WARN Warn DIfferential Guard - Dana 30 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Differential Guards Next Product
Rating:
Product Information
MSRP: $1,111.00
Average Price: $205.67
Manufacturer: WARN
Recommended?
Yes: 18 / No: 0
Angled for a tight fit and structural rigidity, the Differential Skid Plate fits both high and standard pinion covers to give full protective coverage. Since it is a closed system, it slides over objects and won't snag or hang up. Made from 3/16" steel. Bblack powder coat.
None
TheBlueDevil
TheBlueDevil's Reviews
03-19-2011, 10:01 PM
Price: $75.00
Pros: Protects the front diff really well
Cons: none
Recommended? Yes
Comments: Got it used for $75 and painted it up red and it has saved my front diff a few times.
WheelieTime
WheelieTime's Reviews
05-12-2010, 10:21 AM
Price: $99.00
Pros: Inexpensive Protection
Cons: Have to pull the 5 bottom bolts to the differential. Instructions say this should not break the seal. Both began to leak after installing had to remove both differential covers, clean, and reapply RTV.
Recommended? Yes
Comments: Affordable Protection. Good Product for the daily driver/part time wheeler. I would have been more satisfied with the product if I did not have to re-apply RTV to keep the cover sealed. On the plus side my move to synthetic gear oil occured sooner.
T4STE
T4STE's Reviews
05-03-2010, 09:14 PM
Price: $90.00
Pros: protects well for a diff skid
Cons: not a full solid cover.
Recommended? Yes
Comments: works well for a front diff skid. wish it was a full HD cover
limeking
limeking's Reviews
11-19-2009, 10:16 AM
Price: $1,111.00
Pros: easy to install
Cons: none
Recommended? Yes
Comments: Taken some good hits with no real damage.
SjT2107
SjT2107's Reviews
11-17-2009, 01:27 PM
Price: $30.00
Pros: Good for light rock crawling
Cons: No good for rough wheeling, will crush in
Recommended? Yes
Comments: Good for light rock crawling. Will crush if hit hard. Its served me well
provinT13
provinT13's Reviews
10-14-2009, 01:09 PM
Price: $60.00
Pros: small, light, decent price
Cons: none
Recommended? Yes
Comments: I got this for my d-30, and after having it for about 2 years runnin' in the Colorado Rockies i've had no problems with it, it's held solid and gotten the job done.
6thelement
6thelement's Reviews
06-29-2009, 06:54 PM
Price: $25.00
Pros: works
Cons: no style
Recommended? Yes
Comments: it does it's job
RockyClymer
RedRock4Wheeler
RockyClymer's Reviews
06-17-2009, 02:54 PM
Price: $75.00
Pros: Well built and very solid Built to slide past bolts
Cons: None so far
Recommended? Yes
Comments: I had nicked the front pumpkin one too many times. This sure takes care of the problem. I like it over some of the bar and cage units as it seems to be a true slider that does not get hung up on rock edges...beat it up, paint it, beat it up, paint it...etc.
Cherokeegrrl
Cherokeegrrl's Reviews
03-24-2008, 06:46 PM
Price: $1,111.00
Recommended? Yes
Comments: It's okay, but I've managed to dent it, and I'm not even a hardcore wheeler. If you're doing a lot of rocks, get another type. For other types of wheeling including occasional rocky stuff, they'll do.
zombieyj
zombieyj's Reviews
03-23-2008, 01:25 PM
Price: $69.00
Recommended? Yes
Comments: Wanted the 4xdoctor but this one was once again cheeper...
TJ 4 the Boxers
TJ 4 the Boxers's Reviews
03-23-2008, 10:15 AM
Price: $50.00
Recommended? Yes
Comments: No problems after hitting some big rocks.
XJ2000
XJ2000's Reviews
03-03-2008, 07:45 PM
Price: $70.00
Recommended? Yes
Comments: Nice and thick. Easy to install. Have hit it hard, and it shows no signs of failure. A great investment.
rgingerelli99tj
rgingerelli99tj's Reviews
02-27-2008, 02:13 PM
Price: $120.00
Recommended? Yes
Comments: I have them both for my Dana 30 and for my Dana 44 they work alright. They are as strong as I had hoped but Im not going to get rid of them, its better to have something the nothing at all. Price is for both.
Manateu
Manateu's Reviews
12-04-2007, 07:21 PM
Pros: Solid protection
Cons: Socket or Allen head mounting hardware
Recommended? Yes
Comments: I found the socket heads bolts a pain to properly tighten. If you purchase this diff guard make sure to buy the proper allen size socket, so you can tighten to the correct torgue specs.
jeep4fishing
jeep4fishing's Reviews
06-27-2007, 08:02 PM
Pros: Ease of install, strength
Cons: collection of debris
Recommended? Yes
Comments: I shoved a large piece of Pike's Peak Granite into the diff with only a large scratch as evidence. To clean out the cover, use a sprinkler under the vehicle.
z71offroader
z71offroader's Reviews
08-12-2006, 12:28 AM
Pros: Protection and looks
Cons: mud and objects getting stuck in it.
Recommended? Yes
Comments: Good quality guard. adds good protection and a good look. only bad thing is that mud and other things can get in it between the cover and can be a pain to get out. takes very little time to install!
RedefinedTJ
RedefinedTJ's Reviews
08-04-2006, 07:00 PM
Price: $35.00
Pros: Takes huge hits, and no damage!! Super easy install
Cons: Dirt and mud stuck between guard and cover
Recommended? Yes
Comments: Mine has taken a few hard direct hits and has not given at all. I am very impressed with it for the price. Install took all of 5 min.
BigPeters
BigPeters's Reviews
08-04-2006, 06:55 PM
Price: $65.00
Pros: Takes a beating
Cons: Mud and dirt can get stuck between the cover and the guard
Recommended? Yes
Comments: This is a quality skid that can take a beating and is good for the price, however mud and dirt tend to get stuck between the cover and the skid and its not easy to get the mud out. The install is a breeze.
ThreadForumRepliesLast Post
Warn Front/Rear Differential Guards Differential Guards 22 07-02-2016 10:15 PM
Warn Rocker Guards Rocker Guards 49 09-10-2014 02:27 PM
Warn TJ Gas Tank Skid Skid Plates 11 06-30-2011 08:34 AM
warn grill guard hoop Bumpers 6 04-12-2011 01:27 PM
Four X Doctor Dana 30 Differential Guard Differential Guards 3 12-27-2009 03:38 AM
