Go Back JeepForum.com > Reviews > Suspension > Complete Lift Kits > 2" coil spacer kit
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
2" coil spacer kit Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Complete Lift Kits Next Product
2" coil spacer kit
Rating:
Product Information
MSRP: $250.00
Average Price: $130.18
Manufacturer: zone off road
Recommended?
Yes: 72 / No: 5
Company Website: http://www.zoneoffroad.com
i love the kit, it comes with good instructions, was easy to install and performs well too. the 2" lift gives a more agresive lift and gives you plenty of room to torque around your 31s
None
Page 2 of 4 1 2 3 4 > Last »
reeds86xj
reeds86xj's Reviews
12-28-2011, 04:00 PM
Price: $160.00
Pros: lift, bigger tires...
Cons: none
Recommended? Yes
Comments: I have a 2" spacer lift, and i also have upcountry springs. the lift netted me right around 3" of lift. i love it.
scarface82
scarface82's Reviews
12-09-2011, 08:49 PM
Price: $50.00
Pros: 2" of lift
Cons: Metal made Spacers
Recommended? Yes
Comments: Home made 2" spring spacer, work good for me.
vulcanclassic
vulcanclassic's Reviews
12-02-2011, 06:28 PM
Price: $259.00
Pros: AEV 2" spacer lift...Great lift so far
Cons: Front brake line routing is recommended to be zip-tied to shocks and disconnected from lower spring perch bracket per AEV instructions, not sure this is best idea...
Recommended? Yes
Comments: Great lift, accomplished what I set out to do...
Got me up and level, easily clears 33's..could use better solution for F & R brake line extension or re-routing to achieve slack
mreed21
mreed21's Reviews
11-09-2011, 11:55 AM
Price: $105.00
Pros: Very cheap price and a good way to get a 2 inch lift.
Cons: I wish it was new coil springs
Recommended? Yes
Comments: This is a good product for the money. I hope it will serve me well.
kazootom
kazootom's Reviews
10-25-2011, 10:44 PM
Price: $39.95
Pros: Fits perfect, Did not change the ride quality.
Cons: none so far
Recommended? Yes
Comments: The kit has a 2" spcer in the front with 2" shackle exstention in the rear. You can use the stock shocks. Ride quality is great.
99TJNC
99TJNC's Reviews
10-18-2011, 12:56 AM
Price: $249.00
Pros: Jeep looks great, drives great, and is much better than before
Cons: Instructions could be a little more clear, had to use a write up I saw on here to figure some parts out.
Recommended? Yes
Comments: I installed this kit with the help of my dad 2 days ago. It says it should take 2-3 hours, it took us 4.5 hours, but this was our first time messing with a newer model vehicles suspension, especially with a Jeep.
I love how the Jeep drives now, I did upgrade to the nitro shocks. It looks much better now, and I look forward to testing it out off road in a couple of weeks.
The instructions were a little lacking in parts, and I was able to complete the lift easily due to a write up I found on here.
Overall I am very impressed with this kit, and for the money, it was well worth it. And I had no driveline vibes or anything, and I haven't gotten an alignment yet, but plan on it later this week.
tinman77
tinman77's Reviews
10-10-2011, 12:40 AM
Price: $250.00
Pros: Easy install
Cons: Advertise that you can fit 31's however you cannot! Tires rub way to much and endded up ripping my fog lights out
Recommended? Yes
Comments: Very easy to install, no need to make any modes to the drive train. However you need to be aware of the amount of tire rub due to the small wheel wells of the Grand Cherokee
kcaisse
kcaisse's Reviews
08-21-2011, 11:52 AM
Price: $100.00
Pros: easy to install
Cons: jeep wobbly around corners
Recommended? Yes
Comments: Cheap easy way to upgrade tires
Glaze22
Glaze22's Reviews
08-12-2011, 03:52 AM
Price: $220.00
Pros: very comfortable
Cons: not a big enough lift lol
Recommended? Yes
Comments: basically...if you want a lift, and dont want to spend a lot, this is the way to go. very comfortable ride, the height is ok but its better if you add 31 inch tires. makes it look beefy.
uplandhawaii
uplandhawaii's Reviews
07-31-2011, 10:19 PM
Price: $40.00
Pros: Easy to install, pretty standard poly spacer from RuKs
Cons: not sure on the durability of the spacers, time will tell.
Recommended? Yes
Comments: Price was right, hope it lasts.
Silver_Sport
Silver_Sport's Reviews
06-25-2011, 11:27 PM
Price: $60.00
Pros: Easy lift and good budget boost
Cons: Not a spring lift
Recommended? Yes
Comments: Good cheap lift
nbouchaf16
nbouchaf16's Reviews
06-23-2011, 06:16 AM
Price: $130.00
Cons: none
Recommended? Yes
Comments: n/a
pepe91
pepe91's Reviews
06-21-2011, 03:43 PM
Price: $250.00
Pros: .
Cons: .
Recommended? Yes
Comments: .
nadman009
nadman009's Reviews
06-14-2011, 09:47 AM
Price: $150.00
Pros: Much improves stock ground clearance.
Cons: Not quite high enough, but makes a big difference.
Recommended? Yes
Comments: I think the spacers make a huge difference. Not too sure on the price because the jeep came with them on. However, compared to a stock suspension these spacers do a great job to get the jeep off the ground. Plus I can fit 31s now too.
Foundrydude
Foundrydude's Reviews
04-30-2011, 12:47 PM
Price: $55.00
Pros: Cost/ease
Cons: stock trailing arms
Recommended? Yes
Comments: 2" makes it sit like jeep shoulda sold em.
2007UnlimitedNJ
2007UnlimitedNJ's Reviews
04-09-2011, 11:21 AM
Price: $320.00
Pros: Looks great and rides nice
Cons: Instructions were not as clear as they could have been. They were pretty good.
Recommended? Yes
Comments: The SkyJacker 2 in lift is great to give you just a little more height. It makes the stock Jeep look as it should.
heretolearn
heretolearn's Reviews
04-07-2011, 06:03 PM
Price: $125.00
Pros: great for the money
Cons: I want to go higher
Recommended? Yes
Comments: It is an ok product for the money I just wish i went a little higher
ZJtothaTJ
ZJtothaTJ's Reviews
04-04-2011, 07:30 PM
Price: $85.00
Pros: Simple lift
Cons: Not enough lift!
Recommended? Yes
Comments: Cheap way to add larger tires!
ZJtothaTJ
ZJtothaTJ's Reviews
Price: $85.00
Pros: Simple lift
Recommended? Yes
ImportInvasion
ImportInvasion's Reviews
03-15-2011, 03:29 PM
Price: $100.00
Pros: Big difference in height
Cons: Uses stock suspension components
Recommended? Yes
Comments: Depending on your needs, this is a great kit to install. My spacers gave my rig a TRUE 2" increase in lift, and are made from Delrin which will not compress. They also were fairly easy to install, and came with everything I needed. Perfect for those who need the lift, but not ready for changing all their suspension components.
ThreadForumRepliesLast Post
Rough Country 2" spring spacer Springs 7 03-04-2013 11:07 AM
Daystar 2" Coil Spacer Springs 16 03-03-2013 07:56 PM
Rough Country 3.25" Progressive Coil/Spacer Kit for 97-06 TJ Complete Lift Kits 65 01-11-2013 10:41 PM
Iron Rock Offroad 4" coil springs Springs 3 09-16-2009 03:38 PM
TrailMaster 2" Spring Spacer Lift Complete Lift Kits 1 04-14-2008 04:51 PM
Jeep Parts at Andy's
