Go Back JeepForum.com > Reviews > Armor > Differential Guards > Riddler Differential cover
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Riddler Differential cover Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Differential Guards Next Product
Rating:
Product Information
MSRP: $200.00
Average Price: $110.60
Manufacturer: Riddler
Recommended?
Yes: 62 / No: 0
All Riddler covers feature:
* Lifetime Warranty against breakage
* Lip free smooth transition design
* Recessed fasteners
* Made from high grade ductile iron
* CNC Machined
* Recess for locker actuator on Jeep Rubicon Axles
* Stainless Steel Hardware included
* Permatex Ultra Black gasket maker included
* Raised fill plug allows additional fluid for proper lubrication after correcting pinion angle for lifted vehicles.
Page 1 of 4 1 2 3 4 > Last »
ScottD16
ScottD16's Reviews
01-26-2012, 01:21 PM
Price: $1.00
Pros: heavy duty and looks awesome
Cons: none
Recommended? Yes
Comments: got for christmas and its awesome slammed right into a rock and didnt do a thing
05-Rubicon
05-Rubicon's Reviews
12-27-2011, 02:37 PM
Price: $109.00
Pros: heavy, indestructible. Fits behind front tie rod, no contact, and has a hex head cap screw, and not a torx, or an allen (like Warns)
Cons: Must paint, or will rust like crazy
Recommended? Yes
Comments: I would get the poison spyder cover, cool spyder. Either way, can't lose with these.
stevemongr
stevemongr's Reviews
12-23-2011, 12:52 PM
Price: $80.00
Pros: Raw Iron
Cons: Raw Iron
Recommended? Yes
Comments: Good
whitegoat
UPSIDE DOWN AT THE BOTTOM
whitegoat's Reviews
11-05-2011, 11:13 PM
Price: $100.00
Pros: cheap, cast iron, fill plug is higher allows for more fluid
Cons: none
Recommended? Yes
Comments: cheap, they work great, handle abuse, work with rubicons and allow for more oil
jeepmare
Junior Member
jeepmare's Reviews
10-21-2011, 10:03 PM
Price: $109.00
Pros: Great product from Riddler
Cons: None
Recommended? Yes
Comments: Great product and can withstand anything you can get into.
billzcat1
billzcat1's Reviews
09-07-2011, 12:04 AM
Price: $99.00
Pros: Extremely strong, smooth face slides off rocks, Grade 5 hardware
Cons: Reduced track bar clearance (in some vehicles).
Recommended? Yes
Comments: I installed the Riddler diff cover because the one I originally wanted (the $64 SOLID) cover was out of stock. I was looking for alternatives that didn't cost $170 like the ARB cover and this came up. I found at Jeepforum vendor for $99 shipped which was a great price. Another thing that compelled be to buy it: the Youtube review where it is destroyed using extremely heavy machinery.
The cover comes unpainted but coated in oil to prevent rust. Before installing, be sure to clean it thoroughly. I also heated mine up with a torch to evaporate any oils that had soaked into the porous cast iron. I painted it with Rustoleum Professional Enamel in a spray can and it is holding up nicely, even being dragged through dirt and bounced off rocks.
Other reviews mentioned weak stainless hardware breaking as you torqued the bolts down, but mine came with Grade 5 zinc-plated bolts which had no problems at all. I paired it with a Lubelocker gasket on my Dana 30 and it is 100% leak free.
To date, I have dragged it through rocky dirt in a really rutted area and bounced it off a rock, no problems, barely even scratched the paint.
I've read that TJs sometimes have clearance issues with the Riddler diff cover around the track bar at full stuff. No such issues on my WJ, both with the OEM track bar and with the JKS track bar. It also sticks a little further forward and comes close to the tie rod at full steering lock. However, there's still enough room to get your finger between it and the tie rod, and even more room with the JKS tie rod installed (smaller OD than stock).
nwaxtreme
nwaxtreme's Reviews
09-04-2011, 11:46 PM
Price: $110.00
Pros: Fits perfect and superior quality.
Cons: Little pricey but worth it.
Recommended? Yes
Comments: Very happy with the Riddler cover. Includes stainless bolts.
Washi
Rockbiter
Washi's Reviews
08-14-2011, 11:38 AM
Price: $110.00
Pros: Smooth, very stout, looks killer
Cons: None
Recommended? Yes
Comments: Easy to see why this is a good upgrade. Like the new locking hardware that it comes with. I like the fact that you can leave it alone or paint it however you want.
man44a
man44a's Reviews
04-24-2011, 05:36 PM
Price: $100.00
Pros: Heavy, solid, well made.
Cons: Bolts that are included are soft. Do not torque to factory specs
Recommended? Yes
Comments: Heavy, solid, well made.
Bolts that are included are soft. Do not torque to factory specs.
