Rancho - Rancho 3.5 Short arm System Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $1,300.00
Average Price: $1,247.00
Manufacturer: Rancho
Recommended?
Yes: 2 / No: 0
Company Website: http://www.gorancho.com/suspension.php?make=Jeep&model=97_06_jeep_tj_lj#lift
Alright so I have quite a bit to say about the Rancho 3.5 Short arm system positives and pitfalls. I havent decided as I am borderline to answer if the pitfalls are more trouble then the Look I love! I will describe and you will have to make the decision....
2005 Wrangler X TJ, Body Armor 59" 4 loop, xrc8 winch, 1.5 spacers on front springs, 31 inch tires
1 Rancho Front Diff Cover
2. Rancho 3.5in Suspension lift
3. MT7000 shocks(final)
4. RS5000 Shocks(1st)
I purchased my Rancho suspension kit at 4 Wheel Parts and they installed it as well.
Pitfalls under high duress of high speed 4 wheeling:
1. I bought the kit combined with the RS5000-- DO NOT DO THIS! My initial ride out I so afraid I would lose control I had to drive slowly until I got use to the darting to the right the Jeep did. 4 wheel parts told me I had to add a "camber" additional cost and time with Jeep--helped but did not solve. I continue to fix and 4 wheel parts said get beter shocks. 4 wheel parts took the 5000s back but I still had to pay service to put in the MT7000. This worked. I think you must get the MT7000 if you stay with Rancho brand with the 3.5 lift.
2. I also had the Rancho Diff cover put on----the bar that comes with the Rancho kit under duress will impact the Rancho Diff cover. Initially grinded the re-enforcement down to dome of diff cover but hit some sand dunes and after big bump still hit dome. On the picture you will see diff cover with the grinded re-enforcement and black mark on dome where bar will hit!!! I havent replaced this with stock cover because I like the look...but I am afraid if high speed off-roading now!!
3. The stabilizer bar as part of the kit that goes on the back side of the gas tank. It connects from wheel base to frame. This is too close to the wire that powers the fuel pump!!!! How do I know?? Same Sand dunes after big jump car stall out discover that fuel pump fuse blew. Replaced fuse car ran..2 months later car stalls again! figured it was the fuel pump and thought maybe since I sand dune ... that salt water may have corroded wires...after visual inspection discover the fuel wires were grabbed by rear stabilizer bar and shredded the fuel wires!!!! be wary of this....get wires and move to safe location. Luckily this was a quick fix by re-connecting wires. You will see the pictures I added.
Positives:
1. looks great!!
2. slower speed 4 wheeling --I dont have any problems!!
None
Rubi2
Rubi2's Reviews
05-07-2014, 10:23 AM
Price: $1,499.00
Pros:
Cons:
Recommended? Yes
Comments:
Otto Man
Otto Man's Reviews
07-09-2013, 12:10 PM
Price: $995.00
Pros: Very complete kit. Ride is great for a while with RS9000XL shocks. Good directions with pictures where needed. Rebates were available.
Cons: None. **Some parts not used: pitman arm, transfer case linkage kit (see write up).
Recommended? Yes
Comments: I went with a Rancho 3.5" Short Arm Kit from 4WD Hardware, RS9000XL shocks, 33x12.5 Goodyear Duratracs on Black painted Canyons with 1.5" wheel spacers.
Living in WI I was fighting rusted up and seized bolts more than anything else. So, getting things off required some effort with penetrating spray, cut off wheels, grinders and sometimes the torch. This was the worst and most time consuming part of the whole thing.
There were no major troubles getting things put together. The kit is very complete, including an adjustable front track bar, rear extended sway bar links, rear track bar bracket, 4 lower control arms, transfer case drop kit, transfer case shift linkage kit, dropped pitman arm, bump stop extensions, front sway bar disconnects and extended stainless steel front brake lines. Here are my notes:
Front removal:
I soaked everything to be removed in Kroil penetrating lube daily for a week before starting. I also pre-assembled anything with bushing and sleeves that I could. The lower control arm bolts were seized to the bushing sleeves so they were cut off. The directions say to reuse the hardware, so I had to replace the hardware that was cut off. Thankfully most of the remaining front end items came off without issue.
Front installation:
Most things here went smoothly. With some measuring I got the front axle centered up nicely with the adjustable track bar. I had to use a spring compressor to get the front springs in. **I chose to not use the included dropped pitman arm since I was not using a dropped track bar bracket. This was the right choice as the track bar and drag link are at nearly identical angles and I have no bump steer what so ever.
Rear removal:
The rear was coming off wonderfully until we got to the track bar. The axle bolt has a torx head on it. Really? WTF? The axle bolt and frame bolt were seized up and there is not a lot of room to work up there. The decision was made to keep moving forward by cutting the track bar in half, removing brake hose, ebrake lines and eventually the rear axle. I ran in and ordered up a new track bar on Rockauto and we went for it. Everything came off really nicely and this allowed my 14 year old son to work on grinding off the track bar axle bolt head while I worked on the frame bolt. The only other thing that took some time was the top shock bolts braking off which is pretty typical.
Rear installation:
The rear installation went well. The hardest thing was getting the track bar bolt holes lined up at the frame side. There was creative use of a ratchet strap, pry bar and pushing on body to get it to go. Torqued everything and rechecked the torques on everything, bled the brakes, installed the wheel spacers and went for a ride... VIBES! It was still a cool feeling, but I soaked and heated the cross member bolts to install the lowering kit. I was blessed as all of the bolts came out without trouble. It solved the vibes, but I will look into a SYE and drive shaft in the future. **I also skipped the transfer case shift kit included in the kit since my linkage brackets were all rusted up and I decided to go with the Novak cable shifter.
3.5" on 33s feels huge compared to stock, but I love it. There is lots of room to flex without hitting anything and the wheel spacers kept the rear out of the coil buckets and allow for full turning without adjusting the stops. It also sits level now. It rides nice with the shocks on the softest setting (1) up front and (3) in the rear, there are no squeaks or rattles. FYI: I was replacing what looked like the original springs and shocks (175,000 miles) along with replacing tires that were getting pretty bad so almost anything would have been better.
Picture in the woods is stock, picture in the driveway is modified, last picture is posing on a retaining wall to flex it out.
The honeymoon feeling of a new lift quickly wears out. After 1 year I started replacing the control arms for extremely harsh ride from the poly bushings, they have no flex and with the stiff lower control arms the ride is horrible. There is also no adjustability so you will have vibes. Track bar frame side TRE shot after 1 year, replaced just the end once, then replaced the whole bar. The only thing left from this kit on my Jeep are the springs and front quick disconnects (which I actually like). I now ride on Metal Cloak control arms (all 8) Metal Cloak front trac bar and metal cloak rear trac bar.
