Go Back JeepForum.com > Reviews > Suspension > Shocks > Old Manu Emu Nitrochargers
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old Manu Emu Nitrochargers Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Shocks Next Product
Rating:
Product Information
MSRP: $400.00
Average Price: $219.63
Manufacturer: Old Manu Emu
Recommended?
Yes: 50 / No: 1
Of the many factors OME considers when designing Nitrocharger shocks, valving is the most important. In fact, it`s the valving process that sets Nitrochargers apart. our OME engineers are specialists who do nothing but 4WD suspension.
Features that make the difference:
� Tough urethane bushes for extended life
� Steel stone guard provides maximum protection for the piston rod - where the design allows
� Super strong 18mm chromed piston rod
� Low pressure Nitrogen gas for optimum performance
� Tough twin tube design with super strong 1.6mm thick reserve tube protects vital internal components
� Supplementary top & bottom welds give added strength and safety
Page 1 of 3 1 2 3 > Last »
IrishRED
4-Banger Forever!
IrishRED's Reviews
01-29-2012, 07:42 AM
Price: $75.00
Pros: better than stock ride
Cons: none
Recommended? Yes
Comments: I got these shocks to replace the Rough Country 2.2 shocks that came with the 2.5" lift kit. They are much much better riding both on and off road and I would definitely say they are even better than stock without the lift.
mbardeen
mbardeen's Reviews
12-04-2011, 09:30 AM
Price: $120.00
Pros: Smooth controlled ride, easy install.
Cons: Price
Recommended? Yes
Comments: Just replaced some no-name shocks with OME Nitrochargers, N35 and N36, on the four corners. What a difference! Previously the Jeep was very harsh and you felt every bump and crack in the road. Worse, there was a lot of body roll around corners. With the Nitrochargers the ride is very smooth and body roll is well controlled. Feels like a new Jeep! Highly recommended!
lupinsea
lupinsea's Reviews
07-19-2011, 07:13 PM
Price: $300.00
Pros: Excellent ride, a nice balance between good control but not too harsh
Cons: They do need to be matched with the proper spring
Recommended? Yes
Comments: Been running the OME's now for about 2-3 years. When I first put them on they were an upgrade from my old budge boost shocks (Doeshtec DT3000s). The ride was so-so since I was still using stock rear springs and spacers and some unknown no-name "HD" 2" lift spring up front (to deal with a winch).
It wasn't until I installed some progressive rate springs that allowed the OME shocks to really shine. The ride now is very good. Excellent balance between control and smoothness that's taken the edge off the sharp small bumps on the road. Offroad the Jeep feels like it's running on marshmallows vs. the old setup.
In any case, the OME shocks are nicely valved for the TJ provided you get appropriately matched spring rates. The rest of the shock is very well built with bar pins pre-installed and vulcanized to the shock bushings so they won't slide around on the bar pin and clank on the frame.
GIGIO
GIGIO's Reviews
02-06-2011, 01:41 AM
Price: $1,567.42
Pros: 4 shocks included as part of OME Old Man Emu CY-to-YJ Conversion Kit produced by Rocky Road Outfitters.
Cons: As mentioned in the related leaf spring review, products took awhile to get from Australia, but the imported ARB was very very helpful and expedited the one missing shock overnight without charge.
Recommended? Yes
Comments: Really a great, heavy-duty product. Although I was happy with the KYB units I had prematurely installed, after this new Jeeper realized that the leaf springs needed to be changed, I opted for the longer OME springs for a YJ which also lifted the vehicle about 2.5" - 3.0" From the quality of it all, I would anticipate this set lasting for another 35 years. 1975 Jeep CJ-5
Barbarian
Barbarian's Reviews
10-05-2010, 10:57 AM
Price: $90.00
Pros: Great ride. on and off road. didnt take long at all to adjust to. color matched my jeep.
Cons: none at all yet.
Recommended? Yes
Comments: got instaled a little over a month ago. alraound great shock. on and off road. highway speeds and trail riding. work great. have a 4.5 inch lift and ride is easliy better than stock. appreciate it aussies
JDEEEWP
JDEEEWP's Reviews
09-24-2010, 07:08 AM
Price: $83.00
Pros: Poly Bushings upper shield
Cons: Upper rear bolt area gets tight with the upper shield, still possible.
Recommended? Yes
Comments: N66 and N67 installed on my TJ w/ 2"bb, and 32"s around 16" rims.
Ride is nice and perfectly smooth. you can tell it was designed for the TJ and not every truck with the same shock dimensions.
thedirtman
thedirtman's Reviews
08-07-2010, 09:41 AM
Price: $80.00
Pros: Great ride better than the stock. these are the nitro sport installed with the ome heavy duty springs
Cons: Not my favorite color
Recommended? Yes
Comments: I installed these ome nitro sport shocks with the ome heavy duty springs and love the ride. This is the first lift that I have put on one of my jeeps and I got 4" of lift out of it. The ride is great no swaying or feeling top heavy. It really smoothes out the washboard vibrations on county roads.
