Rough Country 2.5 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rough Country 2.5
Rating:
Product Information
MSRP: $300.00
Average Price: $531.02
Manufacturer: Rough Country
Recommended?
Yes: 189 / No: 6
Company Website: http://www.roughcountry.com/
Rough Country 2.5" Progressive Spring Lift Kit. Consists of four progressive rate coils, four 2.2 performance shocks and t-case spacers. Optional matching steering stabilizer.
None
Page 5 of 10 1 2 3 4 5 6 7 8 9 10 > Last
wapeloquin
wapeloquin's Reviews
08-28-2010, 02:53 PM
Price: $1.00
Pros: Great
Cons: U-Bolys were not the correct size for an older CJ5
Recommended? Yes
Comments: The product was as advertised for anewer CJ5. However, it was not correct for an older CJ5 axle diameter. However, the guys a rough contry responded right away and were very helpful.
TheRover
TheRover's Reviews
07-18-2010, 08:59 PM
Price: $400.00
Pros: Everything you'd expect from a budget lift kit.
Cons: shocks are too stiff.
Recommended? Yes
Comments: Even though the shocks are too stiff for my liking, overall, the kit is a great value. Easily done at home by two people. For my TJ we did have to get a rear trackbar relocation bracket and re-drill a hole for the front one. I would suggest getting a adjustable one for the front. A pickle-fork was the only thing that would separate the front trackbar from the frame mount (just something to keep in mind). Definitely recommended.
krahnilogikal
krahnilogikal's Reviews
07-12-2010, 10:23 AM
Price: $400.00
Pros: Easy installation, good value for starter lift, great customer service
Cons: None so far
Recommended? Yes
Comments: I've been pleased despite some criticism from others. RC products have served me very well thus far and their customer service is very responsive and easy to deal with. The ride comfort is as good as to be expected from an off-road designed lift. The 2.2 shocks are not too soft and not too stiff even for my DD/weekend warrior. Springs are not too bouncy and have not settled too far after 6 months. I don't have any heavy bumper accessories yet so we will see how they handle that when the time comes.
knightwolf654
knightwolf654's Reviews
07-11-2010, 08:38 PM
Price: $299.99
Pros: beefy shocks, progressive springs
Cons: shocks are a bit stiff
Recommended? Yes
Comments: install was not too bad, i had some stuck lug nuts that had me doing the front one weekend and the rear the next weekend. do need a spring compressor since the track bar wont allow the axle to drop down far enough to allot the spring to simply slide on. currently have 300+ miles on it but the shocks are pretty stick compared to the stock gas charged ones. it has knocked my muffler loose twice, may look into getting some better ones.
tomas789
tomas789's Reviews
07-11-2010, 06:01 AM
Price: $600.00
Pros: Higher off the ground :)
Cons: It's pretty stiff.
Recommended? Yes
Comments: I don't have any experience with other lift kits, but this one seems stiff, especially after a day of off roading. Went on easy, I installed it with no prior suspension experience.
Sicks
Sicks's Reviews
07-04-2010, 08:49 PM
Price: $199.99
Pros: Cheap. No modifications at all. Just shocks and springs.
Cons: It's only 2.5 inches.
Recommended? Yes
Comments: It adds a decent lift without much modification. It's springs and shocks so no cutting/welding or any other modification. It's a steal for 200 bucks off of roughcountry's website.
kyumanaz
kyumanaz's Reviews
06-19-2010, 01:12 PM
Price: $330.00
Pros: Love the ride, more comfortable, and does much better off-roading.
Cons: none
Recommended? Yes
Comments: I bought the stiffer 6 cylinder rated springs, and everything went in well. As usual it took longer to install as I did it myself, and this was my first lift. It rides much better than it did with the 2 inch spacers that were in there when I bought it. I also got a new steering stabilizer, all 2.2 shocks came with it. I feel it was a good lift for the price.
NickO127
NickO127's Reviews
06-08-2010, 10:47 PM
Price: $476.00
Pros: Cheaper than most lifts I found, right at the amount of lift I wanted. (On Ebay)
Cons: Didn't come with all the bolts and nuts to replace everything. When springs are still new my rear driveshaft grinded from the angle. Putting in homemade TC drop.
Recommended? Yes
Comments: Overall not a bad kit, just some of the issues as listed above. Everything on my YJ was frozen. The bolts that go through the bushings in the leaf springs were completely rusted solid....tried breaker bars, impacts everything....Finally 45 dollars in sawzall blades later I had to buy new nuts and bolts because the kit called for reusing everything HAHA. I believe they should have included all hardware....Other than that pretty good kit rides smooth!
jeepgunner12
jeepgunner12's Reviews
06-05-2010, 10:32 AM
Price: $700.00
Pros: Progressive rate springs, spacers will take it up to 3.25 inches easy.
Cons: Rear sway bar was a Bxxxxx to line up.
Recommended? Yes
Comments: I like this kit because it delivers good flex and can be adjusted easy with spring spacers. Its not rediculously high so it keeps the COG low but i can still clear, and flex with, 31s.
