Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > Fabtech 3½" Performance System FAB-K4022
Fabtech 3½" Performance System FAB-K4022 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
Rating:
Product Information
MSRP: $850.00
Average Price: $546.67
Manufacturer: Fabtech 3½" Performance System
Recommended?
Yes: 9 / No: 1
Heavy duty front and rear leaf spring springs feature nylon glide pads between each leaf for a friction free ride. Front springs employ 5 leafs while rear springs are comprised of a 4 leaf pack. Front and rear spring eyes are constructed with a full military style wrap for superior strength and dependability. The transfer case is relocated via billet spacers that allow the use of the stock skid plate. This system comes complete with a drop pitman arm, extended sway bar links, track bar relocation brackets and more.
bimmerboy570
bimmerboy570's Reviews
08-31-2010, 09:40 PM
Price: $500.00
Pros: The ride height didn't seem to change as if the springs were beginning to sag even when i put the hard top on or towing a trailer.
Cons: The Bracket for the front track bar comes lose, and you have to use aftermarket shackles because my springs hit my frame and limit my flex.
Recommended? Yes
Comments: All together this seemed to be a quality product. Fabtech however did put this on clearance when i purchased it and i got lucky with my price. I have to say that with the minor issues with the track bar bracket and the frame issue with the springs which is to be expected because of the force that is put on those two areas and because of such a thicker spring. i am happy with my purchase and i have been running it for about two years now.
KevinM90
KevinM90's Reviews
02-26-2009, 08:52 PM
Price: $3.00
Recommended? Yes
Comments: yea bub it works mint
typersx
typersx's Reviews
01-20-2009, 11:19 AM
Price: $850.00
Recommended? Yes
Comments: not............................... to..............................
bad...............................
stevenmh
stevenmh's Reviews
06-04-2008, 02:39 PM
Recommended? Yes
Comments: like it, little stiff but stayed pretty level. also have a 2 inch shackle lift on there
chupacabrah
chupacabrah's Reviews
05-02-2007, 02:31 PM
Price: $670.00
Pros: Not *very* expensive, great quality, everything you need, good articulation
Cons: ? none
Recommended? Yes
Comments: I have had this kit for over a year, and have wheeled fairly often. the springs are stiff at first, but soften up a bit after a while. although they still aren't the most comfortable out there.
I recently got rid of the d35 and opted for an 8.8. i have not gone wheeling yet with this setup, but i have no reason to complain about this kit at all.
It nets at LEAST 3.5". I fit 33" mud tires with plenty of room.
That's really everything I can think of....I would definitely recommend this product
Brudmike7
Brudmike7's Reviews
01-29-2007, 11:39 AM
Price: $650.00
Pros: Complete Kit, Relatively inexspensive compared to other high end kits.
Cons: The thing I was most dissappointed with was the amount of flex in the rear. I thought it should have had more droop.
Recommended? Yes
Comments: The t-case drop had huge spacers. It caused a little bit of difficulty shifting in the cold. I put in the cv drive shaft and the slip yolk eliminator and that problem went away. I wanted to do a little bit of more difficult wheeling. If I could do it all over again I would go with a spring over for more flex and height or the Rubicon Express 4.5 heavy duty lift.
srad711
srad711's Reviews
01-11-2007, 07:39 AM
Recommended? Yes
Comments: . Install vey easy, quality of parts excellent, fitment excellent.
Lift full 3.5 if not a little more. Ride excellent could not ask for anything better on or off road.
****extras needed: greasable shackles extended brake lines thats it.
jrnjay
jrnjay's Reviews
09-20-2006, 06:53 PM
Pros: Everything in 1 order!
Cons: The shocks are just OK
Recommended? Yes
Comments: For a leaf spring lift I believe it softened up very fast. No sag after some good beatings. Inexpensive by comparison and high quality.
savage1978
savage1978's Reviews
08-25-2006, 01:13 AM
Pros: completness
Cons: Stiffness
Recommended? No
Comments: Way too stiff
Leroux
Leroux's Reviews
08-03-2006, 10:09 AM
Price: $607.00
Pros: Very complete, great fitting, good offroad quality
Cons: Rough riding at first, smooths out after some wheelin
Recommended? Yes
Comments: Great kit, very good quality. Seems to have great flexibility with track/sway bars removed. I bought it because it 4wheelonline was having such a good sale. Excellent alternative to BDS and Rubicon Express.
ThreadForumRepliesLast Post
Fabtech 4" Performance kit Complete Lift Kits 11 08-08-2009 08:42 PM
Poly Performance Synergy Stage III Complete Lift Kits 3 05-22-2009 04:59 PM
TnT Customs 5.5" - 7.5" Y-link System Complete Lift Kits 7 05-06-2009 09:59 PM
Teraflex S/T swaybar system Steering Stabilizers 1 05-11-2008 01:52 PM
Poly Performance 4.5" Lift Springs Springs 1 04-27-2008 09:11 PM
Glock Forum
