Rough Country 2" budget lift
Rating: |
Product Information
| MSRP: |
$300.00 |
| Average Price: |
$144.60 |
| Manufacturer: |
Rough Country |
| Recommended? |
kit includes two 2" inch front spring spacers and two 2" lift shackels.
muskrat358's Reviews
Price: $71.95 Pros: Just recieved not intalled yet Cons: Just recieved not installed yet Recommended? Yes
Comments: I will be back on after my intall and drive a bit to give some details
gmp211's Reviews
Price: $200.00 Pros: Very inexpensive and the Nitro shocks are awesome. Also, great customer service. Cons: Shocks could be smoother, but its nothing to noticeable. Recommended? Yes
Comments: As I said, its a very basic kit, and nothing too special. I wouldn't get it with the hydro shocks though. Shell out the extra $30 or w/e to get nitros.
anthonyg's Reviews
Price: $189.50 Pros: Easy Install, Clears 30" Tires Cons: None Recommended? Yes
Comments: The only problem I had was that the washers provided for the front shocks tore through the bushings and caused a ridiculous rackett. If I could do it again, use the factory washers, so you don't have to go out and buy new bushings.
kadetklapp's Reviews
Price: $90.00 Pros: Cheap and easy Cons: Not going to go rock and stump crawling anytime soon Recommended? Yes
Comments: Haven't yet installed. Will update when I do.
mav383's Reviews
Price: $250.00 Pros: 2 inches quick and easy Cons: hate the shocks, they bottom out when hitting bumps on the trail, just go for four! Recommended? No
Comments: I installed it quickly by myself but in a well equiped shop in 3 hrs. Shocks included dont quite fit right but that may be because I have stock springs that have been well used and maybe a little worn out. The shock body hits the upper shock mount when on the trail and the ft sway is disco'd. Price wise just spend the extra 250 for the 4 in from rough country and get real springs and always, always upgrade the shocks! These shocks also have a bad bone jarring reaction everytime i hit a hole or bump in the road wish I'd have gone with ajustable ones. 2" runs 245/75r16s just fine no trimming.
Phill80's Reviews
Price: $90.00 Pros: gives enough clearance for bigger tires Cons: puts more stress on the already weak leaf springs Recommended? Yes
Comments: i got the coil spacers along with the adjustable shackles. it wasnt really hard to install. the hardest part was removing the shackle bolts. i had to use a torch on one. about a 4hr job all together. shortly after i put on 30x9.5 tires. the difference is huge. it looks so much better than stock. and for what i use it for its great. im really happy with the way it turned out.
weegie22's Reviews
03-06-2009, 08:56 PM |
Price: $170.00 Recommended? Yes
Comments: I do like this lift because of the price and did what it said it would do but i wish it was higher. It was also a ***** to install.
Scottyboy's Reviews
01-29-2009, 07:16 PM |
Recommended? Yes
Comments: its a good beginner lift. not really a great lift for wheeling but with it and a 1in body lift i put 33's under my rubi.
mikeinminn's Reviews
11-30-2008, 07:53 AM |
Price: $140.00 Recommended? Yes
Comments: This is actually the 2.5" BB. I like this lift. It looks good and functions very well. 2.5" doesn't mess up the handling like some lifts do without long arms. 3" is all I would go without a long arm kit. There were a few installation surprises like RCs failure to include some lower shock mount relocation bracket bolt sleeves and some missing info in the instructions about wires and other lines that would need to be loosened to keep them from stretching. Great price!!
FABS-JK's Reviews
11-20-2008, 10:17 PM |
Price: $180.00 Recommended? Yes
Comments: 2.5" in the front and 2" in the rear can't be beat for the price and result. Super easy to install. I did need the rear track bar relocation bracket.
arielgs's Reviews
11-03-2008, 07:01 AM |
Price: $130.00 Recommended? Yes
Comments: Good enough for my actual journeys into the wild!
Easy to install.
Well made, good finish.
JamJeeper05's Reviews
09-12-2008, 11:10 PM |
Price: $175.00 Recommended? Yes
Comments: I would like more, but this will doe for now. Standing back looking at it, its kind of not very noticeable.
tato1111's Reviews
08-11-2008, 11:21 PM |
Recommended? Yes
Comments: dos not look like two inches unless parked next to a stock jeep but it was on the jeep when i bought it so i dont know if it is or was two inches.
Natrik81's Reviews
08-02-2008, 01:40 PM |
Price: $125.00 Recommended? Yes
Comments: Did the job, Jeep handles great, no problems with install. Afternoon job. Came with a Big Bore Steering Stabilizer.
tx_medic's Reviews
07-29-2008, 04:27 PM |
Recommended? No
Comments: This was on the jeep when I bought it. I'm not terribly impressed with the product or the installation just yet.
dorsalfin3's Reviews
06-25-2008, 02:56 PM |
Price: $300.00 Recommended? Yes
Comments: I have this lift and I love it. I added the quadratec springs along with the lift, making the perfect daily driver, but able to hit the trails on the weekend.
hockeykid3824's Reviews
06-09-2008, 04:38 PM |
Price: $100.00 Recommended? Yes
Comments: went in really easy. very suttle lift but definetly noticeable
slim1000's Reviews
05-22-2008, 02:58 PM |
Comments: adds a nice stance to stock xj with very little to no vibes or wobble. very easy to install only took 2 hours (took my sweet time too)
juiceparn's Reviews
05-21-2008, 08:38 AM |
Price: $139.00 Recommended? Yes
Comments: Just installed and so far I'm loving it. It's actually 2.5". I will probably get shocks in a few months but the stock shocks with extentions are working great!
shelby_Extreme's Reviews
05-11-2008, 07:38 PM |
Price: $86.99 Recommended? Yes
Comments: Excellent Product! Easy Install and Cheap. Very Solid but my Leafs are Getting too Weak to maintain 2" lift
