BDS Suspension 4" 4WD Jeep Grand Cherokee WJ Coil System
Rating: |
Product Information
| MSRP: |
$1,200.00 |
| Average Price: |
$990.20 |
| Manufacturer: |
BDS Suspension |
| Recommended? |
This kit comes with new front and rear Pro-Ride coils springs capable of handling full coil bind. Lower adjustable control arms are included to allow you to adjust the axle rotation(castor). These adjustable arms come with greasable urethane ends for long term performance. Both a dropped pitman arm and track bar relocation are included to return your steering angle to stock. A transfer case drop kit is included to reduce drive line angles. Rear anti-sway bar links are included to ensure optimal performance of your rear sway bar. A rear upper tri-link spacer is incuded to flatten out the tri-link system. This is a complete system designed to make your WJ go where it has never been !
Max. Tire Size: 31" x 10.50"
Max. Wheel Size: 16 x 8
Back Spacing: Stock
Est. Installation: 4 hours
Difficulty Level (easy 1 - 5 complicated): 3
94yj03wj's Reviews
Price: $1,050.00 Pros: A complete kit with everything that is absolutly necessary. Cons: The ride is a bit rougher but that is to be expected. Recommended? Yes
Comments: I got my lift at a local 4x4 accessories shop and i also had him install it.(AutoSport on Rt.17 North, Upper Saddle River, NJ). Now that i look back at what the kit came with, I feel confident that i would have been able to in stall it my self but oh well. Overall it is a great kit and has really set my jeep apart from the crowd especially with my 32 inch goodyear duratracs. If you're thinking on keeping the stock wheels with stock backspacing then i recomend 265/75/R16 size tires. They fill the wheel wells nicely and still alow plenty of room for articulation. With stock backspacing however i do have my drivers side tire rub the lower control arm at full lock when making a left turn. It's not a big deal and i've gotten used to it but just wanted to throw that out there. Also, with stock backspacing the rear tires may contact the shocks when you are articulated or are pulling into a driveway at an angle. This can be solved by placing some washers between the upper shock mount and the shock's eye to move it away from the tire a little. All in all it's a great product and I definitely recomend this to anyone who wants to put more than just a budget boost on their WJ.
Khorat77's Reviews
Price: $400.99 Pros: looks good can clear 31's easily Cons: Not quite as high as I wanted Recommended? Yes
Comments: This lift makes the jeep look much better than stock height. It can clear 31's easily but not much more. 32's will rub.
fewmanchue's Reviews
Price: $1,200.00 Pros: nice stance, rides smooth Cons: sqeaks a little Recommended? Yes
Comments: love the look it gives my wj
xjmark85's Reviews
03-26-2008, 04:40 PM |
Price: $1,200.00 Recommended? Yes
Comments: the BDS is a good company to go with but i wish they made a long arm suspension also
tjthomps's Reviews
03-12-2008, 10:36 PM |
Price: $1,100.00 Recommended? Yes
Comments: Mechanic Installed. Looks great, gets a lot of looks and comments matched up great with the MT MTZ's although could not use maximum tire size BDS said we could with stock wheels.
