Rancho - Rancho RS6227 Dana 30 Differential Glide Plate Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Differential Guards Next Product
Rating:
Product Information
MSRP: $160.00
Average Price: $157.63
Manufacturer: Rancho
Recommended?
Yes: 1 / No: 0
Company Website: http://www.gorancho.com/tjrockgear/diffglide.php
Mounts to front axle casting
Allows for a much smoother glide over obstacles forward and backwards.
Protects casting from direct contact
Works with OE and most aftermarket differential covers
Durable red powder-coated finish
None
mattman998
mattman998's Reviews
09-16-2013, 11:53 AM
Price: $157.63
Pros: - Seems very durable - Nice finish - Hardware seems good
Cons: - .75" loss of clearance - Doesn't work with some aftermarket diff covers
Recommended? Yes
Comments: EDIT: After a year and a half of use I would not recommend this product to anyone that really plans on using it. The lip has bent back towards the diff cover to the point where I'm pretty sure I'll have to cut it off if I ever want to service the diff again. When this is done I'll switch to a plain old heavy duty diff cover. I'll enjoy having the .75" clearance back.
I've added a photo to show how it's held up to a year and a half of wheeling every month or so.
here's the original review that I left:
This is definitely a conditional item. I'm not a very good driver off-road yet, so I tend to drive in to a lot of rocks. I'm hoping that this glide plate with smooth out some of the hits. Unfortunately, after measuring before/after the installation, there is a loss of .75" of clearance. I will be feeling a lot more hits with that kind of clearance loss. I think this will be good for my style of off-roading, and should help a lot with my driving-into-stuff problem
I just installed it two days ago and haven't been able to test it yet. I'll post again once I've smashed it a couple of times.
Installation was very easy, you just remove the lower 5 bolts on the diff cover and bolt this on, then install the metal strap over the rear side of the diff housing. This does NOT work with the Rugged Ridge Dana 30 skid, so I had to take it off and just retain the factory cover. It is supposed to work with most aftermarket covers though.
