2" coil spacer kit Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
2" coil spacer kit
Rating:
Product Information
MSRP: $250.00
Average Price: $129.88
Manufacturer: zone off road
Recommended?
Yes: 90 / No: 6
Company Website: http://www.zoneoffroad.com
i love the kit, it comes with good instructions, was easy to install and performs well too. the 2" lift gives a more agresive lift and gives you plenty of room to torque around your 31s
None
Page 5 of 5 1 2 3 4 5
dirtykoala
Junior Member
dirtykoala's Reviews
12-06-2009, 01:33 PM
Price: $235.00
Pros: looks great, easy to install in theroy, good ride quality, more clearence
Cons: not actually easy to install, instructions werent so good
Recommended? Yes
Comments: best bang for your buck IMO. instructions say that spring compressors are an optional needed tool, they are not, you must use them. havnt taken it on the trails yet, but so far so good
RMTC
RMTC's Reviews
11-24-2009, 01:14 PM
Price: $80.00
Pros: Cheap
Cons: Cheap
Recommended? Yes
Comments: Gives me a little clearance for more tire until I actually lift it.
oj707
oj707's Reviews
10-26-2009, 05:50 PM
Price: $80.00
Pros: super cheap way to lift
Cons: super cheap way to lift
Recommended? No
Comments: i did this only because i took the body lift off that came with the jeep but wanted to keep the same height. works fine
jeepgcnewbie
jeepgcnewbie's Reviews
10-19-2009, 08:26 PM
Price: $300.00
Pros: with factory spacers had a total of 3" lift
Cons: only 3" lift. spacers only on spring not shock.
Recommended? Yes
Comments: I like the spacer because they were inexpensive and easy to find. I would suggest a complete kit with shocks instead of just spacers. This kit is nice for driving but i would go with more if i was going to do more than trails.
ElGuapoBond
ElGuapoBond's Reviews
10-03-2009, 08:35 PM
Price: $20.00
Pros: 1.5 inch spring spacer in front and .75 spring spacer in rear leveled out things with the RC 2.5 lift and gave me a total of 4 inches total lift.
Cons: Cannot run stock sway bar connectors, must go aftermarket 3"-6".
Recommended? Yes
Comments: Any spring spacer if installed correctly will work fine, if you have the RC 2.5 inch lift kit the .75 spacer up front will level you out just fine but for used spacers at 20.00 that was a great price to go up to 4 inches of lift.
silvzj95
silvzj95's Reviews
09-16-2009, 09:50 PM
Price: $70.00
Pros: gives a nice stance
Cons: none
Recommended? Yes
Comments: great start out for anyone just gettin into it/ or a dd
dilligaf69
dilligaf69's Reviews
09-15-2009, 12:15 AM
Price: $35.00
Pros: Easy Installation, no fuss, no foul
Cons: none
Recommended? Yes
Comments: Easiest lift product to install, no mods needed.
Material is Nylon, no noise or vibrations while off roading or on road.
Did not require use of a coil spring compressor for installation.
Have had installed for over 6 months without any problems or complaints.
No noticable change in alignment with this small amount of lift, can use stock shocks unless you plan on hardcore flexing.
kale2s
kale2s's Reviews
09-07-2009, 12:48 PM
Price: $59.00
Pros: easy install. cheap
Cons: none
Recommended? Yes
Comments: easy install, cheap
jeffrayy
jeffrayy's Reviews
09-02-2009, 09:33 PM
Price: $57.00
Pros: not sure
Cons: not sure
Recommended? Yes
Comments: Rubican Express 2" bb from Kolak (still waiting on the rear shocks that are on back order).
k00s
k00s's Reviews
08-31-2009, 02:50 PM
Price: $400.00
Pros: DIY installation
Cons: the quick disconnects do some times stick but some WD-40 will do the trick.
Recommended? Yes
Comments: The Zone 2" Spacer Lift kit is easy to install and does what you want it to do. The price is not that steep and competes with most of the other brands we have in South Africa.
pstack3315
pstack3315's Reviews
08-28-2009, 12:07 PM
Price: $50.00
Pros: Cheap, improves look, etc..
Cons: Didnt come with shocks
Recommended? Yes
Comments: Got it at PA Jeep show at a great price. Would definitly recomend
psyopsdm
psyopsdm's Reviews
07-23-2009, 08:46 PM
Price: $239.99
Pros: Inexpensive, gives a nice aggressive stance with minimal effect on center of gravity. Does everything it claims: provide an economic and capable lift for those looking to run a 31 or 32 inch tire.
Cons: Rubicon Express: Twin tube shocks are a bit stiff... will probably switch to RE mono's or Bilstien 7100s
Recommended? Yes
Comments: Love the lift height and the flex I got. I wish the shocks were a little more forgiving but that is easily remedied with an upgrade down the road. Works great with 31x10.50s.
corkyjr05
corkyjr05's Reviews
07-14-2009, 06:14 PM
Price: $60.00
Pros: more room for larger tires
Cons: limited flex
Recommended? Yes
Comments: Ive had a few friends who have done spacer lifts in the past. It allows for the running of larger tires but is limited by the stock shocks and the stock spring.
ThreadForumRepliesLast Post
Rough Country 3.25" Progressive Coil/Spacer Kit for 97-06 TJ Complete Lift Kits 78 04-01-2015 05:45 PM
Rough Country 2" spring spacer Springs 12 01-31-2015 02:22 AM
Daystar 2" Coil Spacer Springs 16 03-03-2013 07:56 PM
Iron Rock Offroad 4" coil springs Springs 3 09-16-2009 03:38 PM
TrailMaster 2" Spring Spacer Lift Complete Lift Kits 1 04-14-2008 04:51 PM
