.
anthonyg
anthonyg's Reviews
06-16-2009, 08:53 AM
Price: $189.50
Pros: Easy Install, Clears 30" Tires
Cons: None
Recommended? Yes
Comments: The only problem I had was that the washers provided for the front shocks tore through the bushings and caused a ridiculous rackett. If I could do it again, use the factory washers, so you don't have to go out and buy new bushings.
kadetklapp
kadetklapp's Reviews
06-03-2009, 11:10 AM
Price: $90.00
Pros: Cheap and easy
Cons: Not going to go rock and stump crawling anytime soon
Recommended? Yes
Comments: Haven't yet installed. Will update when I do.
mav383
mav383's Reviews
05-28-2009, 04:02 PM
Price: $250.00
Pros: 2 inches quick and easy
Cons: hate the shocks, they bottom out when hitting bumps on the trail, just go for four!
Recommended? No
Comments: I installed it quickly by myself but in a well equiped shop in 3 hrs. Shocks included dont quite fit right but that may be because I have stock springs that have been well used and maybe a little worn out. The shock body hits the upper shock mount when on the trail and the ft sway is disco'd. Price wise just spend the extra 250 for the 4 in from rough country and get real springs and always, always upgrade the shocks! These shocks also have a bad bone jarring reaction everytime i hit a hole or bump in the road wish I'd have gone with ajustable ones. 2" runs 245/75r16s just fine no trimming.
Phill80
Phill80's Reviews
05-11-2009, 11:40 AM
Price: $90.00
Pros: gives enough clearance for bigger tires
Cons: puts more stress on the already weak leaf springs
Recommended? Yes
Comments: i got the coil spacers along with the adjustable shackles. it wasnt really hard to install. the hardest part was removing the shackle bolts. i had to use a torch on one. about a 4hr job all together. shortly after i put on 30x9.5 tires. the difference is huge. it looks so much better than stock. and for what i use it for its great. im really happy with the way it turned out.
weegie22
weegie22's Reviews
03-06-2009, 09:56 PM
Price: $170.00
Recommended? Yes
Comments: I do like this lift because of the price and did what it said it would do but i wish it was higher. It was also a ***** to install.
Scottyboy
Scottyboy's Reviews
01-29-2009, 08:16 PM
Recommended? Yes
Comments: its a good beginner lift. not really a great lift for wheeling but with it and a 1in body lift i put 33's under my rubi.
mikeinminn
mikeinminn's Reviews
11-30-2008, 08:53 AM
Price: $140.00
Recommended? Yes
Comments: This is actually the 2.5" BB. I like this lift. It looks good and functions very well. 2.5" doesn't mess up the handling like some lifts do without long arms. 3" is all I would go without a long arm kit. There were a few installation surprises like RCs failure to include some lower shock mount relocation bracket bolt sleeves and some missing info in the instructions about wires and other lines that would need to be loosened to keep them from stretching. Great price!!
FABS-JK
FABS-JK's Reviews
11-20-2008, 11:17 PM
Price: $180.00
Recommended? Yes
Comments: 2.5" in the front and 2" in the rear can't be beat for the price and result. Super easy to install. I did need the rear track bar relocation bracket.
arielgs
arielgs's Reviews
11-03-2008, 08:01 AM
Price: $130.00
Recommended? Yes
Comments: Good enough for my actual journeys into the wild!
Easy to install.
Well made, good finish.
JamJeeper05
JamJeeper05's Reviews
09-13-2008, 12:10 AM
Price: $175.00
Recommended? Yes
Comments: I would like more, but this will doe for now. Standing back looking at it, its kind of not very noticeable.
tato1111
tato1111's Reviews
08-12-2008, 12:21 AM
Recommended? Yes
Comments: dos not look like two inches unless parked next to a stock jeep but it was on the jeep when i bought it so i dont know if it is or was two inches.
Natrik81
Natrik81's Reviews
08-02-2008, 02:40 PM
Price: $125.00
Recommended? Yes
Comments: Did the job, Jeep handles great, no problems with install. Afternoon job. Came with a Big Bore Steering Stabilizer.
tx_medic
tx_medic's Reviews
07-29-2008, 05:27 PM
Recommended? No
Comments: This was on the jeep when I bought it. I'm not terribly impressed with the product or the installation just yet.
dorsalfin3
dorsalfin3's Reviews
06-25-2008, 03:56 PM
Price: $300.00
Recommended? Yes
Comments: I have this lift and I love it. I added the quadratec springs along with the lift, making the perfect daily driver, but able to hit the trails on the weekend.
hockeykid3824
hockeykid3824's Reviews
06-09-2008, 05:38 PM
Price: $100.00
Recommended? Yes
Comments: went in really easy. very suttle lift but definetly noticeable
slim1000
slim1000's Reviews
05-22-2008, 03:58 PM
Price: $100.00
Recommended? Yes
Comments: adds a nice stance to stock xj with very little to no vibes or wobble. very easy to install only took 2 hours (took my sweet time too)
ThreadForumRepliesLast Post
rough country 3" lift kit Complete Lift Kits 45 11-02-2013 01:03 PM
Rough Country 6.5" XJ Lift Complete Lift Kits 31 10-09-2013 10:39 AM
Rough Country 4" Rough Country Suspension Lift Complete Lift Kits 134 10-05-2013 12:46 AM
Rough Country 2.5" Budget Boost Complete Lift Kits 25 08-26-2013 10:42 PM
Rough Country YJ 1.5" Lift kit Complete Lift Kits 1 08-25-2008 07:18 PM