UncleWilson
Because I can...
UncleWilson's Reviews
03-19-2011, 04:32 PM
Price: $100.00
Pros: Just watch the Rokmen test video. This thing is pretty darn strong. High fill hole helps with high pinion angle
Cons: None
Recommended? Yes
Comments: Very Nice!
vbohannon64
vbohannon64's Reviews
03-06-2011, 08:18 AM
Price: $110.00
Pros: Heavy and thick
Cons: None
Recommended? Yes
Comments: Great product. It adds strength to the housing as well as protection to your diff. Comes with new stainless hardware and gasket sealant. Ships bare steel.
MuddyJeep42
MuddyJeep42's Reviews
02-08-2011, 01:12 PM
Price: $109.00
Pros: Heavy duty! Raised fill hole.
Cons: Supplied bolts are cheap and WILL NOT withstand the torque requirements of a Lube Locker gasket without twisting off in your axle! DO NOT USE THEM!
Recommended? Yes
Comments: Attempted to use the diff guard with a lube locker reusable gasket which requires a first torque of 15 fp and a second of 32 fp. The first bolt I tried to apply 32 fp quickly twisted off in my axle!
Scooter_Trash
Scooter_Trash's Reviews
01-18-2011, 10:06 PM
Price: $50.00
Pros: Perfect fit, and it does what its supposed to do.
Cons: None
Recommended? Yes
Comments: I bought this product 2nd hand. It was a perfect fit and the powdercoating was perfect.
Woodchuck
Wannabe Adventurer
Woodchuck's Reviews
11-09-2010, 11:26 AM
Price: $100.00
Pros: Tuff
Cons: Not as pretty as AEB's
Recommended? Yes
Comments: The do what they are supposed to do
emein
Junior Member
emein's Reviews
10-06-2010, 07:53 AM
Price: $100.00
Pros: They are simply GREAT!
Cons: None
Recommended? Yes
Comments: After going down the Rubicon, it was clear I needed better diff covers. The riddlers are really well made, and look great! Great product! E
markxj2k
markxj2k's Reviews
10-03-2010, 09:24 PM
Price: $99.00
Pros: Designed for JK Rubicon e-Lockers, recessed fasteners, good price
Cons: None
Recommended? Yes
Comments: I replaced the stock front and rear diff covers with these. Painted them with Rustoleum black bedliner and then painted the logos silver. I liked the fact that they had the flat area required to connect the wires for the OEM Rubicon electronic lockers. No problems so far.
warCryr
warCryr's Reviews
08-22-2010, 10:45 PM
Price: $110.00
Pros: Solid and thick and no lip. Cool looking. Doesn't come painted so you can do whatever you want easily.
Cons: Doesn't come painted so you have to do it yourself.
Recommended? Yes
Comments: Everything is fine except I wish it was painted already or powder coated, but thats just me. The only reason I didn't give this a 5 is because I kept breaking the hardware that is provided with the cover. I was using a torque wrench and going to 35 ft/lb., but then I gave up on that and went and got grade 8 hardware and still broke bolts at 30 ft/lbs, I eventually ended up with grade 8 hardware torqued to 25-30 ft/lbs. No problems yet.
Wup This
Wup This's Reviews
08-10-2010, 09:04 PM
Price: $109.00
Pros: Beefy, stainless hardware, looks
Cons: one bolt recess was a little close on the Rear 8.25 and made for a tight fit with socket but I'm being nit picky. They don't give you enough silicone to seal the rear so you have to buy a bigger tube....it's just enough to do the D30 cover and that is pushing it.
Recommended? Yes
Comments: Great looking covers that fit perfect and seal up nicely. Paint mine with black semigloss and they look fantastic. NOTHING to hang up one and sealed perfectly the first time!!
I paid cost and couldn't believe how much of a mark up there is for retail customers.
mmarmouz
mmarmouz's Reviews
07-29-2010, 12:33 PM
Price: $100.00
Pros: Very Solid
Cons: None
Recommended? Yes
Comments:
vilseck21
vilseck21's Reviews
07-19-2010, 01:12 AM
Price: $50.00
Pros: its works great
Cons: I cant think of any
Recommended? Yes
Comments: This has saved my fron diff many times
ThreadForumRepliesLast Post
Rockcrusher Dana 30/35/44 Differential Cover Differential Guards 28 10-26-2009 09:04 AM
Currie Enterprises ramped HD cover for Dana 44 front differential Differential Guards 1 10-15-2009 09:13 AM
Dana 35 Kryptonite Differential Cover D.I.Y Differential Guards 1 06-13-2009 12:36 PM
Solid Axle Industries Differential Cover Skid Plates 3 07-30-2008 02:36 PM
TKH Fab Dana 30 Differential Cover Differential Guards 3 09-18-2007 10:04 AM
Glock Forum
