Riddler Differential cover Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Differential Guards Next Product
Rating:
Product Information
MSRP: $200.00
Average Price: $111.61
Manufacturer: Riddler
Recommended?
Yes: 72 / No: 0
All Riddler covers feature:
* Lifetime Warranty against breakage
* Lip free smooth transition design
* Recessed fasteners
* Made from high grade ductile iron
* CNC Machined
* Recess for locker actuator on Jeep Rubicon Axles
* Stainless Steel Hardware included
* Permatex Ultra Black gasket maker included
* Raised fill plug allows additional fluid for proper lubrication after correcting pinion angle for lifted vehicles.
None
Page 2 of 4 1 2 3 4 > Last
vbohannon64
vbohannon64's Reviews
03-06-2011, 09:18 AM
Price: $110.00
Pros: Heavy and thick
Cons: None
Recommended? Yes
Comments: Great product. It adds strength to the housing as well as protection to your diff. Comes with new stainless hardware and gasket sealant. Ships bare steel.
MuddyJeep42
MuddyJeep42's Reviews
02-08-2011, 02:12 PM
Price: $109.00
Pros: Heavy duty! Raised fill hole.
Cons: Supplied bolts are cheap and WILL NOT withstand the torque requirements of a Lube Locker gasket without twisting off in your axle! DO NOT USE THEM!
Recommended? Yes
Comments: Attempted to use the diff guard with a lube locker reusable gasket which requires a first torque of 15 fp and a second of 32 fp. The first bolt I tried to apply 32 fp quickly twisted off in my axle!
Scooter_Trash
Scooter_Trash's Reviews
01-18-2011, 11:06 PM
Price: $50.00
Pros: Perfect fit, and it does what its supposed to do.
Cons: None
Recommended? Yes
Comments: I bought this product 2nd hand. It was a perfect fit and the powdercoating was perfect.
Woodchuck
Woodchuck's Reviews
11-09-2010, 12:26 PM
Price: $100.00
Pros: Tuff
Cons: Not as pretty as AEB's
Recommended? Yes
Comments: The do what they are supposed to do
emein
Junior Member
emein's Reviews
10-06-2010, 08:53 AM
Price: $100.00
Pros: They are simply GREAT!
Cons: None
Recommended? Yes
Comments: After going down the Rubicon, it was clear I needed better diff covers. The riddlers are really well made, and look great! Great product! E
markxj2k
markxj2k's Reviews
10-03-2010, 10:24 PM
Price: $99.00
Pros: Designed for JK Rubicon e-Lockers, recessed fasteners, good price
Cons: None
Recommended? Yes
Comments: I replaced the stock front and rear diff covers with these. Painted them with Rustoleum black bedliner and then painted the logos silver. I liked the fact that they had the flat area required to connect the wires for the OEM Rubicon electronic lockers. No problems so far.
warCryr
warCryr's Reviews
08-22-2010, 11:45 PM
Price: $110.00
Pros: Solid and thick and no lip. Cool looking. Doesn't come painted so you can do whatever you want easily.
Cons: Doesn't come painted so you have to do it yourself.
Recommended? Yes
Comments: Everything is fine except I wish it was painted already or powder coated, but thats just me. The only reason I didn't give this a 5 is because I kept breaking the hardware that is provided with the cover. I was using a torque wrench and going to 35 ft/lb., but then I gave up on that and went and got grade 8 hardware and still broke bolts at 30 ft/lbs, I eventually ended up with grade 8 hardware torqued to 25-30 ft/lbs. No problems yet.
Wup This
Wup This's Reviews
08-10-2010, 10:04 PM
Price: $109.00
Pros: Beefy, stainless hardware, looks
Cons: one bolt recess was a little close on the Rear 8.25 and made for a tight fit with socket but I'm being nit picky. They don't give you enough silicone to seal the rear so you have to buy a bigger tube....it's just enough to do the D30 cover and that is pushing it.
Recommended? Yes
Comments: Great looking covers that fit perfect and seal up nicely. Paint mine with black semigloss and they look fantastic. NOTHING to hang up one and sealed perfectly the first time!!
