Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Fabtech 4" Performance kit
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Fabtech 4" Performance kit Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $1,100.00
Average Price: $866.00
Manufacturer: Fabtech
Recommended?
Yes: 11 / No: 2
Fabtech's 4" Suspension System features four heavy wall tubular lower link arms with rotational urethane pivot joint assemblies on each end to provide articulation like a heim joint but without the noisy highway ride. System includes billet transfer case spacers, pitman arm, rear sway bar links, bump stops, rear trac bar bracket and front sway bar disconnect links. Kit includes front and rear extended length coil springs and will provide clearance for 33x12.50 tires
sjones26573
Teenage Jeeper
sjones26573's Reviews
09-12-2011, 10:25 PM
Price: $1,200.00
Pros: Durable. Perfect for what I need.
Cons: Everythings black except for plain white shocks. Wanted some color or decals but thats what you get with a basic lift.
Recommended? Yes
Comments: Mine is a 4" basic lift. No real cons for this system. Its great
robbijer
robbijer's Reviews
03-28-2011, 12:22 PM
Price: $1,000.00
Pros: Complete kit
Cons: sway bar disconnects are bad
Recommended? Yes
Comments: Nothing exceptionally fancy about the kit. It came on my Jeep from previous owner. Was upgraded to lower control arms with flex joints on each end. The flex joints work and held up well. The sway bar disconnects that come with this kit are not very good at all, very difficult to use, replaced with JKS.
keaton
keaton's Reviews
08-08-2009, 08:42 PM
Price: $150.00
Pros: Good quality parts, decent flex
Cons: none so far
Recommended? Yes
Comments: Pieced the lift together but gave me just the amount of lift i needed and has a mean stance.
spittindurt
spittindurt's Reviews
02-17-2009, 12:54 PM
Price: $900.00
Recommended? No
Comments: Ok lift, not the greatest. LCA's are no longer than stock but the JJ look alike joints do twist/flex very well. Greaseable joints are quite and dont seem to be wearing out. Drop trackbar bracket in front is cracking out and will need to be re welded. Springs seem a little stiff to me. Along with my 1.25'' JKS BL this setup alows me to run 35'' MT's so I'm happy that way. If I had to do again would deff go with some one else RE,RK,etc.
KodiakBuzz
KodiakBuzz's Reviews
12-24-2008, 04:36 AM
Price: $900.00
Recommended? Yes
Comments: hidsfy8fuofiadjofrqfusadufsdifdsjdssdfkjfkjlfkjlds sdflkjsdfkjlsdfkjliadjpoijohaefiowetfhhewehtf4iofh dfd8ihyw8erwhiyoetwfihoetihojpetwhwitwtihjo
Jgrand03
Jgrand03's Reviews
11-26-2008, 01:04 AM
Price: $700.00
Recommended? Yes
Comments: Great kit especially for beginners installing their first lift. The springs are a bit stiff but after removing the trac bars and sway bar it rides a bit smoother
Skatertony528
Skatertony528's Reviews
10-31-2008, 01:56 PM
Price: $990.00
Recommended? Yes
Comments: Great Lift but the guy who helped me put it on messed up the screws in the top of 1 of the shocks and it came out.1 other problem that i had with this lift is that the new lower control arms make alot of noise when i hit bumps but i think i just need new bushings.
Porky
Porky's Reviews
10-16-2008, 07:59 PM
Price: $880.00
Recommended? Yes
Comments: Good lift, no squeeks or rattles. I don't the angle of the sway bar drop links.
mascun
mascun's Reviews
09-29-2008, 07:13 PM
Price: $950.00
Recommended? Yes
Comments: really happy with fabtech straight foward install xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxx
locolongball
locolongball's Reviews
08-16-2008, 04:29 PM
Price: $1,100.00
Recommended? Yes
Comments: I have the basic kit, not performance, if you got the money get the performance. Mine rides stiff, and I would like the detachable sway bars. Not a big deal, I did the upgrade, and I'll upgrade my shocks later. Good Lift.
Rafikie
Rafikie's Reviews
07-30-2008, 10:10 AM
Price: $900.00
Pros: haven't found any
Cons: stiff
Recommended? No
Comments: Actually installed a basic kit. Took 2-3 days to install during my spare time after work. Solid product, however I wish it flexed just a little more. Knowing what I do now I would have gone with a longarm kit instead. Although this kit does perform very, besides having to replace the rear shocks within 1 year do to bad seals.
EDIT: Some more time has passed and I found myself cutting the ends off the LCAs to add Jonny Joints. Rear spring and shocks (yes again for the shocks) have been replaced with BDS components. Changed my recommendation from yes to NO. Save your money or just buy the no name cheap kit and know what your getting up front.
BIG RED86
BIG RED86's Reviews
05-29-2008, 10:17 AM
Price: $722.00
Recommended? Yes
Comments: Over all I am happy with the Fabtech lift that I installed, it has been able to take what i have trown at it so far
onlyn8v
onlyn8v's Reviews
05-18-2008, 08:35 AM
Recommended? Yes
Comments: It does what it should, I got blue they dont offer blue anymore. It looks nice, works well- Im going 6" soon
ThreadForumRepliesLast Post
Poly Performance Synergy Stage III Complete Lift Kits 3 05-22-2009 04:59 PM
Fabtech 3½" Performance System FAB-K4022 Complete Lift Kits 9 02-26-2009 08:52 PM
Poly Performance 4.5" Lift Springs Springs 1 04-27-2008 09:11 PM
Glock Forum
