2" coil spacer kit
Rating: |
Product Information
i love the kit, it comes with good instructions, was easy to install and performs well too. the 2" lift gives a more agresive lift and gives you plenty of room to torque around your 31s
RubiconBrute's Reviews
Price: $200.00 Pros: good and cheap Cons: not high enough. lol Recommended? No
Comments: good lift now squeaks and dont break.
vonericsen's Reviews
Price: $60.00 Pros: cheap lift, but good for a budget. Not too difficult to install. Cons: rear spring post in the ZJ is completely covered so it needs to be extended with some tubing or something. Recommended? Yes
Comments:
reeds86xj's Reviews
Price: $160.00 Pros: lift, bigger tires... Cons: none Recommended? Yes
Comments: I have a 2" spacer lift, and i also have upcountry springs. the lift netted me right around 3" of lift. i love it.
scarface82's Reviews
Price: $50.00 Pros: 2" of lift Cons: Metal made Spacers Recommended? Yes
Comments: Home made 2" spring spacer, work good for me.
vulcanclassic's Reviews
Price: $259.00 Pros: AEV 2" spacer lift...Great lift so far Cons: Front brake line routing is recommended to be zip-tied to shocks and disconnected from lower spring perch bracket per AEV instructions, not sure this is best idea... Recommended? Yes
Comments: Great lift, accomplished what I set out to do...
Got me up and level, easily clears 33's..could use better solution for F & R brake line extension or re-routing to achieve slack
mreed21's Reviews
Price: $105.00 Pros: Very cheap price and a good way to get a 2 inch lift. Cons: I wish it was new coil springs Recommended? Yes
Comments: This is a good product for the money. I hope it will serve me well.
kazootom's Reviews
Price: $39.95 Pros: Fits perfect, Did not change the ride quality. Cons: none so far Recommended? Yes
Comments: The kit has a 2" spcer in the front with 2" shackle exstention in the rear. You can use the stock shocks. Ride quality is great.
99TJNC's Reviews
10-17-2011, 11:56 PM |
Price: $249.00 Pros: Jeep looks great, drives great, and is much better than before Cons: Instructions could be a little more clear, had to use a write up I saw on here to figure some parts out. Recommended? Yes
Comments: I installed this kit with the help of my dad 2 days ago. It says it should take 2-3 hours, it took us 4.5 hours, but this was our first time messing with a newer model vehicles suspension, especially with a Jeep.
I love how the Jeep drives now, I did upgrade to the nitro shocks. It looks much better now, and I look forward to testing it out off road in a couple of weeks.
The instructions were a little lacking in parts, and I was able to complete the lift easily due to a write up I found on here.
Overall I am very impressed with this kit, and for the money, it was well worth it. And I had no driveline vibes or anything, and I haven't gotten an alignment yet, but plan on it later this week.
tinman77's Reviews
Price: $250.00 Pros: Easy install Cons: Advertise that you can fit 31's however you cannot! Tires rub way to much and endded up ripping my fog lights out Recommended? Yes
Comments: Very easy to install, no need to make any modes to the drive train. However you need to be aware of the amount of tire rub due to the small wheel wells of the Grand Cherokee
kcaisse's Reviews
Price: $100.00 Pros: easy to install Cons: jeep wobbly around corners Recommended? Yes
Comments: Cheap easy way to upgrade tires
Glaze22's Reviews
Price: $220.00 Pros: very comfortable Cons: not a big enough lift lol Recommended? Yes
Comments: basically...if you want a lift, and dont want to spend a lot, this is the way to go. very comfortable ride, the height is ok but its better if you add 31 inch tires. makes it look beefy.
uplandhawaii's Reviews
Price: $40.00 Pros: Easy to install, pretty standard poly spacer from RuKs Cons: not sure on the durability of the spacers, time will tell. Recommended? Yes
Comments: Price was right, hope it lasts.
Silver_Sport's Reviews
Price: $60.00 Pros: Easy lift and good budget boost Cons: Not a spring lift Recommended? Yes
Comments: Good cheap lift
nadman009's Reviews
Price: $150.00 Pros: Much improves stock ground clearance. Cons: Not quite high enough, but makes a big difference. Recommended? Yes
Comments: I think the spacers make a huge difference. Not too sure on the price because the jeep came with them on. However, compared to a stock suspension these spacers do a great job to get the jeep off the ground. Plus I can fit 31s now too.
Foundrydude's Reviews
Price: $55.00 Pros: Cost/ease Cons: stock trailing arms Recommended? Yes
Comments: 2" makes it sit like jeep shoulda sold em.
2007UnlimitedNJ's Reviews
Price: $320.00 Pros: Looks great and rides nice Cons: Instructions were not as clear as they could have been. They were pretty good. Recommended? Yes
Comments: The SkyJacker 2 in lift is great to give you just a little more height. It makes the stock Jeep look as it should.
heretolearn's Reviews
Price: $125.00 Pros: great for the money Cons: I want to go higher Recommended? Yes
Comments: It is an ok product for the money I just wish i went a little higher
ZJtothaTJ's Reviews
Price: $85.00 Pros: Simple lift Cons: Not enough lift! Recommended? Yes
Comments: Cheap way to add larger tires!
