Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Pro Comp 2" Spring Lift w/ ES3000 shocks
GR8TOPS Introduces the Exogate HD Tire CarrierIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Pro Comp 2" Spring Lift w/ ES3000 shocks Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $800.00
Average Price: $455.85
Manufacturer: Pro Comp
Recommended?
Yes: 21 / No: 0
Pro Comp 2" spring lift with ES3000 shocks
Page 1 of 2 1 2 > Last »
glenn99
glenn99's Reviews
08-19-2011, 04:13 PM
Price: $500.00
Pros: cheap
Cons: kinda stiff
Recommended? Yes
Comments: for the price, it was a good value for me. I will buy something that's a smoother ride next
arsenault397
arsenault397's Reviews
08-04-2011, 06:40 PM
Price: $845.00
Pros: very easy install
Cons: none
Recommended? Yes
Comments: very easy install did it in my parking lot took about 2 days with one other person all i have to say is make sure you spray down your nuts and bolts unless you like to swear and curse your jeep out other then that i havent had any issues and make sure to put in the t case lowering kit when installing the lift .
Gold79Fever
Gold79Fever's Reviews
02-23-2011, 02:33 PM
Price: $400.00
Pros: Easy to install with friends
Cons: None so far
Recommended? Yes
Comments: For me, a 2 inch lift is just enough to get clearance for the 32 inch BJGs without any rubbing. Any taller and I'd have to make lots of other changes.
GreggVA
GreggVA's Reviews
12-04-2010, 02:23 PM
Price: $700.00
Pros: Great quality for the money
Cons: None
Recommended? Yes
Comments: This was on the Jeep when I bought it and it has performed well. I really do not have anything else to compare it to but it seems to be well built. I researched online and they are reasonably priced compared to others. It is a product made in the USA.
BigOrange
BigOrange's Reviews
10-10-2010, 10:47 PM
Price: $399.99
Pros: nice ride quality, looks pretty good too
Cons: This will probably just lead to me wanting to go higher
Recommended? Yes
Comments: Just installed this two days ago... everything seems to be a of good quality. The ride is only slightly stiffer than stock, but the improvements are huge in the looks department.
tommybio
tommybio's Reviews
08-03-2010, 12:08 PM
Price: $350.00
Pros: Actually 4" lift over sagging stock springs
Cons: none
Recommended? Yes
Comments: Allows 31" tires with no problems - advertised up to 32".
Easy to install, everything was as advertised and built to fit just right.
I have no complaints, whatsoever.
Highly recommended.
freeskier93
Generation Dead
freeskier93's Reviews
06-21-2010, 09:58 PM
Price: $200.00
Pros: Long life
Cons: average ride
Recommended? Yes
Comments: Simple lift, shocks ride average. Not really sure what to compare the ride to though.
dahlski6
dahlski6's Reviews
02-01-2010, 03:03 PM
Price: $750.00
Pros: Fair price, good articulation
Cons: Rough on the road, have bent two springs in the front
Recommended? Yes
Comments: Pretty good on the trail but i would recommend something a little stronger or with a no questions asked warranty(BDS).
honda53rider
honda53rider's Reviews
01-08-2010, 04:41 PM
Price: $0.01
Pros: Its good for a modest 4 wheeling
Cons: still ant tall
Recommended? Yes
Comments: Its a good all around lift, Gives u a good amount of flex but still handles on the road.
duckman1
duckman1's Reviews
09-13-2009, 03:47 PM
Price: $1.00
Pros: Easy Lift
Cons: None apparent
Recommended? Yes
Comments: Installed by my tire dealer. No problems.This lift gives us good clearence and did not effect the ride or the handling of our LJ.
mwhanson
mwhanson's Reviews
08-30-2009, 11:23 AM
Price: $532.00
Pros: Great lift, helps with leaning without sway bars, looks great! Price...4wd.com, wait until they run the 20% off and free shipping, get it for a much better price.
Cons: Con's with any suspension and Jeep...a little stiff. As for the kit itself, no shock boots, no hardware for installing the springs (bolts/nuts), bushings yes.
Recommended? Yes
Comments: This was a great purchase for me...going from a 40 year old suspension to a new one helped with the swaying when taking corners...At speed (55mph) handles bumps better than I thought, great look. It was actually a 2.5" lift, but I think it was a little more from where I was...
kyumanaz
kyumanaz's Reviews
05-24-2009, 10:48 AM
Price: $220.00
Pros: Bigger tires, rides nice
Cons: Not high enough
Recommended? Yes
Comments: It rides nice, bought it with this lift. I would have started bigger.
MattSink
Junior Member
MattSink's Reviews
05-20-2009, 08:51 PM
Price: $400.00
Pros: looks good easy install
Cons: wobble
Recommended? Yes
Comments: hbfhqwbfehebfhs
ROWDY999
ROWDY999's Reviews
01-04-2009, 11:08 AM
Price: $800.00
Recommended? Yes
Comments: VERY NICE RIDE ON OR OFF ROAD HAVE HAD NO PROBLEMS WITH SAGING OR BREAKING SPRINGS
ET48
ET48's Reviews
11-10-2008, 02:40 PM
Price: $700.00
Recommended? Yes
Comments: Very nice lift that ended up with about 3" of lift instead of the 2.5" advertised. Good articulation but kinda rough on the road. Great installation kit and instructions.
tuckertj
tuckertj's Reviews
11-09-2008, 10:34 PM
Price: $400.00
Recommended? Yes
Comments: It's not expensive. It has held up well and I do manage to flex it out as often and as much as I can. It does lift my Jeep to get 33s on there (with BL), the ride is not great.
crusher242
crusher242's Reviews
11-02-2008, 04:43 PM
Pros: Easy installation, great lift, flexs well.
Cons: terrible shocks
Recommended? Yes
Comments: Better ride than stock
Konstadin
Konstadin's Reviews
10-23-2008, 01:41 AM
Price: $400.00
Recommended? Yes
Comments:
JFranko
JFranko's Reviews
10-20-2008, 08:46 PM
Price: $600.00
Recommended? Yes
Comments: can't complain, not the best, not the worst, wish I would of spent the extra $100 and got the fabtech though
tuffie226
tuffie226's Reviews
10-12-2008, 10:35 PM
Price: $650.00
Recommended? Yes
Comments: Little bouncy...great height. Haven't really got to flex it out a lot yet.
ThreadForumRepliesLast Post
Pro Comp ES3000 Shocks 17 10-13-2011 01:50 PM
Pro Comp 4 inch lift with ES3000 shocks Complete Lift Kits 22 09-09-2011 03:45 PM
Pro Comp 2 inch Spring Lift with MX6 Shocks Complete Lift Kits 9 01-18-2011 01:24 PM
Pro Comp 4 in. Suspension System with MX6 Shocks Complete Lift Kits 52 01-14-2011 09:05 AM
pro comp Pro Comp JTB400 - Pro Comp Adjustable Track Bars Track Bars 2 04-11-2010 02:34 PM
Glock Forum