Gus13601
Gus13601's Reviews
06-03-2010, 09:08 PM
Price: $450.00
Pros: Nice Cost
Cons: Kit could have more components
Recommended? Yes
Comments: Installation was easy once I got the rusty bolts out. Instruction were plenty clear enough. The ride is fine with out the sway bar and track bar. Could use some longer brake lines but stock lines were able able to be reconnected. Wouldn't want to off-road much with them though. didn't need the t-case drop kit either.
PolarBear83
PolarBear83's Reviews
05-24-2010, 02:57 PM
Price: $280.00
Pros: Price, Ride, Ease of installation
Cons: None at this time
Recommended? Yes
Comments: Jeff takes care of JF members
cupojava
cupojava's Reviews
05-09-2010, 03:48 PM
Price: $300.00
Pros: Ride is not that different from stock, but it is my first lift and I haven't driven a jeep any higher than this.
Cons: It does sway a bit, which was especially noticeable after the alignment.
Recommended? Yes
Comments: I had originally wanted just a spacer lift but my husband insisted on the complete lift kit. I am glad now, I don't think I would have been quite happy with just the spacers. And honestly, it looks so much better with the new coils and shocks. The old ones were rather tired looking. It rides very similar to stock, except for the sway around corners. I also had the new, bigger tires put on at the same time. Now that I'm used to the height, I am very satisfied with how it feels. I have to say, the mechanic that I chose picked this, he seemed impressed with the shocks for the price of the kit.
jeeprenegadeaz
jeeprenegadeaz's Reviews
05-02-2010, 04:00 PM
Price: $500.00
Pros: great lift great price
Cons: none right now
Recommended? Yes
Comments: if ur looking for a good lift for a resonable price get it
aubieron
aubieron's Reviews
04-28-2010, 09:54 AM
Price: $199.00
Pros: Easy Installation. Complete kit with easily understood instructions.
Cons: None
Recommended? Yes
Comments: Bought this kit from Morris 4x4. Easily better pricing than Quadratec, and they offer Military discounts, big plus! Excellent customer service and overnite delivery.
2003wranglerRHD
2003wranglerRHD's Reviews
04-26-2010, 08:13 PM
Price: $299.99
Pros: love the ride alot of flex
Cons: none
Recommended? Yes
Comments: Ive had the kit in for 4 months and love it
Pandl
Pandl's Reviews
04-24-2010, 03:15 AM
Price: $300.00
Pros: Good ride
Cons: None
Recommended? Yes
Comments: This is a good lift. It is very simple to install.
tjFREEDOMjeep
tjFREEDOMjeep's Reviews
04-16-2010, 02:29 AM
Price: $335.00
Pros: the ride
Cons: none
Recommended? Yes
Comments: easy install great quality huge ride improvement with no problems
mjk65
mjk65's Reviews
04-10-2010, 07:38 PM
Price: $300.00
Pros: Cheap
Cons: Rough
Recommended? Yes
Comments: I was on a tight budget due to college, and wanted some lift. Its a DD so I didn't want to go huge, but enough to clear some bigger tires than the stockers that came on it. It gets the job done as long as you aren't used to riding in a cady.
bmweseman
bmweseman's Reviews
04-02-2010, 09:07 PM
Price: $450.00
Pros: Everything!! From my research this has been the lift kit for the beginner on up! Flex is great! Handling manners are great too.
Cons: Sent the wrong shocks in the rear. But hopefully that will be fixed in a few days. (good thread by the way)
Recommended? Yes
Comments: I ordered the 2.5 lift kit with progressive springs and the 2.2 shocks. I added on the .75 BL and upgraded the steering stabalizer. When I recieved this lift kit I was living in an apartment at the time. So not only did I need a place to install It had to be fairly quick (due to the other tennants complaining about working on cars in the parking lot).
I read through the instructions and went and rented a spring compressor at schucks and I was on my way! This was the first time that iv'e ever done anything like this, but I had no hiccups! I got it done in one night by myself after the manager left for the evening.
As far as functionality it was more than I expected. A quick disconnect of the front and rear sway bars and up into the hills I went. My buddy wanted to take me to a place that was dug out by heavy machinery and my jeep looked like a cartoon walking through the dig outs.
Road handling is just fine (its a jeep).
Overall this company has had great customer service that produces a product that is above expectations. They definately have a customer for life.
lam4eks
lam4eks's Reviews
04-01-2010, 06:09 PM
Price: $280.00
Pros: easy to install
Cons: none yet
Recommended? Yes
Comments: It took me and a buddy 4 hours to install. That included 30 minutes for lunch.
ThreadForumRepliesLast Post
Rough Country - Rough Country 6" Long Arm Kit Complete Lift Kits 8 11-24-2016 11:32 PM
Rough Country 4" Rough Country Suspension Lift Complete Lift Kits 150 09-26-2016 03:22 PM
Rough Country Rough Country 2.2 Shocks Shocks 38 05-29-2016 03:31 PM
Rough Country - Rough Country 4" Long Arm Kit Complete Lift Kits 15 01-25-2016 11:42 AM
Rough Country - Rough Country Bar Pin Eliminator Kit Shocks 1 01-08-2010 03:30 PM