Chris_XJ
Chris_XJ's Reviews
06-24-2010, 03:27 AM
Price: $1.00
Pros: 0
Cons: 0
Recommended? Yes
Comments: Came with the Jeep when I bought it and I will rock em til they die.
Nicho
Nicho's Reviews
06-11-2010, 09:20 PM
Price: $90.00
Pros: Much better control & handling on road & off.
Cons: none so far except pretty pricey!
Recommended? Yes
Comments: Much better control & handling on road & off.
CrawlorClimb
CrawlorClimb's Reviews
05-24-2010, 09:31 AM
Price: $250.00
Pros: Very quality product
Cons: Kinda spendy.
Recommended? Yes
Comments: Great shock that exudes quality and really helps to control the shocks from the 4" OME coils I have.
Fox01V
Junior Member
Fox01V's Reviews
05-19-2010, 11:40 AM
Price: $150.00
Pros: -solid product that rides real nice -heavy duty stone guard
Cons: none
Recommended? Yes
Comments: I upgraded to these when I got my RE 3.5" lift got all 4 for $150 and I'm glad I got them now.
Creativetopia
Creativetopia's Reviews
04-23-2010, 11:41 PM
Price: $84.99
Pros: Great lift and ride.
Cons: Yellow Shocks (instead of black)
Recommended? Yes
Comments: These shocks are the best on the market. I am really happy with the results and height!
RockMonster
RockMonster's Reviews
04-22-2010, 01:28 AM
Price: $100.00
Pros: amazin on/off road ride
Cons: none
Recommended? Yes
Comments: i run thease shocks with a 4" lift and they ride great on and off road. they allow for exceptional flex while maintining the best road manners in the biz.
BonesWK
Right Coast
BonesWK's Reviews
03-03-2010, 12:35 PM
Price: $79.99
Pros: Nice ride
Cons: price
Recommended? Yes
Comments: Nice Shock, especially with the lift
trotsjeep
trotsjeep's Reviews
02-20-2010, 08:45 PM
Price: $75.00
Pros: Gas CHarged and they aren't hydraulic
Cons: nothing
Recommended? Yes
Comments: OME are the premier shocks on the market. If you can swallow the price they are worth all the money and time spent putting them in. From the road to the trail they are a great all around shock and I would use nothing else.
Bevers
Bevers's Reviews
01-22-2010, 06:27 PM
Price: $300.00
Pros: Ride quality, simple install,
Cons: none
Recommended? Yes
Comments: Got these to replace the shot Pro Comp shocks. Heard good things about the OME shocks and so I got em. I love em, The difference is amazing.
MoCab
MoCab's Reviews
12-07-2009, 05:24 PM
Price: $200.00
Pros: tuned for the Jeep not a down sized truck shock.
Cons: took a long time to ship.
Recommended? Yes
Comments: simple the best shock for a Wrangler.
PackDude
PackDude's Reviews
08-13-2009, 08:06 PM
Price: $360.00
Pros: Very sturdy Good ride quality
Cons: Urethane bushings squeak
Recommended? Yes
Comments: Before adding the OME 2 inch spring lift, I had just recently replaced my stock shocks with Edelbrock IAS, so I can't help but compare them to the OME shocks.
I think the OME shocks are a bit stiffer than the Edelbrocks, probably because I have the heavy duty OME shocks. But the OME shocks are part of the full OME suspension system, and have the increased travel, so they are ultimately a better match. They seem to be built much sturdier than the Edelbrocks, too.
I would like to try a set of the OME comfort (N35C and N36C) shocks and see how they compare to my HD N35 and N36's.
jimwww
jimwww's Reviews
05-24-2009, 11:48 PM
Price: $300.00
Pros: Best ride
Cons: None
Recommended? Yes
Comments: Excellent ride on a YJ. I don't know of another shock that will give a YJ a great ride like this. Yj basically does not have a suspension - very rough - but.. these smooth it quite a bit. I don't know why they don't make them longer to fit in 'really' lifted trucks.
RockyClymer
Red Rock 4-Wheeler
RockyClymer's Reviews
05-10-2009, 04:44 PM
Price: $240.00
Pros: Easy install
Cons: None
Recommended? Yes
Comments: These came as a part of my OME lift. After several trips to Moab and in the mountains of CO I think these give about the same ride that the JK OEM gas shocks that came stock. They seem well matched to the OME spring set and I have no complaints as of yet. About 10k miles as of this writeup.
Glock Forum