I paid cost and couldn't believe how much of a mark up there is for retail customers.
mmarmouz
mmarmouz's Reviews
07-29-2010, 01:33 PM
Price: $100.00
Pros: Very Solid
Cons: None
Recommended? Yes
Comments:
vilseck21
vilseck21's Reviews
07-19-2010, 02:12 AM
Price: $50.00
Pros: its works great
Cons: I cant think of any
Recommended? Yes
Comments: This has saved my fron diff many times
sanchagrins
sanchagrins's Reviews
06-01-2010, 11:34 AM
Price: $198.00
Pros: Very heavy duty
Cons: None as of yet
Recommended? Yes
Comments: I received the D44 and D30 differential covers from Northridge 4x4 a few days ago. Prepped and painted them, and just waiting to install. They are considerably more heavy duty than the stock covers, and are an upgrade I consider essential to any jeep that will see the trails. I am a satisfied customer!
mpoo1083
mpoo1083's Reviews
05-22-2010, 05:15 PM
Price: $220.00
Pros: everything else
Cons: front cover rubbed a little with hard turns
Recommended? Yes
Comments: Front and rear covers went on very easy. Painted before install and looked great. They are a lot beefier than the stock covers. and have held up great so far.
no0ption
no0ption's Reviews
05-22-2010, 03:39 PM
Price: $110.00
Pros: Strong, smooth, look great painted.
Cons: none
Recommended? Yes
Comments: The Riddler diff covers are very clean, no extra metal, and well rounded, so they shouldn't get hung up on rocks. They look great painted.
slpv09
slpv09's Reviews
05-11-2010, 10:03 PM
Price: $115.00
Pros: looks cool, beefy
Cons: expensive
Recommended? Yes
Comments: looks good and strong
provinT13
provinT13's Reviews
04-28-2010, 06:09 PM
Price: $99.99
Pros: Very heavy duty, low profile, easy to install, no lips to catch on
Cons: None
Recommended? Yes
Comments: The riddler cover is 100% solid. There is no doubt in my mind that it will protect my diff and gears from anything that I can throw at it on the trail. It's easy to install, doesn't take up a ton of room, and has a very clean look. I have one on my ford 8.8 rear axle and love it.
98VolsTJ
98VolsTJ's Reviews
04-19-2010, 11:09 PM
Price: $110.00
Pros: Indestructible
Cons: None
Recommended? Yes
Comments: Hefty design. It looks like it'll take a beating with no problems.
twojacks
twojacks's Reviews
04-12-2010, 01:23 PM
Price: $110.00
Pros: Beefy material (3/8" thick), perfectly shaped to the differential, includes new hardware, comes unpainted allowing you to customize.
Cons: Fill plug is an Allen bolt style. Ended up using the stock drain plug instead (less tools to carry around)
Recommended? Yes
Comments: Overall these are extremely well made (just watch the video), provide a smooth design, and are a significant upgrade over stock. No clearance issues on the front or rear ('03 Rubicon). Got F&R from ROKMEN for $220.
Why run the risk of punching a hole in the stock cover and risk loosing your bearings, gears, locker, etc.?
digizure
digizure's Reviews
03-01-2010, 03:43 PM
Price: $105.00
Pros: Very strong. Perfect fit.
Cons: None I can think of.
Recommended? Yes
Comments: Abused and still looks brand new like nothing would crack this thing! I have the guards for my D30 and 8.8. Love it!
WI03Wrang
Junior Member
WI03Wrang's Reviews
01-20-2010, 08:27 PM
Price: $110.00
Pros: none
Cons: great look, strong as heck, holds extra oil
Recommended? Yes
Comments: looks great
river2c
river2c's Reviews
01-02-2010, 04:23 PM
Price: $100.00
Pros: solid iron
Cons: none
Recommended? Yes
Comments: These differential covers come unpainted but can be easily painted or powder coated to your preference.
ThreadForumRepliesLast Post
Currie Enterprises ramped HD cover for Dana 44 front differential Differential Guards 2 02-28-2015 11:26 PM
Solid Axle Industries Differential Cover Skid Plates 5 06-24-2013 07:57 PM
Rockcrusher Dana 30/35/44 Differential Cover Differential Guards 33 04-17-2011 06:20 PM
Dana 35 Kryptonite Differential Cover D.I.Y Differential Guards 1 06-13-2009 11:36 AM
TKH Fab Dana 30 Differential Cover Differential Guards 3 09-18-2007 09:04 AM
