2" coil spacer kit
Rating: |
Product Information
i love the kit, it comes with good instructions, was easy to install and performs well too. the 2" lift gives a more agresive lift and gives you plenty of room to torque around your 31s
rollercam351's Reviews
Price: $115.00 Pros: Drives exactly the same(awesome) gave me clearance for the bigger tires Cons: could be just a tad larger than 2" now that i put a winch up front i lost a little, coil overs would be a better choice for some adjustment Recommended? Yes
Comments: Skyjacker 2" budget boost, red polyurethane pucks that sit on top of your coils with or without your original rubber pads, can be installed in about 2hrs with basic tools, so far so good, gets me by till i can buy that 4" long arm i want
firemerc99's Reviews
Price: $200.00 Pros: much better look with bigger tires Cons: should have gotten longer shocks Recommended? Yes
Comments: bought as a body and spring spacer kit, that is why so expensive. They were fairly easy to install once i figured out what I was doing. The body lift was never installed.
dirtykoala's Reviews
Price: $235.00 Pros: looks great, easy to install in theroy, good ride quality, more clearence Cons: not actually easy to install, instructions werent so good Recommended? Yes
Comments: best bang for your buck IMO. instructions say that spring compressors are an optional needed tool, they are not, you must use them. havnt taken it on the trails yet, but so far so good
RMTC's Reviews
Price: $80.00 Pros: Cheap Cons: Cheap Recommended? Yes
Comments: Gives me a little clearance for more tire until I actually lift it.
oj707's Reviews
Price: $80.00 Pros: super cheap way to lift Cons: super cheap way to lift Recommended? No
Comments: i did this only because i took the body lift off that came with the jeep but wanted to keep the same height. works fine
jeepgcnewbie's Reviews
Price: $300.00 Pros: with factory spacers had a total of 3" lift Cons: only 3" lift. spacers only on spring not shock. Recommended? Yes
Comments: I like the spacer because they were inexpensive and easy to find. I would suggest a complete kit with shocks instead of just spacers. This kit is nice for driving but i would go with more if i was going to do more than trails.
ElGuapoBond's Reviews
Price: $20.00 Pros: 1.5 inch spring spacer in front and .75 spring spacer in rear leveled out things with the RC 2.5 lift and gave me a total of 4 inches total lift. Cons: Cannot run stock sway bar connectors, must go aftermarket 3"-6". Recommended? Yes
Comments: Any spring spacer if installed correctly will work fine, if you have the RC 2.5 inch lift kit the .75 spacer up front will level you out just fine but for used spacers at 20.00 that was a great price to go up to 4 inches of lift.
silvzj95's Reviews
Price: $70.00 Pros: gives a nice stance Cons: none Recommended? Yes
Comments: great start out for anyone just gettin into it/ or a dd
dilligaf69's Reviews
Price: $35.00 Pros: Easy Installation, no fuss, no foul Cons: none Recommended? Yes
Comments: Easiest lift product to install, no mods needed.
Material is Nylon, no noise or vibrations while off roading or on road.
Did not require use of a coil spring compressor for installation.
Have had installed for over 6 months without any problems or complaints.
No noticable change in alignment with this small amount of lift, can use stock shocks unless you plan on hardcore flexing.
kale2s's Reviews
Price: $59.00 Pros: easy install. cheap Cons: none Recommended? Yes
Comments: easy install, cheap
jeffrayy's Reviews
Price: $57.00 Pros: not sure Cons: not sure Recommended? Yes
Comments: Rubican Express 2" bb from Kolak (still waiting on the rear shocks that are on back order).
k00s's Reviews
Price: $400.00 Pros: DIY installation Cons: the quick disconnects do some times stick but some WD-40 will do the trick. Recommended? Yes
Comments: The Zone 2" Spacer Lift kit is easy to install and does what you want it to do. The price is not that steep and competes with most of the other brands we have in South Africa.
pstack3315's Reviews
Price: $50.00 Pros: Cheap, improves look, etc.. Cons: Didnt come with shocks Recommended? Yes
Comments: Got it at PA Jeep show at a great price. Would definitly recomend
psyopsdm's Reviews
Price: $239.99 Pros: Inexpensive, gives a nice aggressive stance with minimal effect on center of gravity. Does everything it claims: provide an economic and capable lift for those looking to run a 31 or 32 inch tire. Cons: Rubicon Express: Twin tube shocks are a bit stiff... will probably switch to RE mono's or Bilstien 7100s Recommended? Yes
Comments: Love the lift height and the flex I got. I wish the shocks were a little more forgiving but that is easily remedied with an upgrade down the road. Works great with 31x10.50s.
corkyjr05's Reviews
Price: $60.00 Pros: more room for larger tires Cons: limited flex Recommended? Yes
Comments: Ive had a few friends who have done spacer lifts in the past. It allows for the running of larger tires but is limited by the stock shocks and the stock spring.
