Notices
Rockcrusher Dana 30/35/44 Differential Cover Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Differential Guards Next Product
Rating:
Product Information
MSRP: $200.00
Average Price: $102.08
Manufacturer: Rockcrusher
Recommended?
Yes: 31 / No: 2
Features:
Lifetime warranty
Thick nodular iron casting with reinforcing ribs
Fully machined seal surface
Machined bolt bosses for maximum clamping force
Benefits:
Adds rigidity to weak factory housings
Replaces weak factory stamped steel covers
Large diameter fill plug for easy fluid replacement (where applicable)
Higher fill plug location for increased fluid capacity
None
Page 1 of 2 1 2 > Last
Liquid741
Liquid741's Reviews
04-17-2011, 08:20 PM
Price: $275.00
Pros: they can support 110,000 lbs.! lol
Cons: umm, none i can think of.
Recommended? Yes
Comments: they are badass...i just need to paint them! easy install...just follow the instructions or take out bolts and replace bolts...standard diff plate change.
quadcrazed26
quadcrazed26's Reviews
03-11-2011, 10:07 PM
Price: $80.00
Pros: beefy
Cons: none
Recommended? Yes
Comments: great
Lyonsa80
Junior Member
Lyonsa80's Reviews
01-02-2011, 09:18 PM
Price: $115.00
Pros: Tough as nails. Unpainted for a custom look. Heavy duty. Reasonably priced. Was available in Chrysler 8.25.
Cons: You have to paint it for that "custom look". HAHA
Recommended? Yes
Comments: I actually have the Chrysler 8.25 model of this Rockcrusher unit, but there wasn't a selection box for this model. Same as the others though. This product is tough as nails. Have dropped off quite a few stones on this cover and it doesn't phase it in the lease. Thick steel, gusseted for rigidity, heavy duty.
Would recommend to anyone wanting a hard-@$$ diff.cover.
Flat_Black_ZJ
Flat_Black_ZJ's Reviews
11-05-2010, 11:35 AM
Price: $68.00
Pros: strong piece
Cons: none
Recommended? Yes
Comments: I bought the dana 35 rockcrusher off eBay and am very pleased with the way it looks and performs.
jeepjoe4
jeepjoe4's Reviews
06-28-2010, 07:12 PM
Price: $100.00
Pros: strong and fit is good
Cons: bolts are so small cant get a wrench on the head and i keep breaking the heads off and there is no finish to them so paint them as soon as you get them
Recommended? No
Comments: These are OK they get the job done nothing special i have had more problems with the bolts easy fix just get new bolts ones with allen keys not hex and paint them as soon as you get them.
PoopFaceKillah
PoopFaceKillah's Reviews
10-26-2009, 10:04 AM
Price: $120.00
Pros: Sturdy, holds more fluid
Cons: $$$
Recommended? Yes
Comments: Sturdy, holds more fluid that OEM covers. Replaces diff covers that do not have threaded fill holes liek the 35s and 8.25s
richmond1273
richmond1273's Reviews
08-28-2009, 11:29 AM
Price: $50.00
Pros: seems solid enough to take a beating
Cons: a couple of my holes didn't line up, becasue of the reinforcing some of the holes didn't have enough clearance to put a socket on it.
Recommended? Yes
Comments: i haven't got to really test it out yet, or if i have i didn't even realize it. they have been on for 2 or 3 years now and are holding up good. be sure to paint them before you install them. i thought they were already finished and they rusted pretty quick. they are a big pain to try to clean up again to paint.
TJJP77
TJJP77's Reviews
07-05-2009, 12:26 PM
Price: $50.00
Pros: Beefy, good price at the time.
Cons: Screw holes need to be larger to make installation easier.
Recommended? Yes
Comments: Got the rear D44 cover during the 2 for $100 sale...never did get my front D30 cover, but didn't get charged for it thankfully. Cover is good overall. They need to machine the bolt holes a bit larger to help ease installation.
4pointOH1998
4pointOH1998's Reviews
06-29-2009, 08:27 AM
Price: $100.00
Pros: Very stout
Cons: Unpainted, but easy to paint
Recommended? Yes
Comments: Wicked heavy. Probably my easiest upgrade to date
crash070602
crash070602's Reviews
03-14-2009, 09:40 AM
Price: $170.00
Recommended? Yes
Comments: , .
UTmike
UTmike's Reviews
10-17-2008, 12:48 AM
Price: $80.00
Recommended? Yes
Comments: Great covers. I've got the front 30 and rear 8.8. They've taken many hits and haven't given anything.
Guns
Guns's Reviews
09-17-2008, 01:42 PM
Price: $200.00
Recommended? Yes
Comments: I have the D30 Aluminum diff cover up front, and the Ford 8.8 steel cover in the rear. The 8.8 cover is bullet proof, but holds heat. The D30 cover is not as bullet proof, but dissapates heat very well. I have beat the ever living tar out of the front diff cover. No dents whatsoever, but the rocks tend to shave a lot more off of the aluminum than the steel which bothers me. In the future, I will stay with Solid/Rockcrusher, but in a steel format.
Red_
Red_'s Reviews
09-14-2008, 04:54 PM
Price: $100.00
Recommended? Yes
Comments: On the front, the rib on the D30 cover rubs against the track bar. Easy fix with a grinder. The back plenty of clearance but no room to tighten down the fill plug if you are sitting at ride height.
alvinl
alvinl's Reviews
07-10-2008, 11:44 AM
Price: $50.00
Recommended? Yes
Comments: I have the Rockcrusher cover for my 8.8 rear axle. This is a great cover and looks great on the Jeep.
jdarg
jdarg's Reviews
06-27-2008, 05:33 PM
Price: $100.00
Recommended? Yes
Comments: These are crap. Bought two 44 covers and holes were off on one but not the other. Had to grind down a rib on the front or the track bar would hit but I think this is a Rubicon D44 thang. Good for the money I guess.
-sean-
-sean-'s Reviews
06-04-2008, 02:02 AM
Price: $100.00
Recommended? Yes
Comments: ---------------------------------------------------------------------------------------------------------------
XTC Jpr13
XTC Jpr13's Reviews
05-08-2008, 10:22 PM
Price: $100.00
Recommended? Yes
Comments: very strong and well built. Bolts on easy, and when used with a lubelocker does not leak at all!
rescueTJ
rescueTJ's Reviews
04-28-2008, 06:17 PM
Price: $125.00
Recommended? Yes
Comments: Very strong diff cover that inspires confidence. The have since changed their name to "SOLID" but I have an origional "Rockcrusher" stamped piece.
Trombino
Trombino's Reviews
04-19-2008, 01:08 PM
Price: $60.00
Recommended? Yes
Comments: Great product -- Definitely heavy duty.
brrempel
brrempel's Reviews
04-18-2008, 03:22 PM
Price: $65.00
Recommended? Yes
Comments: Love it.
ThreadForumRepliesLast Post
Solid Axle Industries Differential Cover Skid Plates 5 06-24-2013 07:57 PM
Riddler Differential cover Differential Guards 67 07-08-2012 02:46 AM
Currie Enterprises ramped HD cover for Dana 44 front differential Differential Guards 1 10-15-2009 08:13 AM
Dana 35 Kryptonite Differential Cover D.I.Y Differential Guards 1 06-13-2009 11:36 AM
TKH Fab Dana 30 Differential Cover Differential Guards 3 09-18-2007 09:04 AM
