Notices
Bilstein HD Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Shocks Next Product
Bilstein HD
Rating:
Product Information
MSRP: $320.00
Average Price: $229.61
Manufacturer: Bilstein
Recommended?
Yes: 41 / No: 0
The 5100 Series offers traditional Bilstein technology with applications for lifted trucks, Jeeps and prerunners. The 5100 Series shock absorbers are designed for specific manufactured lift kits utilizing the stock O.E.M. mounting configuration. 5100 Series shocks feature Bilstein's superior single tube high gas pressure design for the upmost in consistent fade-free performance and long life. Bilstein's patented Digressive self-adjusting valving delivers improved damping control and a smooth ride on all road surfaces at any speed.
None
Page 1 of 2 1 2 > Last
wraycoli
wraycoli's Reviews
04-26-2016, 10:43 AM
Price: $115.00
Pros: Quality Product, OEM replacement
Cons: none
Recommended? Yes
Comments: solid product, very pleased
cweed24
cweed24's Reviews
01-26-2016, 04:21 PM
Price: $260.00
Pros: great ride quality and control
Cons: price i guess but you can find deals if you look hard enough
Recommended? Yes
Comments: these shocks are awesome
freonwj
freonwj's Reviews
01-04-2016, 08:26 PM
Price: $325.00
Pros: Awesome 5100s front 5125 rears
Cons: Non
Recommended? Yes
Comments: Super ride. Nice quality. Great bang for the buck. Got from Kolak
ajgiii
ajgiii's Reviews
01-04-2016, 11:34 AM
Price: $311.60
Pros: Nice road feel without excessive stiffness.
Cons: Exterior strut tube appears very slightly larger than OEM. Had to spread strut clevis mount very, very slightly to install the Bilstein 4600s. Dead blow mallet came in handy.
Recommended? Yes
Comments: Bilstein 4600 series are the actual items (not available in pull-down menu).
I purchased front and rear sets based on the vast majority of other comments as to the ride improvement. Reviews on other sites showed a very high satisfaction level--I agree.
Installation notes:
1. Great advice from JeepForum on how to install. See: http://www.jeepforum.com/forum/f67/how-change-front-struts-rear-shock-05-jeep-grand-cherokee-limited-4-7-a-1073341/
2. Exterior strut tube appears very slightly larger than OEM. Had to spread strut clevis mount very, very slightly to install the Bilstein 4600s. Dead blow mallet came in handy.
ajgiii
ajgiii's Reviews
01-04-2016, 11:27 AM
Price: $311.60
Recommended? Yes
Comments: Bilstein 4600 series shocks/struts are what I installed.
Very nice improvement over 70k old OEM.
Not a major "wow" but they made my Jeep feel new again.
Install note for front struts: Exterior strut tube appears very slightly larger than OEM. Had to spread strut clevis mount very, very slightly (with screwdriver) to install the struts. Dead blow mallet came in handy.
tcbob11
tcbob11's Reviews
12-24-2015, 10:50 AM
Price: $300.00
Pros: Firmer ride, but not uncomfortably so, and reduced roll.
Cons: None evident so far.
Recommended? Yes
Comments: Not cheap, but definitely a big improvement in ride, quality and longevity over stock shocks. I expect to get 10 years/100,000 miles or more out of these shocks. Only nit: it's nearly impossible to slide the rubber bellows covering the shock rod down to eliminate bunching of the bellows in collapsed position.
kjmccar
kjmccar's Reviews
07-31-2014, 02:38 AM
Price: $292.00
Pros: Good control, look nice, 2" longer than stock
Cons: A bit stiff, more expensive than most shocks
Recommended? Yes
Comments: I recently installed my Bilstein HDs, and haven't even taken them off road yet. On road the handling is noticeably better, and I am looking forward to adding 2" to my Jeep now that I have the option.
FlornFlarnowitz
FlornFlarnowitz's Reviews
07-16-2013, 10:20 AM
Price: $70.99
Pros: Made by Bilstein... What else do you need to know?
Cons: Move along, nothing to see here
Recommended? Yes
Comments: I replaced shotso KYB rear shocks with Bilsteins. Although my Upper Rear Control Arm bushings are almost non-existent, it is hard to tell the difference. But the difference is still there. I'm wondering what kind of Coil Springs to install now. Tomorrow is install day for the rear upper and lower control arms and ball joint so I will have a 100% better understanding of the difference. Stock crappy 9/16" sway bar but I did chrow on some Energy Suspension poly bushings. Even that made a difference but next for the rear will be an Addco 1" Sway Bar and maybe Eibach Lowering Springs (message me and let me know what you think of those springs - I'm not into lifting it higher or off-roading. I want a little lower center of gravity). Same goes for the front. Soon. Hopefully.
EDIT: Go Buy BILSTEINS!!!!!
MKWrangler
MKWrangler's Reviews
04-18-2013, 05:05 PM
Price: $76.99
Pros: Easy install, lifetime warranty
Cons: none
Recommended? Yes
Comments: Purchased as a stock replacement and they work with the Teraflex 1.5" coil leveling kit.
