Kit purchased from DPG Offroad and included JKS front and rear adjustable track bars, JKS front quick disconnects, JKS rear adjustable sway bar links, and OME steering stabilizer.
Good lift and ride quality but don't know if it is worth the money if you are wanting a true 3". Mine came to exactly 3" in the rear but makes me nervous if it will sag lower over time.
I had to have an actual shop do it to comply with warranty, would have preferred to do it myself.
Recommended
yes
Comments: Great lift I think it is better than stock ride, I should have gotten a better SS but I love it, it is solid, make sure you get the HD, which is what I got otherwise it may be a little loose. I got the 3" OME.
Comments: The lift is still new but the rear is riding at 4.5", so the vehicle has some rake to it, front to back. I am waiting to see if it will settle. No wobble or vibrations. It included the transfercase lowering kit which is installed.
Comments: for the price of the lift kit, and the smooth and soft suspension travel, this kit is worth the buy! I would call it the XJ with the cadillac suspension lol
Comments: I purchased the complete Super Ultimate 3.5 lift from Dirk at DPG. The kit came with everything needed to work as a system.
OME XJ Coils(2930), OME Dual Rate Leaf Springs (CS033RB), OME Front Long Travel Shocks(60052L), OME Standard Lenth Rear Shocks(because I got the JKS Shock Mounts(60053)), JKS Disconnects (200D), JKS Adj Trackbar (OGS126), JKS Lower Adj Control Arms (6100), RE SS Brakelines (RE1550), 1.75 in coil spacers(MO2532), DPG HD Ubolts (DPG825U), DPG Ext Bumpstops (DPGNHL2), DPG Disco Cables (DPGDC1), Leaf Bushings, JKS Weld On Shock Mounts (OGS922), RE 4 Degree Shims (RE1467).
kit did not come with adjustable trac bar. go for the 4 inch lift instead. wouldve came with everything needed including the correct length shocks, trac bar and brake lines.
Recommended
yes
Comments: overall very good. the place i got it from did not put the kit together very well. i opted out of ome shocks and got cheaper ones. ended up finally put some procomps 3000 on it. much better! the kit could've been ordered as a 4 inch kit including much more and correct parts i needed. should've, could've kinda thing. next lift i do i think i might just use the ome springs and still part out everything else on my own. but definatley more research.
Comments: The kit is amazing. On the street the jeep rides like a lifted sports car and off road the jeep can hang with the best of them if not out wheel them. I personally love the stiffness of socks but some would complain. A friend told me their old shocks "OME nitrocharger" are softer than their new "OME nitrocharger sport."
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
