Monroe - Max-Air Shocks Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Shocks Next Product
Rating:
Product Information
MSRP: $69.95
Average Price: $57.85
Manufacturer: Monroe
Recommended?
Yes: 1 / No: 0
Company Website: http://www.monroe.com/
The Max Air® shock absorber is ideal for vehicles that haul heavy loads or tow trailers. Designed to maintain level vehicle height, they can be inflated or deflated as needed...from 20 psi to 150 psi with the vehicle loaded.
A pair of Max Air shock absorbers can maintain ride height when up to 1,200 lbs of additional weight is loaded.
Packed in pairs that include air line, air fittings, and air fill kit.
Capacity is limited by vehicle suspension, tires and transmission. See vehicle owner's manual for details.
  1. All Weather Fluid: Contains special modifiers to reduce friction and ensure smooth rod reaction.
  2. Full Displaced Valving: Better valving range on both the compression and extension cycles of the unit for a smooth comfortable ride.
  3. Sintered Iron Piston: Stronger than traditional metals, enhances durability for long service life.
  4. Lubricated Air Sleeve: Reduces friction for longer service life. Provides smoother operation during suspension movement.
  5. 1/2" Piston Rod: Hardened and precision ground rod for consistent performance and long service life.
  6. Special Air Fitting: Resists air leakage.
  7. Large Volume Air Chamber: Inflates up to 150 psi with vehicle loaded. Deflates for normal driving.
None
Kettles
Kettles's Reviews
01-12-2010, 10:47 PM
Price: $57.85
Pros: Easy to Install, Inexpensive, Easy to Fill, Rides Well
Cons: Fill nipple on passenger shock placement
Recommended? Yes
Comments: Monroe's Max-Air shocks do what they advertize. They installed fairly easily, and routing the air lines and attaching the fill fitting was simple. They ride at least as good as stock, and allow you to compensate for larger loads and towing. And allow you to tune the rake if you so please. I installed them to help with towing, and my sagging rear springs, and it has worked so far.
My only quarrel so far is the passenger shock fill nipple is supposed to go to the inside, but I had to position it the other way to avoid the exhaust. This gives little clearance between it and the "frame". It has not been a problem (the line has enough room to turn away), but you have to put the line in before you bolt the shock up.
You can also add a cab control and fill kit that has a compressor, dash gauge, and controls to adjust the pressure from the drivers seat (Airlift 25804). A bit pricy, (around $100) but adds a degree of convenience if you so wish. (I have OBA so its no big deal to inflate when needed)
ThreadForumRepliesLast Post
Monroe Sensa-Trac Shocks 17 04-26-2016 08:45 AM
Monroe Gas Matic LT Shocks 11 02-15-2016 08:08 PM
Monroe - Monroe Reflex Shocks 9 01-05-2016 08:16 AM
Monroe Steering Stabilizer SC2928 Steering Stabilizers 9 12-07-2015 12:14 AM
BDS Shocks 5500 series Shocks 19 07-26-2015 04:51 PM
