Rock Krawler - Rock Krawler 3.5" X-Factor + Short Arm Lift (TJ) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $1,749.00
Average Price: $1,739.99
Manufacturer: Rock Krawler
Recommended?
Yes: 5 / No: 0
Company Website: http://www.rockkrawler.com/
The Rock Krawler 3.5 X Factor Plus Short Arm System is the ultimate short arm system on the market today. This system allows you to run up to 33" tires with excellent road manners and unparalleled off-road ability. Our front track bar correction system maintains perfect steering geometry with the drag link and drop pitman arm combination. The rebuildable spherical Krawler Joints at the axle connections allow for a tremendous amount of twist. The rear features our awesome triangulated 4 link conversion allowing removal of the rear track bar for awesome rear axle articulation. We have also put in anti-squat geometry for improved vertical climbing ability. No detail has been left out of this system! Rock Krawler has also included rear upper reinforcing mounts to improve the strength of the OEM mounts. The weld on rear cradle improves the overall strength of the factory rear axle housing as well as providing mounting points for the triangulated 4 link members. This system includes everything you need to turn your TJ into an off-road power house. You get double adjustable lower control arms all the way around, adjustable front upper control arms, double adjustable rear upper triangulated 4 link arms, adjustable front track bar, weld on rear axle truss, front sway bar disco's, rear extended sway bar links, and stainless steel brake lines just to name a few key components. Try to find all of these great features in any other short arm system. That won't happen! Don't forget this system comes with our exclusive abuse proof lifetime guarantee on all hard parts!
System Benefits:
-Excellent Highway Ride and Handling
-Perfect Steering Geometry Corrections
-The Best Off Road Ability of any Short Arm System
-RTI 1200+ on a 20 Degree Ramp
-Triangulated 4 Link Rear Conversion
-Front Sway Bar Quick Disconnects
-Double Adjustable Lower Control Arms
-Allows for 33 Inch Tires
-Limited Lifetime Warranty
-Upgradeable to long arm system
System Includes:
4 linear coil springs, 4 high misalignment/double-adjustable lower control arms made from solid stock, front high misalignment/adjustable track bar made from solid stock, (2) double adjustable rear upper triangulated 4 link arms made from solid stock, (1) weld on rear axle truss made from 1/4" thick laser cut steel, (1) weld on rear truss tie in plate, front upper high misalignment/adjustable control arms made from solid stock, front adjustable sway bar disconnects, rear extended sway bar links, stainless steel brake lines, drop pitman arm, hardware and detailed instructions.
General Notes:
*Requires a transfer case drop kit, or a C.V. Driveshaft Conversion, or a SYE with C.V. Driveshaft Conversion
**2003 TJ's equipped with 4 speed automatics will require removal of the factory automatic transmission skid plate if so equipped to allow for proper front driveshaft travel
***Choose your bump stop lengths after you choose your wheel/tire and fender combination.
Shock Notes:
It is recommended that high quality shocks be used with all Rock Krawler Suspension Systems. The Rock Krawler RRD Racing Shocks are a great choice! Bilstein 5100ís are also a good choice.
RRD Racing Shock Front Part Number RRD02050 ($169 Each)
RRD Racing Shock Rear Part Number RRD02051 ($169 Each)
Get a set of (4) 2.0 Emulsion RRD Racing Shocks for only $599!
Bilstein 5100 Recommended Part Numbers
Front - BE5-F100-HO
Rear - BE5-A939-H5
Generic Front Shock Recommendation - 17" Collapsed to 27" Extended
Generic Rear Shock Recommendation - 16" Collapsed to 26" Extended
None
FingerEleven54
FingerEleven54's Reviews
06-03-2012, 07:37 PM
Price: $1,200.00
Pros: Great workmanship, great lift. Makes the TJ stand like it's supposed to. Offroad capability with great a great daily driving ride.
Cons: None.
Recommended? Yes
Comments: This kit is great for those who drive their Jeep every day and take it on the trail on the weekends. It will not let you down! I'm running 33's on 17 inch rims.
Dwebber18
Dwebber18's Reviews
05-10-2012, 01:56 PM
Price: $1,300.00
Pros: Solid build quality with solid steel components.
Cons: I just am getting it put on but it might be a little difficult to get it all adjusted just right.
Recommended? Yes
Comments: Build quality seems very good, and the parts are solid. I'm just getting it installed so we'll see how much work it takes to get them adjusted.
JuniorUSN
JuniorUSN's Reviews
03-09-2012, 03:04 AM
Price: $1,000.00
Pros: Great Ride, flexes like crazy, super beefy control arms.
Cons: None
Recommended? Yes
Comments: You cant go wrong with the abuse proof warranty!
Looney
Looney's Reviews
09-05-2011, 06:47 PM
Price: $3,500.00
Pros: Man size lift!
Cons: install could have been easier.
Recommended? Yes
Comments: This is indeed a man size lift. I have the PRO version and so its aluminium makes the kit lighter but just as stout. I bought the RRD remote shocks to go with it so now my jeep feels like it could crawl over anything. I got way more that 3.5 inches of lift. I would estimate 4.5 to 5 inches of lift and that is with heavy aftermarket steel bumpers, tire carriers, and a winch.
All in all its a great kit that moves well. I do get a little more body roll than before but considering the amount of lift I figured that just happens. It is pricey and you may need to get creative with some of the installation but you wont regret it. Kit did not have anything for steering stabilizers so that is an additional piece that you will need to add in addition to this kit.
briguy3030
briguy3030's Reviews
07-26-2011, 07:18 PM
Price: $1,699.95
Pros: Stout! BEEFY
Cons: Heavy Noisy rod ends No Zerk fittings
Recommended? Yes
Comments: This setup has TONS of flex. I never have to worry about busting up the control arms on a rock as they are made of solid stock steel.
However, the rod ends/joints are manufactured so tightly that Rock Krawler reccomends using 2-in-1 oil by means of a allen screw @ ea. link end-- regular grease gun lube by ways of zerk fitting is not possible. For that reason, routine maintenance is a royal pain as some screw fittings are not accessible w/ an oil/lube can.
Rod ends are also both RIGHT HAND threaded so any adjustment requires complete removal.
I would recommend this product for its stoutness & performance, yet not for the aforementioned nuances above. You decide what your priorities are . . .
ThreadForumRepliesLast Post
Rock Krawler 7" X-Factor Complete Lift Kits 3 01-13-2016 03:16 PM
Rock Krawler XFactor 3.5" Lift Complete Lift Kits 11 09-25-2014 03:10 PM
Rock Krawler Hydro Shocks Shocks 2 04-29-2014 12:51 PM
Rock Krawler TJ 4" & 5.5" X-Factor Long Arm Complete Lift Kits 14 05-26-2013 06:24 PM
Rock Krawler RK 6.5" Coils - XJ Springs 0 12-02-2007 05:39 PM