04Overland47
04Overland47's Reviews
03-19-2013, 04:28 PM
Price: $260.00
Pros: Controlled ride, great quality, stiffer than stock but in a good way
Cons: None really
Recommended? Yes
Comments: My WJ feels a lot more controlled over bumps and imperfections in the road. The ride and handling difference between the Bilsteins and stock are night and day. The ride is a bit more firm, but in a positive way. Takes bumps like a champ on the highway too. Highly recommended!
Evil_98_ZJ
Evil_98_ZJ's Reviews
10-31-2012, 06:35 PM
Price: $227.00
Pros: Great shocks for the money
Cons: None really. Why buy anything else?
Recommended? Yes
Comments: Purchased from Summit Racing after having them price match, got them literally 25 hours later. Installation was pretty straightforward. One of the best shocks you can get for your money.
johnridesjeeps
johnridesjeeps's Reviews
05-10-2012, 07:53 PM
Price: $250.00
Pros: Excellent handling and very responsive.
Cons: Can be stiff for people ( not this guy though). Also not direct bolt on. Metal sleeve needs to be ground a little to fit.
Recommended? Yes
Comments: Amazing shocks. Handle great on the road and offer an excellent ride. You can feel the bumps alittle more with the stiffness of the shocks. But the zj feels safer now. Not like a brick on jello
Jomphe
Jomphe's Reviews
03-22-2012, 09:57 PM
Price: $90.00
Pros: Huge difference over stock.
Cons: none so far.
Recommended? Yes
Comments: Worthy investment.
Komet
Komet's Reviews
02-29-2012, 01:46 AM
Price: $4.00
Pros: Excellent ride quality
Cons: Spendy to buy new, only good for stock height.
Recommended? Yes
Comments: Got these for dirt cheap at a junkyard, and they are so very much nicer than the rock hard Mountain Ryder IIs they replaced. The softness means a little more body roll in the corners, but who drives a Jeep fast anyhow?
johnboy_24
johnboy_24's Reviews
12-19-2011, 02:47 PM
Price: $260.00
Pros: Much firmer ride More control No more "floating" after bumps
Cons: The ride is a little more harsh
Recommended? Yes
Comments: Great upgrade from OEM shocks/struts after lift. Even before putting on lift my WK was floating after hitting bumps above 45mph. This got a little scarry during rain storms. While putting on my RC lift I noticed some serious rust damage on my OEM strut and put the money in a new set of Bilsteins. The ride since then is so much better. The WK holds the road over bumps, does 10x better off-road, and the only downside is you feel the road a bit more on the highway (not much more) but certainly worth the trade off.
Piepenbrok420
Piepenbrok420's Reviews
10-02-2011, 07:52 PM
Price: $340.00
Pros: High quality shocks and struts, price
Cons: none
Recommended? Yes
Comments: Got the front Struts (Bilstein 4600 HD) off Tire Rack for $198 including 2 day shipping, got the rear shocks from 4 Wheel Parts for $140. Very nice shocks and struts, rides amazing.
Thomahawk
Thomahawk's Reviews
06-22-2011, 12:01 PM
Price: $260.00
Pros: exelent shocks great handling, less body roll, less nose dive at hard brake downs, smoother trough pot holes.
Cons: price
Recommended? Yes
Comments: havent really tried them out yet, just mounted them, first impression is really good.
after tried out: exelent shocks great handling, less body roll, less nose dive at hard brake downs, smoother trough pot holes.
jimebeans
jimebeans's Reviews
02-17-2011, 11:52 AM
Price: $238.00
Pros: look good, feel great, very well built, incredible dampening
Cons: they dont install themselves
Recommended? Yes
Comments: Since ive been on the oem shocks for 158k miles. i shopped around for the best performance/valued shocks i could find. these are the ones. go them from shockwarehouse.com for nice price delivered.
Cowgirrl1
Cowgirrl1's Reviews
01-09-2011, 10:13 PM
Price: $400.00
Pros: Smooth even when mudding, excellent handling
Cons: Can't say there are any.
Recommended? Yes
Comments: The shocks are very tight, nothing sloppy on street corners or mud ruts. You're still in touch with the ride, just a bit more comfy.
EquipmentJunkie
EquipmentJunkie's Reviews
12-31-2010, 04:28 PM
Price: $260.00
Pros: Noticeably smoother & quieter over the Gabriel shocks that were on the TJ when I bought it.
Cons: None yet
Recommended? Yes
Comments: My '98 TJ now has 138K on it and has a stock suspension. When I bought the Jeep 9 months ago, it had some old Gabriel shocks on it. They looked ancient and very rusty. I didn't think that my Jeep drove the way it should. I decided to treat myself to some new shocks and bought the Bilstein HDs after reading the positive reviews here.
The Bilsteins turned my Jeep into a much smoother riding and stable vehicle. The road noise and rattles are much lower, too. I am very impressed.
ThreadForumRepliesLast Post
Bilstein 5100 Series Shocks 108 11-06-2015 05:48 PM
